Gearing up for Industry 5.0 with new welding solutions
Application Story
4/10/2024
Viñolas Metall is a family business specializing in the construction of metal components, sheet metal processing, and boiler making. As part of their latest innovation measures, a CMT robotic welding cell was introduced in combination with a TPS 400i power source for the series production of identical parts. At the same time, the iWave Pro series—the new generation of Fronius multiprocess welding machines—is being used for certain applications.
Josep Viñolas founded Viñolas Metall in 1968 in Cornellà del Terri, Spain, and the company has been producing metal constructions for companies and private consumers ever since. Years later, his son David Viñolas joined the company and invested in new machinery and technologies for the export business and to optimize project workflows through computerization. A 4,000 m2 production site in Banyoles was recently opened to complement the existing 800 m2 assembly workshop in Cornellà del Terri. In addition, Viñolas Metall has been certified to ISO 3834-2 by the Fronius Welding Academy.
The company has a diverse range of customers from different industries, including winemaking, water treatment, swimming pool accessories, mechanical engineering, plant construction, toolmaking, power plant construction, and railway construction. Viñolas Metall is known for its innovative solutions, high quality of service, and efficient, customer-oriented project management.
Current situation and new challenges
Welding currently accounts for 70 to 80% of production times. Carbon steel, stainless steel (304, 316, duplex, and super duplex), aluminum, and COR-TEN® are the most common materials processed.
It is mainly smaller components that are joined, but also large and heavy components too. Sheet thicknesses range from 2 to 40 mm. Welding is carried out in the PA (flat position), PB (horizontal vertical position), and PC (horizontal position) positions. Out-of-position welding on vertical beams and pipes is performed in the PF (vertical up position) and PG (vertical down position) positions. The most frequently used processes are TIG and MIG/MAG for manual tasks, as well as the ArcTig keyhole welding process for automated applications. Orbital welding systems are also used, whereby the welding torch rotates around the component during joining.
As they specialize in technically demanding, complex metal structures, Viñolas Metall faced two new challenges. The first was finding a solution for creating high-quality, reproducible welds for series production where industry specifications and welding standards had to be taken into account. The components produced are exposed to high loads and used in a highly corrosive environment—for example, in plant construction.
The second requirement focused on welding autonomy and system optimization. The desired system should be able to switch between two welding processes (TIG and MIG/MAG) independently and without sacrificing the weld quality, all in the course of a quick process change.
The solution: Robotic welding cell with TPS 400i CMT
As a result of the good experiences Viñolas Metall has had with Fronius welding machines and processes, the company trusts in the professionalism and reliability of Fronius both from a technical and efficiency perspective.
“When we need to weld identical parts with the highest weld quality, we turn to Fronius, as they always have the solution we’re looking for,” says David Viñolas, managing director of Viñolas Metall.
One specific challenge for Viñolas is welding beams for swimming pool roofs from austenitic chrome-nickel steels 304 and 316. The welding solution consists of a robotic welding cell equipped with a TPS 400i CMT welding machine, a hollow arm welding robot, and a H reverser, which has two vertical turntables on a horizontal axis on both sides. Custom-made clamping devices are mounted between the turntables, each of which can accommodate four of the stainless steel beams.
Once one side of the H reverser is loaded with four steel beams, they are turned into the welding cell and joined in a single cycle. Meanwhile, on the other side, the finished welded components can be removed and four new ones positioned, saving valuable cycle time. As soon as the teaching of the system is complete, the sequence program together with axial movements is specified and the weld quality is ensured. The component handling itself can be carried out by trained operators who do not have to be experienced welding specialists—a particular advantage in times of skills shortages.
“We want our best welders to work on large projects with high added value, while smaller series parts can be welded with the robotic welding cell,” explains mechatronics engineer Matheus Borborema.
The Cold Metal Transfer (CMT) process used in the welding cell is characterized by its minimal heat input, which reduces the heat-affected zone and thus the deformation of the base material. At the same time, it impresses with its extremely high arc stability. CMT enables higher welding speeds with low spattering, minimizing uneconomical rework and costs for consumables.
Standardization with iWave Pro in robotic welding cells
Viñolas Metall has been placing its faith in Fronius since 2016, when the first TPS/i welding system for intelligent MIG/MAG welding was introduced. Recently the company has been facing a new challenge: the welding robot must weld various components using both the TIG and MIG/MAG process—with rapid process changes and programmed configurations. Welding quality and system stability must be kept constant throughout. The welding solution to meet this challenge is the iWave Pro AC/DC multiprocess welding machine from Fronius.
“The reliability of the equipment and service quality of technology partners are key factors for us,” emphasizes David Viñolas. “The Fronius support team fully supported us during the test phase of the new iWave Pro. We have now purchased four more devices.”
Viñolas plans to gradually replace all the old equipment, so that by 2025 all 15 welding cells will be equipped with the iWave Pro, and all the company’s welding machines will be Fronius devices. The main reason for purchasing the multiprocess welding machines is the fast process change. Overall, the iWave increases productivity, saves consumables, and requires less space. What’s more, production efficiency is increased because welding specialists can use the welding process immediately required—without wasting time switching between TIG and MIG/MAG.
On Viñolas Metall’s journey towards Industry 5.0, the iWave Pro stands out for its compatibility with WeldCube, the advanced Fronius welding data management and documentation software. Further advantages include the CycleTig and PMC (Pulse Multi Control) functions, which significantly contribute to the reduction in uneconomical rework. The optional DynamicWire Welding Package, enabling dynamic wirefeed during manual TIG welding, is another plus. The devices are robust and feature a long service life with low maintenance, significantly improving the ecological footprint. Their large digital color display is easy to use even with welding gloves.
From now on, Viñolas Metall’s demanding projects involving tanks and other components made of carbon steel, stainless steel, and aluminum for the aerospace, pharmaceutical, and food industries will be joined by hand with the iWave Pro AC/DC.
Benefits and opportunities
David Viñolas explains: “Fronius products are far more powerful and reliable than the devices we’ve used before. They’re robust and have been developed with the needs of welding professionals in mind. Since owning Fronius equipment, we have never had to stop production due to failures. The devices are very intuitive and easy to use, and the training offered allows us to make the most of what they can do.”
In addition, Viñolas points out: “We have been working with Fronius for many years because we trust the renowned technology company. Their sales team is very empathetic and professional. The fast, reliable, and solution-oriented service has shown us that we can rely on Fronius. We were looking for a company that would not only demonstrate to us the latest technology in welding, but also support us as we embarked on the process of technological transformation.”
Viñolas and Fronius: Past, present, and future
Since the application engineers at Viñolas Metall first tested a Fronius device and the decision was made to purchase, the business relationship has gradually grown. In the meantime, further systems have been acquired, including an ArcView camera system for visual weld pool control during robotic welding, an ArcTig keyhole welding system, and ten iWave and TPS/i welding machines.
Where the shared success story began with the introduction of a robotic welding cell, it has now moved forward thanks to the purchase of four iWave Pros.
Today, Viñolas Metall is convinced by Fronius at every level.
1. APPLICABILITY
2. PRICES AND PAYMENTS
5. GENERAL EXPRESS WARRANTIES
5.1 General. Seller warrants to Buyer only, subject to the disclaimers and limitations of the Agreement, that Goods to the extent manufactured by Seller shall be free from defects in materials and workmanship at the time of delivery which are discovered and reported to Seller within the period of 24 months from the delivery date. From the beginning of the 13th month of this period, however, Seller’s warranty shall be limited to making available, free of charge, the items needed for remedying the defects; from this time onwards, any warranty claims going beyond the above shall be inadmissible. This period limitation also applies to the supply of items deemed to be immovable and to work on items which are, or are deemed to be, immovable. The warranty period shall start to elapse upon the passage of risk. Buyer must always prove that defects coming to light during the warranty period were already present at the time of the passage of risk. This is not a warranty of performance, but a limited warranty as to the condition of the Goods at delivery. Seller does not warrant any portion of the Goods not designed, developed or manufactured by Seller (whether or not specified by Buyer), but Seller shall assign to Buyer upon request all assignable warranties of Seller’s suppliers related to such Goods. Because the Goods may be subject to a wide variety of use, installation, maintenance, cleaning, and other factors, the warranty is only against the named defects and not against any other defects or failures such as, but not limited to, those due to normal wear and tear, normal maintenance and unknown causes. Perishable and wear items are excluded from warranty against defects. Buyer shall ensure that all computer equipment and software included with or used with the Goods has adequate protection against viruses or other malicious software after initial installation. Seller’s warranty does not cover damage or contamination caused by such malicious software. Notwithstanding anything to the contrary, there is no warranty as to prototype Goods.
6. PATENT WARRANTIES
7.4 Warranty
9.1 General Remedies. Defective or non-conforming Goods or parts thereof discovered and reported during the express warranty period shall be repaired, or replaced by Seller without any additional charge, and shipped to Buyer, FOB Seller’s plant, for reinstallation by Buyer at its cost, subject to the terms hereof of the Agreement, as Buyer’s exclusive remedy. The warranty obligation of Seller is limited to the repair or replacement at Seller’s plant of any part of the Goods which Buyer shall, within the warranty period, return to Seller, with transportation charges prepaid by Buyer, and which Seller shall determine upon examination to be defective or not in conformity with the express warranties contained herein. Goods cannot be deemed defective or non-conforming if Seller cannot duplicate the alleged failure. In lieu of repair or replacement, if Seller elects, Seller may, upon return of such Goods and making a determination of nonconformity or defect, keep the Goods and refund the purchase price as Buyer’s exclusive remedy. Seller may provide such repairs itself or through its third party contractors. Buyer’s remedies shall be limited (even in the event of Seller’s default of its warranty obligations or a failure of an item to meet its intended purpose) exclusively to those provided in this Section. UNDER NO CIRCUMSTANCES SHALL SELLER BE LIABLE, REGARDLESS AS TO WHETHER SELLER’S LIABILITY ARISES UNDER CONTRACT, TORT, STRICT LIABILITY STATUTES, OR OTHERWISE, FOR EXEMPLARY, PUNITIVE, SPECIAL, CONSEQUENTIAL OR INCIDENTAL DAMAGES, INCLUDING BUT NOT LIMITED TO: LOSS PROFITS OR REVENUES; INCREASED COSTS; DAMAGE TO EQUIPMENT, TOOLING,PREMISES, OR WORK-IN-PROCESS; COST OF CAPITAL; COST OF PURCHASED POWER; SUBSTITUTE OR ADDITIONAL EQUIPMENT, FACILITIES OR SERVICES; COST OF PRODUCTION INTERRUPTION OR START-UP; OR THE CLAIMS OF THIRD PARTIES FOR SUCH DAMAGES, WHETHER OR NOT THE DAMAGES WERE FORESEEABLE OR SELLER WAS ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. Each provision of the Agreement which provides for a limitation of liability, disclaimer of warranties, or exclusion or limitation of damages or remedy is severable and independent of each other and to be enforced as such. Buyer waives any causes of action or theories of liability relating to or arising under the Agreement including, but not limited to, those arising under contract, tort, strict liability, product liability statutes, or otherwise, except as specifically provided by the UCC as modified and limited herein. The replacement or repair of Goods by Seller does not give rise to any new or extended warranty, and the warranty period provided for herein shall not be extended by the length of any period from the date the defective or non-conforming Goods are received by Seller until the date the repaired or replacement Goods are delivered to Buyer or otherwise.
10.1 SELLER DISCLAIMS ALL IMPLIED WARRANTIES AND SIMILAR OBLIGATIONS (OTHER THAN THAT THE GOODS WILL BE NEW AND GOOD TITLE) INCLUDING BUT NOT LIMITED TO THOSE OF NON-INFRINGEMENT, FITNESS FOR A PARTICULAR PURPOSE, AND MERCHANTABILITY, WHETHER OTHERWISE ARISING BY LAW, CUSTOM, USAGE, TRADE PRACTICE, COURSE OF DEALING, OR COURSE OF PERFORMANCE. There are no warranties which extend beyond those express warranties contained in the Agreement. Buyer affirms that it has not relied upon Seller’s skill nor judgment to select or furnish the Goods for any particular purpose beyond the specific express warranties in the Agreement. Any design provided by Seller is based on information provided by Buyer. Seller may rely entirely on information provided by Buyer and is under no obligation to verify such information or take any action to obtain explanatory or supplemental information from Buyer or third parties. Buyer’s approval of drawings and/or prototypes constitutes Buyer’s acceptance and waiver of any responsibility for a failure to consider or correct information or approval provided by Buyer. Any modifications of drawings, prototypes and other work of Seller after approval by Buyer shall be at Buyer’s expense at Seller’s normal rates for services and materials. Seller does not warrant the Goods will comply with the requirements of any safety or environmental code or regulation of any federal, state, municipality or other jurisdiction beyond the specific express warranties in the Agreement. Seller does not warrant that the Goods will operate with any accessories or within any system not sold under the Agreement and Seller’s warranty is limited to the operation of the Goods in a stand-alone mode, unless specifically stated in Seller’s written specifications. Some countries, states, or provinces do not allow the exclusion or limitation of implied warranties or the limitation of incidental or consequential damages for certain products supplied to consumers, or the limitation of liability for personal injury, so such limitations and exclusions may be limited in their application to an end user and others. When the implied warranties are not allowed to be excluded in their entirety, they will be limited to the duration of the applicable written warranty. The warranty gives specific legal rights which may vary depending on local law.
11. INDEMNIFICATION
12. SECURITY INTEREST
12.1 In addition to any security interest granted by the UCC or other law, Buyer hereby grants a security interest to Seller in all Goods and documents related thereto and proceeds and products therefrom to secure all obligations of Buyer to Seller, whether or not arising under the Agreement. Seller may file a financing statement and at Seller’s request, Buyer shall sign financing statements and other documents, which evidence perfect and confirm the security interest. Buyer grants Seller an irrevocable power of attorney to sign Buyer’s name to a financing statement or other similar documents if necessary or convenient to perfect Seller’s security interest. Buyer shall not change the name of Buyer, the jurisdiction of Buyer’s formation, or the location of any Goods from the original delivery point or installation site without prior written notice to Seller. Buyer shall provide a lien waiver or subordination from all third parties to whom the Goods may be delivered. Buyer shall provide a landlord’s waiver or subordination of any lien rights at the premises to which the Goods are to be installed. In case of a default by Buyer, Seller may peaceably enter the premises of Buyer and others and take other actions to repossess or render inoperable all Goods in which it has a security interest provided that Seller provides Buyer with immediate notice it has rendered the Goods inoperable. In case of a default by Buyer, Buyer hereby irrevocably appoints Seller as its agent to obtain possession of the Goods and documents related thereto. Seller may install and activate procedures or devices to make the Goods or Software non-operative upon Buyer’s default. The Goods shall be and remain strictly personal property whether or not affixed or attached on permanent foundation or affixed or attached to building or structure. Title shall not transfer to Buyer until the Goods shall be paid in full. Buyer shall maintain the Goods which constitute inventory in a segregated area and not comingle any Goods which are not fully paid. Buyer shall not sell, exchange, transfer, convey, mortgage, pledge, hypothecate or grant a security interest in any Goods which are subject to the Agreement until payment has been made in full to Seller, at which time title shall transfer to Buyer. Buyer shall immediately advise Seller in writing of any damage to, change in location of, or seizure of, any of the Goods the price of which has not been paid to Seller.
13. PROPRIETARY INFORMATION
13.2 Seller’s Rights to Confidentiality. All proposals, plans and other information furnished by Seller in bidding, negotiating and performing the Agreement, are confidential and the property of Seller, whether or not marked “Confidential”, and shall not be shown or disclosed to any other bidder, and shall not be shown or disclosed to any other third party or used by buyer unless necessary for the selection or use of the Goods and notice of such disclosure has been given to Seller. Buyer shall treat as confidential any quotation or other business proposal from Seller and all technology which shall be made available, directly or indirectly to Buyer by Seller and by Seller’s licensors, including but not limited to drawings, schematics, specifications, bills of material, test results, analysis, recommendations, models, and designs, and Buyer shall use such proposal and technology only to evaluate its business relationship with Seller and to enable Buyer to perform under the Agreement. Buyer shall not manufacture or sell any product using confidential information provided by Seller or obtained from reverse engineering or decompiling Goods of Seller. Buyer shall not disclose, or authorize or instruct any third party to disclose, any confidential or proprietary information of Seller to any third party that is not bound by contract to at least the same duty of confidentiality to Seller as is Buyer. In addition, only those employees and contractors of Buyer having a need-to-know and bound by contract by the same confidentiality provisions as Buyer may be given access to such technology. Buyer shall maintain, for Seller’s inspection, written records which shall include the names and address of such employees and contractors granted such access. Buyer shall indemnify Seller from all expenses and damages related to the improper use or disclosure by Buyer or its employees and contractors. Business proposals and technology of Seller may be protected by patent, copyright, trademark and other law. No license or other right to business proposals or technology is granted to Buyer except as specifically provided in the Agreement.
14. BREACH
15.1 Disclaimer. BUYER AND THIRD PARTIES SHALL NOT BE ENTITLED TO ANY CONSEQUENTIAL, PUNITIVE, LIQUIDATED, EXEMPLARY OR INCIDENTAL DAMAGES, AS DEFINED IN THE APPLICABLE LAW OR OTHERWISE, EXCEPT AS TO ANY INDEMNIFICATION OBLIGATIONS TO THIRD PARTIES SPECIFICALLY PROVIDED IN THIS AGREEMENT. “CONSEQUENTIAL DAMAGES” SHALL INCLUDE, BUT NOT BE LIMITED TO, LOSS OF PROFITS OR REVENUE, LOSS OF USE OF CONTRACT GOODS, COSTS OF REPLACEMENT POWER OR CONTRACT GOODS, ADDITIONAL EXPENSES INCURRED IN THE USE OF CONTRACT GOODS OR FACILITIES, OR THE CLAIMS OF THIRD PARTIES, EVEN IF SELLER HAS BEEN ADVISED OF POSSIBILITY OF SUCH DAMAGES OR IF THEY ARE OTHERWISE REASONABLY FORESEEABLE. THIS DISCLAIMER SHALL APPLY TO INCIDENTAL, CONSEQUENTIAL AND LIQUIDATED DAMAGES BASED UPON ANY CAUSE OF ACTION WHATSOEVER ASSERTED AGAINST SELLER, INCLUDING ONE ARISING OUT OF PRINCIPLES OF CONTRACT, ANY BREACH OF WARRANTY, EXPRESSED OR IMPLIED, GUARANTEE, EQUIPMENT OR OTHER CONTRACT GOODS LIABILITY, NEGLIGENCE, TORT, OR ANY OTHER CAUSE PERTAINING TO PERFORMANCE OR NON-PERFORMANCE TO THE PROPOSAL OR ORDER BY SELLER. This limitation shall be enforced regardless of whether Seller has defaulted in its warranty or other obligations or the limited warranty is held to fail of its essential purpose. Any legal inability to limit or restrict the right of Buyer or a third party to such damages shall not affect the right of Seller to indemnification here-under, and under no circumstance shall Buyer recover more than the purchase price. 15.2 Overall Limitation. IRREGARDLESS OF THE DISCLAIMER IN SUBSECTION 15.1 ABOVE, UNDER NO CIRCUMSTANCES SHALL SELLER’S LIABILITY FOR CLAIMS FOR NON-DELIVERY OR OTHER NON-PERFORMANCE, DEFECTIVE PERFORMANCE, NON-CONFORMING GOODS, DEFECTIVE GOODS OR OTHERWISE EXCEED THE AMOUNT RECEIVED OR TO BE RECEIVED BY SELLER FOR THE PERFORMANCE OR SHIPMENT WHICH CONTAINED THE NON-CONFORMING GOODS, DEFECTIVE GOODS OR SUCH OTHER EVENT GIVING RISE TO THE CLAIM, EXCEPT AS MAY BE SPECIFICALLY PROVIDED BY THESE GENERAL TERMS.
16. TERMINATION
17. SEVERABILITY
18. ASSIGNMENT
