TPS/i PushPull Systems
Equipped with two perfectly synchronised wirefeeders, these systems are predominantly used with long wirefeeding distances and soft filler metals. PushPull systems (MIG/MAG) are suitable for all processes and applications.
Applications
  • Automotive and Supplier Industry
  • General Industry
Your benefits
Process: CMT
  • Extremely stable dip transfer arc up to 315 A
  • Less rework thanks to practically spatter-free welding
  • Exceptionally low heat input
  • Performance increased by 20% with the TPS/i
  • Suitable for welding the thinnest materials – from 0.3 mm
Universal use
  • Special material joints are possible, e.g. steel/aluminium, copper, zinc, titanium, magnesium, etc.
  • Cladding with little dilution
  • Minimal spatter when welding steel with 100% CO2
  • Brazing, particularly where there are high demands in terms of heat input and process stability
  • New options: Additive Manufacturing, CMT Cycle Step, CMT Marking
All welding processes possible
  • Standard
  • LSC
  • Pulse
  • PMC
  • CMT
Maximum wirefeeding flexibility
  • ​Two synchronised wirefeeders guarantee reliable wirefeeding
  • The large range enables the wire drum to be individually positioned
ARE YOU LOOKING FOR THE IDEAL SOLUTION FOR YOUR WELDING CHALLENGE?
Let's get connected.
fnyrf@sebavhf.pbz Contact
