Installateure & Partner
The quick and easy way to find the right inverter for every PV system
Products and Solutions
06-12-2021
The digital support tools from Fronius allow users to find the ideal inverter for any PV system quickly and easily, regardless of whether it's for a new project or an obsolete system. Users can choose from two convenient tools depending on their needs – the Fronius Solar.creator and the Fronius Repowering tool.
Optimal system design with the Solar.creator
There are many factors that play a crucial role when planning a new photovoltaic system. The user-friendly Fronius Solar.creator takes into account all the required planning steps, from choosing the location right through to the final report.
The online configurator not only helps the user with the comprehensive planning and design of PV systems, but also serves as an aid in meetings with customers. For example, the user can select predefined load profiles in order to take into account the customer’s consumption behavior in the calculations.
The customer receives a detailed report containing all the relevant information at a glance, such as a cost-effectiveness analysis and component overview.
The advantages of the Fronius Solar.creator at a glance:
  • Automatic suggestions for Fronius components
  • Simple export function for configurations
  • Detailed reports providing all the important info at a glance
  • One account – an unlimited number of projects
  • Connection to a weather database to determine insolation data and predict the yield
A return to full performance with Repowering
Fronius also has the ideal solution for older inverters that are no longer powerful enough in existing systems. In a few simple steps, the Online Repowering tool suggests the ideal device to be integrated into the existing system. Efficient Repowering quickly and easily enables the PV system to return to its full performance level and generate higher yields again.
Durable and robust
Fronius inverters are the ideal replacement for older models. In addition to making them quick and easy to install, the designers paid particular attention to their durability and robustness. The devices are subjected to countless quality tests to ensure they not only meet the high standards expected, but also exceed them. Other features, such as on-site PC board replacement, enable valuable resources to be saved.
The advantages of Repowering at a glance:
  • Full system performance
  • Increased service life of the PV system
  • Quick and easy configuration
  • Cost savings thanks to higher yields
