Lightweight aluminium construction for industry: access solutions from ALTEC
Application Story
7/6/2021
ALTEC manufactures a wide variety of largely aluminium scaffold-based access solutions, such as aircraft docking systems, by relying on welding technology from Fronius. With the CMT welding process and the Rippledrive pulse characteristic, ALTEC’s industrial production lines are fully equipped for future challenges.
It is not only in lightweight automotive construction or aerospace technology that aluminium is a byword for dynamism and pushing the boundaries of accepted engineering limits. It also facilitates everyday life wherever large structures have to be moved by human hands, such as the diverse range of access solutions offered by ALTEC Aluminium-Technik GmbH & Co. KGaA.
The medium-sized enterprise from Mayen in the western German state of Rhineland-Palatinate has an extremely broad product portfolio: from rolling scaffolds, facade scaffolds and flat roof fall-protection systems to complete docking systems for the aviation industry and numerous special solutions. These include mobile maintenance stairs, working platforms, transitions or platform stairs for industrial applications.
Certified welding company with the latest technology
Up to 95 percent of the metal processed and welded on ALTEC’s production lines is aluminium. Steel applications account for just five percent. Yet as a specialist welding company with EN 1090-1 and 1090-3 certification, ALTEC and its 50 employees can master even the most complex orders thanks to 35 years of experience in welding aluminium components. In order to be able to meet its customers’ demands, ALTEC has always relied on pioneering process and manufacturing technology, despite its relatively modest size. “This includes state-of-the-art CAD workstations as well as fully automated robotic welding cells and the associated high-tech welding process technology,” explains Siegfried Berenz, a certified master metalworker and international welding specialist (IWS). Having spent the past 15 years being primarily active in the fields of aluminium welding and processing, he took over as plant manager of ALTEC in 2019.
Fronius welding technology moves in at ALTEC
As part of an ongoing automation process, a specific aluminium framework part (AlSi1, two millimetres) that has since become required in large quantities was to be transferred from manual production to robotic welding. One of the main goals here was to achieve a high welding speed in order to gain a competitive advantage. At the same time, the structure was to be joined with the greatest possible process reliability.
As a specialist in thin sheet and aluminium applications, Fronius therefore had the opportunity to beat the competition in 2018 as ALTEC found the best possible solution for its needs with the Fronius CMT (Cold Metal Transfer) process. When deployed in combination with the high-tech TPS 320i welding system platform, CMT delivers particularly high welding speeds, especially in the thin sheet range. As a result, Fronius succeeded in establishing itself in ALTEC’s production operations.
After 25 years of automated production, however, other areas of ALTEC’s robotic welding technology were also becoming long in the tooth. Plant manager Berenz therefore made it his mission to ensure the company’s production environment was equipped to guarantee long-term competitiveness. Following the positive experiences gained with the CMT process, the welding expert once again turned to the German sales and service team at Fronius Kaiserslautern.
Further manufacturing challenges for ALTEC
In the case of the scaffolding system concerned, the outdated welding technology from a third-party supplier was now causing up to 70 percent rework due to a steady increase in weld seam defects. Time, material and labour costs were therefore no longer in proportion, and the advantages of robotic welding were being completely cancelled out. In addition, the weld seam appearance no longer came close to satisfying ALTEC’s strict demands. However, the production volume of the component was not high enough to justify investing in a modern robot system.
ALTEC’s requirements were therefore clear – a new system would first have to be compatible with the old robot technology. In addition, the greatest possible process reliability had to be ensured, which would reduce downtimes to almost zero. If possible the system should also be capable of welding in a single action in order to reduce processing times; it was this target that represented the greatest challenge. Due to the round style and the semi-circular fabrication of the rung, the unmanipulated welding operation would have to produce a vertical-up, flat and vertical-down seam in a single action. One process for all positional welds was thus a basic requirement.
At the same time, there was a gap of two millimetres in the flat-seam section due to the pre-processing. Particularly high gap-bridging ability therefore also had to be ensured in the future process technology. In order to be able to clearly distinguish itself from the competition in the production of scaffold and framework structures, the future welding process also had to deliver the best possible weld seam appearance. And on this basis ALTEC started its search for alternative modernization options.
Conversion to PMC Rippledrive
Extensive welding tests conducted at the Fronius Germany competence centre for application engineering in Neuhof-Dorfborn near Fulda ultimately led to a successful conclusion. The PMC Rippledrive welding process variant, a special characteristic used for pulse welding, represented the most suitable solution for ALTEC’s welding challenges.
Rippledrive works in a way that is as ingenious as it is simple. Between a number of pulses defined by the welder, defined pause times are set in which the arc is completely switched off. This gives the weld pool time to cool down, making welding possible in all positions. The necessary gap-bridging ability of two millimetres is also guaranteed without any problems. In terms of appearance, the Rippledrive function also leaves a rippling pattern that is in no way inferior to the elegance of TIG welding.
The Pulse Multi Control (PMC) functions also allow the number, shape and size of the individual welding spots to be set by precisely defining the pulse currents. The TIG-like seam pattern can thus also be varied in its final execution.
TPSi compatible with all robot systems
However, ALTEC also had to deal with the problem of connecting the welding technology to the robot. The task now was to mate the newly acquired TPS 320i digital high-tech welding system platform and the Fronius Robacta-Drive push-pull welding torch needed for the Rippledrive solution with the veteran but fully operational robot technology. ALTEC decided to take this step not least because of the wide range of fieldbus protocols (modern interfaces) available from Fronius, as well as the option of connecting the TPSi using conventional digital or analogue interface technology.
This results in the extraordinary advantage that the TPSi is truly compatible with almost every robot. Furthermore, the high-tech power source is equipped with numerous standardised hardware and software interfaces for various robot manufacturers right from the start. This reduces the installation time required to integrate the power source into the robot system to a minimum.
Impressive service and technical expertise from Fronius
ALTEC plant manager Siegfried Berenz is thoroughly impressed with the welding results and the service: “The expert advice from the Fronius application engineers and our experience to date with the new Rippledrive welding process have absolutely convinced us of the worth of the Fronius system. It has enabled us to reduce welding times by around 20 percent.”
One of the reasons for this is that the welding robot now no longer has to travel from the centre of the weld seam in both directions. “By using Rippledrive, it became possible for the first time at ALTEC for the robot to weld from left to right – through all the challenging vertical-up and vertical-down positions – in a single action. At the same time, weld seam defects have become an absolute exception, which means that the rework that was previously necessary is now almost zero,” continues Berenz. The highly precise wire guidance is also responsible for this: from the wire drum to the contact tip, all the components of the welding system involved are perfectly matched to each other. Only in this way can the particularly soft AlSi 5 wire be conveyed with the necessary precision over the required seven (!) metres.
Reduction of downtimes by almost 100 percent
“This fact, as well as the modernization of the plant itself, has reduced downtimes to a minimum. As a result, downtimes hardly ever occur any more. The high process stability of the Fronius welding system that has made this possible has therefore completely convinced us,” assures the plant manager.
“Should system failures nevertheless occur, the Fronius technicians are on site in no time at all thanks to the dense support network, which in our case is fulfilled by the Fronius Kaiserslautern sales and service team. Maintenance and servicing work is conducted reliably and highly professionally.”
High-quality process technology for high-quality parts
“The visual appearance of the welded parts has also improved significantly, making post-weld cleaning almost superfluous,” adds a visibly delighted Siegfried Berenz. However, in his eyes, the almost perfect Rippledrive TIG weld seam appearance is not only a bonus, but also an important prerequisite for underlining the high quality of ALTEC products.
Fronius and ALTEC have thus been able to develop a particularly trusting and mutually valuable relationship.
1. APPLICABILITY
2. PRICES AND PAYMENTS
5. GENERAL EXPRESS WARRANTIES
5.1 General. Seller warrants to Buyer only, subject to the disclaimers and limitations of the Agreement, that Goods to the extent manufactured by Seller shall be free from defects in materials and workmanship at the time of delivery which are discovered and reported to Seller within the period of 24 months from the delivery date. From the beginning of the 13th month of this period, however, Seller’s warranty shall be limited to making available, free of charge, the items needed for remedying the defects; from this time onwards, any warranty claims going beyond the above shall be inadmissible. This period limitation also applies to the supply of items deemed to be immovable and to work on items which are, or are deemed to be, immovable. The warranty period shall start to elapse upon the passage of risk. Buyer must always prove that defects coming to light during the warranty period were already present at the time of the passage of risk. This is not a warranty of performance, but a limited warranty as to the condition of the Goods at delivery. Seller does not warrant any portion of the Goods not designed, developed or manufactured by Seller (whether or not specified by Buyer), but Seller shall assign to Buyer upon request all assignable warranties of Seller’s suppliers related to such Goods. Because the Goods may be subject to a wide variety of use, installation, maintenance, cleaning, and other factors, the warranty is only against the named defects and not against any other defects or failures such as, but not limited to, those due to normal wear and tear, normal maintenance and unknown causes. Perishable and wear items are excluded from warranty against defects. Buyer shall ensure that all computer equipment and software included with or used with the Goods has adequate protection against viruses or other malicious software after initial installation. Seller’s warranty does not cover damage or contamination caused by such malicious software. Notwithstanding anything to the contrary, there is no warranty as to prototype Goods.
6. PATENT WARRANTIES
7.4 Warranty
9.1 General Remedies. Defective or non-conforming Goods or parts thereof discovered and reported during the express warranty period shall be repaired, or replaced by Seller without any additional charge, and shipped to Buyer, FOB Seller’s plant, for reinstallation by Buyer at its cost, subject to the terms hereof of the Agreement, as Buyer’s exclusive remedy. The warranty obligation of Seller is limited to the repair or replacement at Seller’s plant of any part of the Goods which Buyer shall, within the warranty period, return to Seller, with transportation charges prepaid by Buyer, and which Seller shall determine upon examination to be defective or not in conformity with the express warranties contained herein. Goods cannot be deemed defective or non-conforming if Seller cannot duplicate the alleged failure. In lieu of repair or replacement, if Seller elects, Seller may, upon return of such Goods and making a determination of nonconformity or defect, keep the Goods and refund the purchase price as Buyer’s exclusive remedy. Seller may provide such repairs itself or through its third party contractors. Buyer’s remedies shall be limited (even in the event of Seller’s default of its warranty obligations or a failure of an item to meet its intended purpose) exclusively to those provided in this Section. UNDER NO CIRCUMSTANCES SHALL SELLER BE LIABLE, REGARDLESS AS TO WHETHER SELLER’S LIABILITY ARISES UNDER CONTRACT, TORT, STRICT LIABILITY STATUTES, OR OTHERWISE, FOR EXEMPLARY, PUNITIVE, SPECIAL, CONSEQUENTIAL OR INCIDENTAL DAMAGES, INCLUDING BUT NOT LIMITED TO: LOSS PROFITS OR REVENUES; INCREASED COSTS; DAMAGE TO EQUIPMENT, TOOLING,PREMISES, OR WORK-IN-PROCESS; COST OF CAPITAL; COST OF PURCHASED POWER; SUBSTITUTE OR ADDITIONAL EQUIPMENT, FACILITIES OR SERVICES; COST OF PRODUCTION INTERRUPTION OR START-UP; OR THE CLAIMS OF THIRD PARTIES FOR SUCH DAMAGES, WHETHER OR NOT THE DAMAGES WERE FORESEEABLE OR SELLER WAS ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Each provision of the Agreement which provides for a limitation of liability, disclaimer of warranties, or exclusion or limitation of damages or remedy is severable and independent of each other and to be enforced as such. Buyer waives any causes of action or theories of liability relating to or arising under the Agreement including, but not limited to, those arising under contract, tort, strict liability, product liability statutes, or otherwise, except as specifically provided by the UCC as modified and limited herein. The replacement or repair of Goods by Seller does not give rise to any new or extended warranty, and the warranty period provided for herein shall not be extended by the length of any period from the date the defective or non-conforming Goods are received by Seller until the date the repaired or replacement Goods are delivered to Buyer or otherwise.
10.1 SELLER DISCLAIMS ALL IMPLIED WARRANTIES AND SIMILAR OBLIGATIONS (OTHER THAN THAT THE GOODS WILL BE NEW AND GOOD TITLE) INCLUDING BUT NOT LIMITED TO THOSE OF NON-INFRINGEMENT, FITNESS FOR A PARTICULAR PURPOSE, AND MERCHANTABILITY, WHETHER OTHERWISE ARISING BY LAW, CUSTOM, USAGE, TRADE PRACTICE, COURSE OF DEALING, OR COURSE OF PERFORMANCE. There are no warranties which extend beyond those express warranties contained in the Agreement. Buyer affirms that it has not relied upon Seller’s skill nor judgment to select or furnish the Goods for any particular purpose beyond the specific express warranties in the Agreement. Any design provided by Seller is based on information provided by Buyer. Seller may rely entirely on information provided by Buyer and is under no obligation to verify such information or take any action to obtain explanatory or supplemental information from Buyer or third parties. Buyer’s approval of drawings and/or prototypes constitutes Buyer’s acceptance and waiver of any responsibility for a failure to consider or correct information or approval provided by Buyer. Any modifications of drawings, prototypes and other work of Seller after approval by Buyer shall be at Buyer’s expense at Seller’s normal rates for services and materials. Seller does not warrant the Goods will comply with the requirements of any safety or environmental code or regulation of any federal, state, municipality or other jurisdiction beyond the specific express warranties in the Agreement. Seller does not warrant that the Goods will operate with any accessories or within any system not sold under the Agreement and Seller’s warranty is limited to the operation of the Goods in a stand-alone mode, unless specifically stated in Seller’s written specifications. Some countries, states, or provinces do not allow the exclusion or limitation of implied warranties or the limitation of incidental or consequential damages for certain products supplied to consumers, or the limitation of liability for personal injury, so such limitations and exclusions may be limited in their application to an end user and others. When the implied warranties are not allowed to be excluded in their entirety, they will be limited to the duration of the applicable written warranty. The warranty gives specific legal rights which may vary depending on local law.
11. INDEMNIFICATION
12. SECURITY INTEREST
12.1 In addition to any security interest granted by the UCC or other law, Buyer hereby grants a security interest to Seller in all Goods and documents related thereto and proceeds and products therefrom to secure all obligations of Buyer to Seller, whether or not arising under the Agreement. Seller may file a financing statement and at Seller’s request, Buyer shall sign financing statements and other documents, which evidence perfect and confirm the security interest. Buyer grants Seller an irrevocable power of attorney to sign Buyer’s name to a financing statement or other similar documents if necessary or convenient to perfect Seller’s security interest. Buyer shall not change the name of Buyer, the jurisdiction of Buyer’s formation, or the location of any Goods from the original delivery point or installation site without prior written notice to Seller. Buyer shall provide a lien waiver or subordination from all third parties to whom the Goods may be delivered. Buyer shall provide a landlord’s waiver or subordination of any lien rights at the premises to which the Goods are to be installed. In case of a default by Buyer, Seller may peaceably enter the premises of Buyer and others and take other actions to repossess or render inoperable all Goods in which it has a security interest provided that Seller provides Buyer with immediate notice it has rendered the Goods inoperable. In case of a default by Buyer, Buyer hereby irrevocably appoints Seller as its agent to obtain possession of the Goods and documents related thereto. Seller may install and activate procedures or devices to make the Goods or Software non-operative upon Buyer’s default. The Goods shall be and remain strictly personal property whether or not affixed or attached on permanent foundation or affixed or attached to building or structure. Title shall not transfer to Buyer until the Goods shall be paid in full. Buyer shall maintain the Goods which constitute inventory in a segregated area and not comingle any Goods which are not fully paid. Buyer shall not sell, exchange, transfer, convey, mortgage, pledge, hypothecate or grant a security interest in any Goods which are subject to the Agreement until payment has been made in full to Seller, at which time title shall transfer to Buyer. Buyer shall immediately advise Seller in writing of any damage to, change in location of, or seizure of, any of the Goods the price of which has not been paid to Seller.
13. PROPRIETARY INFORMATION
13.2 Seller’s Rights to Confidentiality. All proposals, plans and other information furnished by Seller in bidding, negotiating and performing the Agreement, are confidential and the property of Seller, whether or not marked “Confidential”, and shall not be shown or disclosed to any other bidder, and shall not be shown or disclosed to any other third party or used by buyer unless necessary for the selection or use of the Goods and notice of such disclosure has been given to Seller. Buyer shall treat as confidential any quotation or other business proposal from Seller and all technology which shall be made available, directly or indirectly to Buyer by Seller and by Seller’s licensors, including but not limited to drawings, schematics, specifications, bills of material, test results, analysis, recommendations, models, and designs, and Buyer shall use such proposal and technology only to evaluate its business relationship with Seller and to enable Buyer to perform under the Agreement. Buyer shall not manufacture or sell any product using confidential information provided by Seller or obtained from reverse engineering or decompiling Goods of Seller. Buyer shall not disclose, or authorize or instruct any third party to disclose, any confidential or proprietary information of Seller to any third party that is not bound by contract to at least the same duty of confidentiality to Seller as is Buyer. In addition, only those employees and contractors of Buyer having a need-to-know and bound by contract by the same confidentiality provisions as Buyer may be given access to such technology. Buyer shall maintain, for Seller’s inspection, written records which shall include the names and address of such employees and contractors granted such access. Buyer shall indemnify Seller from all expenses and damages related to the improper use or disclosure by Buyer or its employees and contractors. Business proposals and technology of Seller may be protected by patent, copyright, trademark and other law. No license or other right to business proposals or technology is granted to Buyer except as specifically provided in the Agreement.
14. BREACH
15.1 Disclaimer. BUYER AND THIRD PARTIES SHALL NOT BE ENTITLED TO ANY CONSEQUENTIAL, PUNITIVE, LIQUIDATED, EXEMPLARY OR INCIDENTAL DAMAGES, AS DEFINED IN THE APPLICABLE LAW OR OTHERWISE, EXCEPT AS TO ANY INDEMNIFICATION OBLIGATIONS TO THIRD PARTIES SPECIFICALLY PROVIDED IN THIS AGREEMENT. “CONSEQUENTIAL DAMAGES” SHALL INCLUDE, BUT NOT BE LIMITED TO, LOSS OF PROFITS OR REVENUE, LOSS OF USE OF CONTRACT GOODS, COSTS OF REPLACEMENT POWER OR CONTRACT GOODS, ADDITIONAL EXPENSES INCURRED IN THE USE OF CONTRACT GOODS OR FACILITIES, OR THE CLAIMS OF THIRD PARTIES, EVEN IF SELLER HAS BEEN ADVISED OF POSSIBILITY OF SUCH DAMAGES OR IF THEY ARE OTHERWISE REASONABLY FORESEEABLE. THIS DISCLAIMER SHALL APPLY TO INCIDENTAL, CONSEQUENTIAL AND LIQUIDATED DAMAGES BASED UPON ANY CAUSE OF ACTION WHATSOEVER ASSERTED AGAINST SELLER, INCLUDING ONE ARISING OUT OF PRINCIPLES OF CONTRACT, ANY BREACH OF WARRANTY, EXPRESSED OR IMPLIED, GUARANTEE, EQUIPMENT OR OTHER CONTRACT GOODS LIABILITY, NEGLIGENCE, TORT, OR ANY OTHER CAUSE PERTAINING TO PERFORMANCE OR NON-PERFORMANCE TO THE PROPOSAL OR ORDER BY SELLER. This limitation shall be enforced regardless of whether Seller has defaulted in its warranty or other obligations or the limited warranty is held to fail of its essential purpose. Any legal inability to limit or restrict the right of Buyer or a third party to such damages shall not affect the right of Seller to indemnification here-under, and under no circumstance shall Buyer recover more than the purchase price. 15.2 Overall Limitation. IRREGARDLESS OF THE DISCLAIMER IN SUBSECTION 15.1 ABOVE, UNDER NO CIRCUMSTANCES SHALL SELLER’S LIABILITY FOR CLAIMS FOR NON-DELIVERY OR OTHER NON-PERFORMANCE, DEFECTIVE PERFORMANCE, NON-CONFORMING GOODS, DEFECTIVE GOODS OR OTHERWISE EXCEED THE AMOUNT RECEIVED OR TO BE RECEIVED BY SELLER FOR THE PERFORMANCE OR SHIPMENT WHICH CONTAINED THE NON-CONFORMING GOODS, DEFECTIVE GOODS OR SUCH OTHER EVENT GIVING RISE TO THE CLAIM, EXCEPT AS MAY BE SPECIFICALLY PROVIDED BY THESE GENERAL TERMS.
16. TERMINATION
17. SEVERABILITY
18. ASSIGNMENT
