Straightforward, robust, and cost-effective: Steel welding with a push system
10/24/2018
Be it in the construction, mechanical engineering, or automotive supply industry, steel is used whenever possible. In steel applications, productivity and cost are often the primary focus. The push configuration of the TPS/i power source from Fronius supports users with improved system availability and optimized system costs.
TPS/i Push System
Whether it’s rolled, milled, or welded, steel is incredibly versatile thanks to the variety of alloys and can be machined with ease. And even more importantly, steel is abundantly available at a reasonable cost. All of these factors make steel the top choice of material, provided that weight, resistance to the weather and acids, and hygiene aren’t an issue in the application in question.
Push system optimizes system costs
Not every welding application is high-tech and high-end. With steel, you’re getting a material that’s straightforward, robust, and cost-effective. And the exact same characteristics apply when welding this material. Gas metal arc welding is often used for steel, either in a manual or robot-controlled process. The push system is ideal for this application, and Fronius offers it as a configuration option for its flexible TPS/i welding platform. The push system has a simple design and is easy to use. It helps ensure high levels of system availability and optimizes system costs as far as procurement and operation are concerned.
This is how it works: the motor in the wirefeeder feeds the wire forward through the hosepack and toward the welding torch. With the hosepack and welding torch also having been developed by Fronius, the system works flawlessly as a whole unit. The welding torch doesn’t require a motor of its own, keeping it lightweight – a definite benefit for welders and robots alike. Less powerful robots are therefore required for automated applications, which reduces the overall system costs even further.
Assistance systems for high quality and faster welding speeds
With the push system, Fronius has once again focused its attention on the consistently high quality of welding results. The Low Spatter Control (LSC) and Pulse Multi Control (PMC) welding packages include assistance systems to help welders achieve high-quality seams even when conditions are tough. Both packages have a penetration stabilizer, and welders receive an additional benefit with the PMC package in the form of an arc length stabilizer. These assistance systems are particularly important when component tolerances cannot be complied with, such as when joins become larger or material thicknesses vary. The stable arc also makes it possible to achieve high welding speeds. Many suppliers within the automotive industry even manage to increase their productivity by around 20% with PMC. Overall, the push system enables users to achieve optimum weld seams even when budgets are tight and conditions are far from ideal.
1. Applicability
2. Offers
6. Passage of risk
8. Warranty
11. Final provisions
12.1 Scope of use
12.2 Further rights
12.3 Warranty
12.4 Compensation
