Installers & partners
The Fronius Solar.creator Features Everyone Should Know About
Features
2/29/2024 / Austria
Free of charge but invaluable: The Fronius Solar.creator is a versatile tool which can be used to plan PV systems quickly and reliably. Three of the tool’s features are particularly beneficial for planners.
Check PV Design
For all those who want to play it safe (but don’t want to create a new project), “Check PV design” allows you to use all the popular features and advantages of our predecessor Solar.configurator. All it takes is a few clicks and you can tailor the PV system precisely to your individual requirements. The optimal number of PV modules is calculated based on the module and inverter data as well as the general characteristic values. This allows users to achieve the optimal design for their PV system, including a detailed wiring list for the inverter, which can be exported as a PDF file for further planning and documentation.
Watch the video to find out more
Manual Design
 “Manual design” gives you full control to conveniently edit the previously automatically generated result. From the selection of inverters to detailed settings, adjustments can be made to achieve the optimal configuration.
Custom Load Profiles
Fronius Solar.creator allows for individuality down to the last detail for optimal utilization. Users are able to create and import their own custom load profiles, with examples including slightly modified standard load profiles, as well as those for heat pumps and electric vehicles. This means that the design of the PV system can be optimally adapted to the expected individual energy consumption right from the planning phase. Another function that offers safety plus flexibility and helps users to optimize their PV system.
