BlogCase studiesSupport area
Fronius Wattpilot Flex
Future driven
Wattpilot Flex: Maximum efficiency for charging with solar power
For those who like to be ahead of the game, Fronius offers the perfect combination of elegant design* and state-of-the-art technology with the Wattpilot Flex.
The Fronius EV charger uses every ray of sunshine from your PV system** to charge your car as efficiently as possible for the next day. Intelligent charging modes enable cost-effective and efficient use of the solar power generated by your own PV system. The ideal electric car charging station for your home—sustainable, flexible, and cost-efficient.
* The Wattpilot Flex is supplied in the limited edition with embossed logo and the standard version with classic red logo. The product delivered will be allocated based on availability at dispatch.
** Additional components are required for charging with surplus PV energy. All the details can be found in the operating instructions.
Fronius Wattpilot Flex with embossed and classic red logo
Charge and save with the power of the sun
Charging your EV at home can be significantly more affordable than filling up with petrol. With typical EV consumption of around 18–20 kWh per 100 km and an average Australian electricity price of around 30 cents per kWh, driving 100 km costs approximately $5–$6 when charging from the grid.
If you have solar, charging becomes even more cost‑effective. Using your own excess solar energy can reduce the cost to around $0–$3 per 100 km, depending on your solar generation and electricity tariff.
In comparison, a typical petrol car using 8 L/100 km at an average price of about $1.75 per litre costs roughly $14 per 100 km. Over an average annual driving distance of 15,000 km, this can mean hundreds of dollars in savings every year.
With the Fronius Wattpilot Flex, you can maximise your solar self‑consumption, reduce charging costs, and improve the return on your solar investment, all with smart, flexible EV charging.
*Consumer‑Compliant Disclaimer: All figures are indicative only. Actual savings depend on vehicle efficiency, driving habits, solar generation, energy tariffs, and local fuel prices. Electricity and fuel prices are based on Australian national and state averages as of 2026.
Maximum sun
Your energy, your e-mobility. With the Fronius Wattpilot Flex, you can charge your electric car very economically with self-generated solar power. The PV-optimized wallbox automatically switches between 1 and 3 phases to make the best possible use of the sun's power. From 1.38 to 11 or 22 kW (depending on the version), PV surplus is optimally used. No ray of sunshine is wasted.
Thanks to intelligent charging modes, you always have the choice: Eco Mode gives priority to solar power, while Next Trip Mode ensures that exactly the right amount of energy is charged at the right time for your next trip.
If you have a PV system, Fronius Wattpilot Flex gives you a double benefit: you save on charging and also increase your own consumption - which speeds up the amortization of your PV system.
Woman with electric car and Fronius Wattpilot Flex
Pure elegance
Experience a new level of charging your electric car - with the Fronius Wattpilot Flex.
This EV charger will impress you with its modern design and its outstanding functionality. The elegant look and high-quality finish make it a stylish addition to your home.
Electric car and Wattpilot Flex
Flawless usability
The Fronius Wattpilot Flex offers a user-friendly interface with intuitive touch buttons and clear menu navigation.
Integrated WLAN and LAN interfaces allow easy integration into your home network.
The Solar.wattpilot app enables conveniently control and monitor the wallbox via smartphone or tablet - anytime, anywhere.
Thanks to RFID technology, you can manage different user profiles and always have full control over all charging processes.
Discover the highlights of the electric car charger for your home.
Additional information for installers and commercial customers
Here you will find technical data and important downloads, as well as special features that may be of particular interest to installers and commercial customers.
Wattpilot Flex touch display
Installation made easy
The Fronius Wattpilot Flex is quickly installed and ready for operation in no time at all. Whether indoors or outdoors, on a company parking lot, in an underground garage or in front of a residential building - with protection class IP66, the Wattpilot is optimally protected against external influences. Cables can be routed from the top, bottom or rear of the unit, allowing for flexible system design to suit the location.
Photovoltaics and e-mobility: the ideal combination for your customers
The synergy of photovoltaics and e-mobility results in innovative energy solutions with which you can optimally expand your product portfolio. With Fronius complete solutions, you can offer your customers perfectly matched energy systems from the leading solution provider.
Are you interested in a portable charging solution?
The Fronius Wattpilot Go is the portable charging station for use on the go. Thanks to the CEE plug, you can charge whenever and wherever there is a plug socket available.
Learn more about Wattpilot Go
Technical data
Data Wattpilot Flex Home
Max. charging power 11/22 kW
Dimensions (l x w x h) 325 x 195 x 105 mm
Weight incl. type 2 cable 4.1/5.4 kg (11/22 kW)
Charging cable 6m cable with type 2 plug
Cable entry Cable entry from top (only permitted indoors), bottom, rear
Network connection LAN & WLAN
MID meter  Not integrated
Conformity with calibration law (Mess- und Eichrechtskonform)  No
Color Telegrey 4
Use* Indoor & outdoor
*When installing outdoors, the cable entry may only be used from below or behind. The charging power of the Wattpilot may be limited in direct sunlight.
