BlogExperience reportsSupport area
Fronius GEN24 & GEN24 Plus.
Designed to empower.
Installer in front of GEN24 inverter on the wall
Thanks to the Fronius GEN24, you can also use backup power with your PV system
With the Fronius GEN24 at the heart of your photovoltaic system, you can use your own solar energy flexibly and directly, even in the event of a power failure. You can even enjoy 24 hours of sun in your home with the Fronius GEN24 Plus because the hybrid inverter lets you connect a battery storage system, making your energy supply even more independent.
Electricity, heating, cooling, e-mobility: Anything is possible - even at night with the GEN24 Plus.
Full solar power for your energy revolution with the Fronius GEN24 and Fronius GEN24 Plus. Designed to empower.
    Backup power for every situation
    Your energy supply must be reliable. That’s why the Fronius GEN24 offers an integrated basic backup power supply, which works even without battery storage. In combination with a battery storage system and a grid switching device of your choice, the Fronius GEN24 Plus can even back up your home’s entire power supply in the event of a power failure.
    • Fronius GEN24: with PV Point – an integrated basic backup power supply from a socket when the sun is shining
    • Fronius GEN24 Plus: with PV Point – an integrated basic backup power supply – or Full Backup – power for the whole home, even large loads such as heat pumps
    Family dinner in the evening
    Built-in freedom
    The Fronius GEN24 and Fronius GEN24 Plus have open interfaces that enable optimal integration and control of Fronius and third-party components. The integrated and intelligent load management maximises self-consumption by efficiently distributing excess PV energy and prioritising consumers such as heat pumps, pool pumps or wallboxes.
    • Open interfaces for easy integration and control of Fronius and third-party components
    • Increased self-consumption thanks to integrated and intelligent load management for controlled operation of various consumers
    Versatility as standard
    The Fronius GEN24 and Fronius GEN24 Plus help you establish an efficient, independent energy supply.
    • Optimum yield, even when the PV modules are in shade
    • Active cooling for a longer service life
    Always the right solution: with or without a Plus
    With our Fronius GEN24 and Fronius GEN24 Plus inverters, you can live more sustainably no matter which solution you choose. Whether you want to take advantage of the Fronius GEN24 Plus straight away for greater reliability and independence depends entirely on your needs.
    Use of your solar power
    Making the most of your solar power – Reliable backup during power outages
    Fronius GEN24
    Direct usage of solar power when the sun is shining:
    – Self-sufficiency instead of relying entirely on the grid
    – Cost savings instead of high energy prices
    Fronius GEN24 Plus
    Greater independence thanks to the battery storage connection:
    – Use the solar power when you need it, day or night
    – Even more independence from electricity providers and energy prices
    Fronius GEN24
    Backup power when the sun is shining:
    – PV Point: integrated basic backup power function
    – Supply via a separate socket
    Fronius GEN24 Plus
    Two backup power options for enhanced security:
    – PV Point for socket supply
    – Full Backup for whole-home coverage, even for large loads like heat pumps.
    The ultimate decision aid
    For those who still can’t decide: With the Fronius UP.storage* software upgrade for the Fronius GEN24, the existing device can be retrofitted with a battery connection at any time, including the Full Backup option.**
    * Available in selected countries.
    ** The Full Backup option is not available for the Fronius Symo GEN24 3.0–5.0 Plus.
    meadow-green
    Fronius Solar.web
    Knowledge as a service: Our monitoring tool for photovoltaic systems records all the key data and provides a clear overview of the energy flows in your home. This allows you to easily optimize your power consumption. With Fronius Solar.web you can find out, for example, whether a battery storage system is worthwhile for you or when’s the best time to turn on your tumble dryer to save even more money.
    Learn more about Fronius Solar.web
    Sustainable right from the start
    All our products and solutions are “Made in Europe” with a constant focus on sustainability. This has been verified by the renowned Fraunhofer IZM, which put our Fronius GEN24 inverters to the test in a life cycle analysis. They impressed in every phase with sustainable performance and outstanding features:
    100% recycled aluminum
    for the heat sinks in all Fronius GEN24 and Fronius GEN24 Plus inverters
    100% green power
    is used in our production facilities in Austria
    Maximum repairability
    thanks to easy-to-replace individual components
    Solar energy to reduce CO2 emissions
    As part of the energy revolution, you enjoy double the benefits while also setting an example: With the Fronius GEN24 and Fronius GEN24 Plus at the heart of your photovoltaic system, you will save money and cut CO2 emissions from day one.
    Climate benefits of Fronius GEN24
    Using a photovoltaic system in combination with the Fronius GEN24 or Fronius GEN24 Plus over 20 years will save enough CO2 to compensate for 587 flights* from Lisbon to New York.
    * Depending on the specific scenario of the Fronius GEN24 life cycle analysis.
    Fronius GEN24 Plus in action
    A life with 24 hours of solar power, is that even possible? Yes! The Anzi family is already living this vision of the future in Niederfüllbach, Germany, and relies entirely on quality Fronius products to make it happen. These products transform the power of the sun into electricity, heating, cooling, and e-mobility, enabling the family to live an energy self-sufficient life.
    Click here to learn more about their experience
    House with solar panels and electric car at sunset
    Multi-award-winning
    Your photovoltaic system can do more
    Imagine if you could use your excess solar energy to produce heat or energy to power your electric car. Fronius makes this possible. With solutions tailored to the very heart of your photovoltaic system:
    Fronius Ohmpilot
    The Fronius Ohmpilot consumption regulator uses excess power to continuously control the heating of hot water, so you can enjoy efficient energy use and even lower CO2 emissions.
    Learn more
    Fronius Wattpilot
    Sustainable, affordable travel: Our Fronius Wattpilot uses excess solar energy to power your electric car. Available as a mobile charging solution to take with you or as a stationary model for the home.
    Learn more
    Compatible battery storage
    ndependent and reliable: With a battery storage solution, you have reliable access to your PV energy at night and even in the event of a power failure.
    Learn more
    Fronius Ohmpilot
    Learn more
    Fronius Wattpilot
    Learn more
    Learn more
    Find a suitable Fronius partner installer now
    By installing a photovoltaic system, you are laying the foundation for a sustainable and cost-effective energy supply. It pays to invest in quality components and work with reliable partners.
    As solar pioneers with more than 30 years of experience, we produce our inverters in compliance with strict quality guidelines in Austria and work closely with our Fronius Solutions Partners. Our partner network consists of over 5800 expert installers around the world.
    Find a suitable partner installer and let us support you personally, from the consultation to the installation.
