Fronius Wattpilot Flex
Future driven
Wattpilot Flex: Maximum efficiency for charging with solar power
For those who like to be ahead of the game, Fronius offers the perfect combination of elegant design and state-of-the-art technology with the Wattpilot Flex.
The Fronius EV charger uses every ray of sunshine from your PV system* to charge your car as efficiently as possible for the next day. Intelligent charging modes in combination with a variable electricity tariff enable cost-effective and efficient use of the solar power generated by your own PV system. Where necessary, the Wattpilot Flex draws additional power from the grid when the price is lower for maximum range. The ideal electric car charging station for your home—sustainable, flexible, and cost-efficient.
*Additional components are required for charging with surplus PV energy. All the details can be found in the operating instructions.
Maximum sun
Your energy, your e-mobility. With the Fronius Wattpilot Flex, you can charge your electric car very economically with self-generated solar power. The PV-optimized wallbox automatically switches between 1 and 3 phases to make the best possible use of the sun's power. From 1.38 to 11 or 22 kW (depending on the version), PV surplus is optimally used. No ray of sunshine is wasted.
Thanks to intelligent charging modes, you always have the choice: Eco Mode gives priority to solar power, while Next Trip Mode ensures that exactly the right amount of energy is charged at the right time for your next trip.
If you have a PV system, Fronius Wattpilot Flex gives you a double benefit: you save on charging and also increase your own consumption - which speeds up the amortization of your PV system.
Pure elegance
Experience a new level of charging your electric car - with the Fronius Wattpilot Flex.
This EV charger will impress you with its modern design and its outstanding functionality. The elegant look and high-quality finish make it a stylish addition to your home.
The Wattpilot Flex received the prestigious German Design Award 2025 for its excellent product design even before its official market launch.
The optional pedestal allows for easy and clean installation. It is robust, rust-resistant, and flexible in use. Perfect for one or two wall boxes.
Usability in perfection
The Fronius Wattpilot Flex offers a user-friendly interface with intuitive touch buttons and clear menu navigation.
Integrated WLAN and LAN interfaces allow easy integration into your home network.
The Solar.wattpilot app enables conveniently control and monitor the wallbox via smartphone or tablet - anytime, anywhere.
Thanks to RFID technology, you can manage different user profiles and always have full control over all charging processes.
Discover the highlights of the electric car charger for your home.
Charging precision
The Fronius Wattpilot Flex Pro is the ideal choice for your electric company car.
Thanks to the integrated, MID*-compliant electricity meter, your company car is being charged efficiently while the exact number of kilowatt hours charged are recorded for transparent billing with your employer.
The Fronius Wattpilot Flex Pro can be seamlessly integrated into existing energy systems and impresses with its modern, elegant design in anthracite that blends perfectly into any living environment.
Additional information for installers and commercial customers
Are you interested in a portable charging solution?
The Fronius Wattpilot Go is the portable charging station for use on the go. Thanks to the CEE plug, you can charge whenever and wherever there is a plug socket available.Technical data
| Data | Wattpilot Flex Home | Wattpilot Flex Pro** |
| Max. charging power | 11/22 kW | 11/22 kW |
| Dimensions (l x w x h) | 325 x 195 x 105 mm | 325 x 195 x 105 mm |
| Weight incl. type 2 cable | 4.1/5.4 kg (11/22 kW) | 4.1/5.4 kg (11/22 kW) |
| Charging cable | 6m cable with type 2 plug | 6m cable with type 2 plug |
| Cable entry | Cable entry from top (only permitted indoors), bottom, rear | Cable entry from top (only permitted indoors), bottom, rear |
| Network connection | LAN & WLAN | LAN & WLAN |
| MID meter | Not integrated | Integrated |
| Conformity with calibration law (Mess- und Eichrechtskonform) | No | Yes |
| Color | Telegrey 4 | Anthracite |
| Use* | Indoor & outdoor | Indoor & outdoor |
*When installing outdoors, the cable entry may only be used from below or behind. The charging power of the Wattpilot may be limited in direct sunlight.
