TPS/I PUSH Systems
Push systems (MIG/MAG) are particularly suitable for standard applications (e.g. CrNi and steel), where consistent quality and high system availability are needed.
Applications
  • Automotive and Supplier Industry
  • General Industry
Your benefits
Low-cost, low-maintenance robot welding system
  • Quick to assemble
  • Compact system with only one wirefeeder
  • Robust system for harsh production conditions
High welding speeds using the PMC process
  • Uniform penetration
  • Low risk of undercutting
  • PMC Mix characteristic for positional welding and visible weld seams
  • The arc-length and penetration stabilizers aid the welder and facilitate constant, unwavering weld seam quality
Constant penetration with the LSC process
  • Low-spatter dip transfer arc
  • Optimised for light-gauge sheet applications
  • "Root" characteristic for perfect root passes
  • Penetration stabilizer for constant penetration
ComfortWire brings time savings
  • Assists during wire threading
  • Optimum wire position at the start of welding – automatic
  • Easy to change the wire drum
Optimised welding torches for shift operation
  • Long service lives of wearing parts
  • Magnetic CrashBox with high reset accuracy to protect the torch body
ARE YOU LOOKING FOR THE IDEAL SOLUTION FOR YOUR WELDING CHALLENGE?
Let's get connected.
fnyrf@sebavhf.pbz Contact
