Customer Solutions for Welding Automation Welding solutions that are impressively cost effective
Mechanized welding systems
Cell case, pipes, flanges with FCW Compact
Characteristics: Compact circular seam welding system with two welding heads, rotary unit and tailstock for various tasks, wide range of functions, user-friendly system controls and remote control.
Material:
  • Steel, CrNi, Al, duplex, nickel based
Welding processes:
  • MIG/MAG (CMT), TIG (cold & hot wire, ArcTig), plasma
Cylindrical components such as cell case shell rings with FCP seam welder
Characteristics: Longitudinal seam welding system for internal and external welding of cylindrical components with a large diameter in tank and cell case construction, welding carriage with accompanying wirefeeder, pneumatic clamping system, user-friendly system controls and remote control.
Material:
Welding processes:
  • MIG/MAG (CMT), TIG, plasma
Send a non-binding request
Robotic welding cells
Yellow roboter welds
Robotic welding cell in use at Anton Paar (Austria)
Challenge: Ongoing sales growth and a shortage of skilled workers made the switch from manual to automated welding a must, despite small batch sizes of 1 to 400 pieces. The requirements were: a high degree of system autonomy, flexibility in terms the number, shape and size of the components, in their positioning, and in the use of different welding processes.
Solution:
Handling-to-Welding robotic welding cell
Welding processes:
  • TIG
  • MIG/MAG (CMT, PMC)
Continue to Anton Paar’s reference
Housing, flange and root face connections with handling to welding weld cell
Characteristics: Robotic welding system for a wide range of tasks and components, which is cost effective even for small batch sizes. System controls with 3D real-time visualization, high level of welding autonomy and safety, welding data management.
Material:
  • Steel, CrNi, Al
Welding processes:
Learn more about HTW robotic welding cell
Housing connections with handling to welding weld cell
Characteristics: Robotic welding system for welding inverter housings made of sheet metal in varying thicknesses. System controls with 3D real-time visualization, high level of welding autonomy and safety, ERP interface, welding data management.
Material:
  • Al
Welding processes:
  • MIG/MAG (CMT Mix, PMC Ripple Drive)
Watch video about handling to welding
Flanges, frames and dished ends and various other components with FRW Compact
Characteristics: Compact robotic welding system for various components, cost effective from a batch size of one, user-friendly system controls with 3D real-time visualization, smart welding data management, high safety standard.
Material:
Welding processes:
Overlay welding
Overlay welding of valves with “Endless Torch Rotation System”
Characteristics: Overlay welding system with endless rotating welding torch for overlay welding of components with complex shapes such as bore to bore advanced, race track, ring groove, circle segments, flanges with bores, sphere sections and more.
Material:
  • Steel
Welding processes:
  • TIG (cold & hot wire, SpeedClad 2.0)
Learn more about cladding
Boiler & vessel connections with multi welding system
Characteristics: Welding system for overlay, longitudinal seam and circumferential welding of various components such as boilers, vessels, pipe extensions, pipes, pipe-flange connections or valves.
Material:
Welding processes:
  • MIG/MAG (CMT), TIG (cold & hot wire), ArcTig, SpeedClad 2.0), plasma
Let’s get connected.
