Transsteel 2200
The multi process steel pro from Fronius. MMA, MIG/MAG, TIG: This power source manages all welding processes without quality issues. Because of the multi voltage variant it is suitable for all power supply systems worldwide. The design of the machine fits perfect for construction site applications.
Applications
  • Workshops
  • Steelwork
  • Servicing & maintenance
Your benefits
Multiprocess device
  • MMA
  • MIG/MAG
  • TIG
Intuitive operation
  • Simple menu navigation
  • Main setting visible on the control panel
Multivoltage variant
  • Compatible with different grids
  • Compensates for voltage fluctuations
Technical data
  • Multivoltage: 120 and 230 volts
  • Duty cycle
  • 60% - 180 A
  • 100% - 160 A
  • Wire diameters of 0.6 - 1.2 mm
ARE YOU LOOKING FOR THE IDEAL SOLUTION FOR YOUR WELDING CHALLENGE?
Let's get connected.
fnyrf@sebavhf.pbz Contact
