Welding
TPS/ I Steel Edition Optimized for Manual Steel Applications
Why TPS/i Steel Edition?
With the TPS/i Steel Edition, all of the applications are dedicated to – and optimized for – one particular purpose: steel welding. The Steel Edition has more than 100 steel characteristics for standard and pulsed arcs.
THE RESULT:
  • The right characteristic for every steel application
  • The ability to weld steel plates from just 1 mm thick
 The tough usage conditions also demand great durability. The TPS/i series guarantees uncompromisingly perfect operation in this regard.
QUESTIONS ON THE TPS/i STEEL EDITION?
Contact Fronius for more details about the TPS/i Steel Edition with no obligation.
Our team will be happy to provide you with all the information you need.
Welding machines
SPECIAL FEATURES OF THE TPS/i STEEL EDITION
The Steel Edition is optimized for steel welding at a software level. This means that the most important steel characteristics from the Pulse and Standard welding packages have been combined in a Steel Edition. The result is a cost-effective welding system for steel applications with a pulse function. Every TPS/i can also be configured to be a “Steel Edition”.
The advantages of the TPS/i Steel Edition:
  • Cost-optimized for the steel market
  • Over 100 pulse and standard characteristics for steel applications
  • Steel characteristics with PCS characteristic
EN1090 certificate
WPS STEEL PACKAGE FOR EN 1090
The WPS Steel Package contains a number of welding procedure specifications that are also compatible with other MIG/MAG welding systems. The WPS has been certified in accordance with EN 15612 through the standard welding process.
Special features:
  • Steel qualities up to S460 can be welded
  • Plate thicknesses from 1-50 mm
  • Includes WPS for pipes and tubular constructions
For more information about the WPS Steel Package, please contact your local Fronius partner.
Contact a partner now
Let´s get connected!
THE RIGHT CHARACTERISTIC FOR EVERY APPLICATION
PCS - PULSE CONTROLLED SPRAY ARC
PCS combines the advantages of pulse and spray arcs in one characteristic. The PCS characteristic ensures that intermediate arcs are avoided. The result is a smooth transition from a pulsed arc to a spray arc, which reduces welding spatter. For this reason, PCS is most often used for small gaps, fillet welds and root passes.
The advantages of PCS:
  • Minimal joint preparation
  • High deposition rate
  • Higher welding speeds Less rework
Dynamic arc
Dynamic
Concentrated, dynamic arc for deep and narrow penetration. Higher welding speeds can also be achieved.
Root
Root
The powerful arc with good gap-bridging ability enables straightforward root passes – even when welding without moving the workpiece.
Universal
Universal
Simple, time-saving welding settings for standard steel welding applications, with an arc that can be easily controlled.
Welding
TPS/i - THE INTELLIGENT WELDING SYSTEM
Communication between man and machine is sure to be an important topic in the future and the reason why the TPS/i already stands out today. The latest optimizations have resulted in improved weld properties, more efficient handling and greater flexibility. The selection of different welding packages makes it all possible.
Find out more about the TPS/i
Welding machine
RECOMMENDED ACCESSORIES
EXENTO FUME EXTRACTION TORCH
Fume extraction torches and extraction sets eliminate welding fumes where they are produced. Welding fumes are detected before they are able to spread, which not only protects the welder, but also everyone in the vicinity.
To the Exento fume extraction torch
Dust filter
DUST FILTER
The dust filter offers addition protection against contaminants in the housing of the TPS/i – particularly in tough environmental conditions.
Torch
Jobmaster
The JobMaster welding torch means that the user always has the most important welding parameters (U, I, Vd) on the torch and can easily switch between them at any time.
To the MIG/MAG welding torches
Welding
SAFETY WHEN WELDING
Welders face a number of safety concerns during their day-to-day work. UV radiation and welding fumes can be a health hazard if there is insufficient protection. The right clothing and equipment are crucial in this regard.
More information about safety accessories
Welding helmet
SEND YOUR NON-BINDING REQUEST DIRECTLY TO FRONIUS
Let´s get connected.
    Find your nearest Fronius Service Partner
    Find your Fronius Service Partner now
