Five solar string inverter myths, debunked.
Myth #1. String inverters
can't handle shade
The design flexibility and
shade mitigation features of string inverters have changed drastically over the
last ten years. Intelligent software algorithms can track global maximum power
points dynamically, leading to higher performance of string inverters than
other inverter technologies.
Fact: String inverters outperform DC optimizers - even in a
system with shade, as found by the University of Southern Denmark in an independent study, read here.
Myth #2. A
string inverter system works like Christmas tree lights
It is a widespread belief
that string inverter systems operate like Christmas tree lights – one goes out,
and all stop working. The idea behind that belief is that a solar system only
produces as much electricity as its least productive module in a string. This is false.
Fact: If a module is being affected by shade, the bypass diode of the module activates and bypasses the affected sub-module. All the voltage of the first sub-module is lost, BUT current is maintained. All the other modules in the system are not affected at all.
Myth #3. String inverters
don't have good monitoring
Today's inverters are more
intelligent and connected and have data communications integrated into the
inverter, such as data loggers, interfaces between inverters, and internet connections.
This integration reduced complexity and component count as well as costs.
Fact: The inverters are connected to the internet via Wi-Fi, enabling cloud-based monitoring platforms for proactive notifications and online troubleshooting on MPPT-level, providing deep insight into the system.
Myth 4: String inverters
are not safe enough
String inverters have
integrated arc fault detection that detects and shuts off arcs in a system
before the arc can do any harm. This arc fault detection covers the whole DC
voltage range in a system, giving installers and system owners peace of mind.
Fact: Integrated arc fault detection and a small number of components and connection points significantly reduces the risks of arcing in the first place.
Myth 5: String inverters
do not last long
Since string inverter systems
do not require power electronics to be mounted on every module, there are fewer
potential failures.
Fact: String inverters are usually located in more protected
areas, such as a garage or on the side of the house, where they are less
exposed to weather extremes. And if something does go wrong, manufacturers
offer warranties for up to 20 years, and the inverters are easily accessible
for repairs if needed.
In conclusion, modern solar string inverters are efficient, safe and cost effective.
