Fronius OhmpilotFAQ
Basics
The Fronius Ohmpilot is a consumption regulator designed to use excess solar power to heat water.
Thanks to the continuously adjustable regulation from 0 to 9 kW, surplus PV current can be put to highly efficient use and fed to the loads in the household.
The Fronius Ohmpilot is primarily used to intelligently control heating elements for providing hot water in boilers and buffer storage tanks, but can also be used for infrared heating or towel radiators. Solar power can thus provide a family home with average levels of water consumption with most of their hot water during spring and summer.
The result is maximum self-consumption, a reduction in the household’s CO2 emissions and less wear on the building’s main heating system during the summer months.
Installation & Start up
Features
Service
There can be several reasons, like not enough surplus energy being available. For troubleshooting, press the button on the Ohmpilot three times to activate boost mode.
If the Ohmpilot is still not heating, check the neutral wire connection, the temperature switch of the heating element and make sure you are using a compatible heating element.
If the Ohmpilot is heating during boost mode, but not during normal operation, check your maximum temperature settings and the communication between the Ohmpilot and the inverter.
