Installers & partners
Fronius Wattpilot Designed to move.
The electric car charging solution that always provides the cheapest charging
Whether at home or on the move, with a PV system or not: the Fronius Wattpilot charges your customers' electric cars more flexibly and intelligently than ever before.
The Fronius Wattpilot comes in two versions and power categories:
  • Home – the fitted charger for use at home.
Power categories: 11 kW and 22 kW
Mounting: hanging upright indoors or outdoors, fitted
  • Go – the transportable solution for when you're on the road
Mounting: hanging upright indoors or outdoors, detachable and portable
Both versions offer sustainable charging with solar power or green electricity from the grid and help you and your customers to slow down climate change a little bit.
It's about e-mobility that drives us all forward. Fronius Wattpilot. Designed to move.
TWO CHARGING MODES FOR FLEXIBLE E-MOBILITY
Your customers can charge their vehicles to suit their needs. The Fronius Wattpilot offers two charging modes which can be selected directly on the electric car charger or via the Fronius Solar.wattpilot app:
Eco Mode
The preferred mode for PV system owners. It ensures that the vehicle is charged – if available – with self-generated solar power or the cheapest mains current.
Next Trip Mode
Next Trip Mode is for those who want to reliably charge their electric car to cover a specific journey – a certain number of kilometres – by a specific time. The Fronius Wattpilot reliably and intelligently charges the required amount. If available, surplus PV power from your own PV system is used or the cheapest mains current.
IT DOESN'T GET CHEAPER THAN THIS: CHARGE USING YOUR OWN SOLAR POWER
If your customers are PV system owners, they'll already be benefiting from the environmental and economic advantages of generating their own energy. As electric car owners, they can significantly increase their potential savings with the Fronius Wattpilot.
This electric car charger can make optimal use of any surplus energy from the PV system to sustainably charge the vehicle at virtually no cost.
The benefits: your customers save while they charge and make optimum use of their PV system so that it pays for itself faster.
• PV surplus     • Electric car
Dynamic Load Balancing for optimal power distribution
With Dynamic Load Balancing, the amount of self-generated solar power available from your customer’s own photovoltaic system as well as the maximum household load connected to the grid is optimally used: your customers can charge up to three electric cars at the same time and in an energy-optimised manner with one system. The energy produced by the photovoltaic system as well as the household consumption are taken into account. This not only saves high connection costs, but also effectively avoids load peaks. The energy required can be precisely controlled and therefore is dynamically distributed among the vehicles being charged.
SOLAR.WATTPILOT – THE APP FOR THE CHARGER
As flexible as the charging solution itself – your customers can control the Fronius Wattpilot with ease from their smartphones or tablets:
  • Easy commissioning of the Fronius Wattpilot
  • Clear display of all charging data
  • Select a charging mode anytime, anywhere
  • Change settings with just a click
  • Software updates made easy
Download now and discover flexible charging!
The Fronius Wattpilot The electric car charger for at home and on the road. Useful functions and features for your customers.
Quick selection The Eco and Next Trip modes can be selected directly on the device. The exact charging current can also be set by pressing and holding the button.
Residual current device Also protects against additional costs: Since the Fronius Wattpilot detects DC fault current immediately, no upstream type B RCD is required.
Security & control The Fronius Wattpilot can, if required, be secured with an approved RFID chip or card, protecting it against misuse and making it secure for use in public spaces.
Anti-theft protection The Fronius Wattpilot and the type 2 charging cable are valuable items that you should and can protect. The corresponding anti-theft protection is included in the scope of supply – a shackle as protection for the Wattpilot and the locking option for the type 2 charging cable.
Quick selection
Security & control
the fronius wattpilot in action
“Thanks to its fast and accurate control, the Wattpilot adapts perfectly to my PV generation. This means that no surplus energy is lost from the PV system.
The Wattpilot and GEN24 also interact exceptionally well.”
Franz Breitwieser,
Wattpilot user & product manager of GEN24
THE FRONIUS WATTPILOT AND SUSTAINABILITY
The Fronius Wattpilot is a key part of our product portfolio, enabling 24 hours of sun – for a world which is 100% based on renewable energy, without exception:
  • The Wattpilot electric car charger promotes emission-free mobility and helps to slow down climate change
  • With your own PV system and the Fronius Wattpilot, electric cars can be charged independently and sustainably
  • Adjustable modes enable particularly resource-conserving charging processes
WEBINAR: INTELLIGENT CHARGING WITH THE FRONIUS WATTPILOT & APP
By professionals for professionals. Find out everything you need to know about operating and configuring the Fronius Wattpilot with the Solar.wattpilot app. Our experts show you how to use the individual functions and charging modes step by step. You'll also get an insight into the range of functions on the app and the options for visualising and controlling the charging process. Watch the video
ALL VERSIONS OF THE FRONIUS WATTPILOT
  Wattpilot Go 11 J Wattpilot Go 22 J Wattpilot Home 11 J Wattpilot Home 22 J
Max. charging power  11 kW 22 kW 11 kW  22 kW
Dimensions
(l x w x h)
28,7 x 15,5 x 10,9 cm
Mains connection CEE16 plug red 5-pin / 30 cm
including neutral conductor
CEE32 plug red 5-pin / 30 cm
5-pin cable / 180 cm
Optional adapter sets CEE32 red fused,
CEE blue camping plug,
safety plug 16A
CEE16 red,
safety plug 16A
Network connection  WLAN
Residual current device 20 mA AC,
6 mA DC
Supply line cable
cross-section
Min. 2,5 mm² Min. 6 mm² Min. 2,5 mm²  Min. 6 mm²
FIND A SALES PARTNER AND GET A QUOTE
1. Applicability
2. Offers
6. Passage of risk
8. Warranty
11. Final provisions
12.1 Scope of use
12.3 Warranty
12.4 Compensation
