Solar.configurator
Configure PV systems with ease
Correct configuration with the Solar.configurator
The Fronius Solar.configurator software helps you precisely size PV systems. This online tool withing solar.web calculates the ideal number of solar modules and how they are connected or the best type of inverter, no matter how complex the system.
Fronius also offers a PV-Genset Design service for customized design and optimal planning of your PV-Genset system. This service includes an analysis of the current situation and evaluation of the system with detailed simulations and design options.
Advantages of system sizing with the Solar.configurator
- Provides all the possible designs for each inverter type
- Latest data on solar modules, inverters, and compatible battery storage systems
- Flexible configuration of PV systems with multiple MPP trackers
- The number of parameters is limited to a minimum
- Standardized display on any device, be it a laptop, tablet, or smartphone
- Clear PDF report
Sizing made easy
With the Fronius Solar.configurator, correctly sizing even complex PV systems is a straightforward matter. The various configuration options and yield forecasts are quick and easy to obtain. Clear presentation and intuitive functions included!
Thanks to our open interface to other planning tools, complex systems can be precisely sized and perfectly planned. This means that all system data is entered only once, significantly reducing the planning effort.
With K2, Fronius offers such cross-tool planning. After planning the appropriate mounting system in the K2 Base software, all it takes is a click to transfer the entered project data to the Fronius online tool, where the system configuration is finalized with the latest module and inverter data. Specify the inverter, the module type, and, if necessary, a battery storage system, and the number of solar modules required and their required circuitry appears instantly. The clear report provides all design-relevant data on a single page.
Solar.configurator is embedded into Fronius solar.web for your convenience.
Webinar: Fronius Solar.configurator 4.0
System planning made easy! In this webinar you will learn how to implement the optimum system design quickly and efficiently with Fronius Solar.configurator 4.0.
