TPS/i powerdrive
PowerDrive (MIG/MAG) is an alternative to the PushPull system. It only uses one wirefeeder, namely the WF 25i RD, which is placed close to the arc (directly on the torch body) and ensures reliable and constant wirefeeding. This enables the PMC Mix Drive process to be used, bringing advantages in aluminium applications in particular.
Applications
  • Automotive and Supplier Industry
  • General Industry
Your benefits
Excellent gap-bridging ability using the PMC Mix Drive process
  • Enables clear weld rippling
  • Low heat input
  • Ideal for aluminium applications
  • Easy to join thick- and thin-gauge sheets
All materials can be welded
  • Steel
  • CrNi
  • Aluminium
Safe and constant wirefeeding
  • Wire can be fed directly out of the wire drum
  • Robacta Drive positioned right in front of the torch body
Quicker, time-saving teaching with TeachMode
  • Assists with robot teaching
  • No wire deformation during teaching
  • Keeps the stick out constant
ARE YOU LOOKING FOR THE IDEAL SOLUTION FOR YOUR WELDING Challenge?
Let's get connected.
fnyrf@sebavhf.pbz Contact
