Step by step to the desired weld quality thanks to weld sequencing
4/4/2024
Error-free and efficient welding—our Fronius WeldCube Navigator makes it a breeze! Paired with WeldCube Navigator, both the TPS/i and iWave become perfectly coordinated weld sequencing systems. In combination with our Dual Wire Feeder, welding specialists can also access two different wire spools in no time. Those looking to experience the ease of use and quality of the results for themselves can use the trial version to test our new Navigator software obligation-free.
Faulty welded joints in the manufacturing process can result in massive costs. In this context, weld sequencing is an effective solution for quality assurance and a proven means of countering the shortage of skilled workers.
Digital welding sequence: here’s how it works
The WeldCube Navigator software shows the welder what to do next at the workstation. An extra screen displays each work step for a component in the correct sequence, and the welding parameters of the respective job are applied automatically. The worker is guided through their jobs step by step.
Keeping an eye on quality—and errors under control
If the worker deviates from the weld sequencing, the system will immediately flag it up. And if it detects a deviation (limit violation) in seams that have been defined as safety-relevant, welding cannot be continued until released by a welding supervisor, for example. This means that errors are not repeated or duplicated, but corrected immediately.
Try WeldCube Navigator for free
The best way to experience the advantages is by using it. With the option to try the software free of charge in combination with the trial license for our welding systems, there’s nothing stopping you from testing the system in conjunction with the TPS/i, the iWave, or the Dual Wire Feeder in your own company.
iWave and TPS/i users can download the WeldCube Navigator software here or via their myFronius portal.
Contact address
Mag. Heidemarie Haslbauer
+43 (664) 88293709
+43 (664) 88293709 unfyonhre.urvqrznevr@sebavhf.pbz
