ダウンロード
製品
Easy entry into the world of digitalized welding
Our WeldCube Air cloud-based software solution brings transparency to welding operations and grants a clear overview of welding certificates and welding procedure specifications (WPS) at all times. It is a quick and straightforward way for companies to start benefiting from digitalization and helps with quality assurance and resource efficiency.
WeldCube Air can currently be purchased for all TPS/i and iWave models and will also be compatible with future digital Fronius series. Small and medium-sized companies in particular—and especially welding supervisors, production managers, and quality managers—are provided with a well-structured and particularly user-friendly tool.
No more paperwork and Excel lists
WeldCube Air helps you manage and update welding certificates and brings everything together in one place. The current qualification status of the welding specialists can be called up at any time, with the system automatically indicating expiring certificates so that they can be renewed in good time.
WPS-compliant welding
WeldCube Air helps you keep track of all the welding procedure specifications, update them, and ensure that they are applied correctly. Standard-compliant parameter sets (jobs) can also be prepared with ease and rolled out to the entire welding machine fleet at the click of a button.
Fit for the future thanks to data transparency
The platform also enables all intelligent Fronius welding machines to be managed centrally, such as by conveniently rolling out regular updates with a single click.
Just as conveniently, the software provides a clear overview of all relevant welding-related key figures for the past 30 days, making it easy to keep an eye on manufacturing productivity and identify areas for optimization. Time and material efficiency are particularly important in this respect, which is why it is worth taking a closer look at parameters like the average wire consumption or the arc switch-on time.
Easy to install, secure, and available anywhere
Thanks to innovative cloud technology, WeldCube Air does not require complex installation and is ready for immediate use. An overview of the welding performance of individual devices or the entire welding machine fleet is created in an instant—on whatever device you prefer, from a PC to a tablet or smartphone. We ensure certified security (ISO/IEC 27001) and protect the stored data in accordance with strict European data protection directives.
Find out more about WeldCube Air here!
Contact address
