Innovation
Fronius Energy Profiling: smart analysis of electrical consumers
Would you like to visualise your heat pump, wind generator or other consumers using Fronius Solar.web?
With the new Fronius Energy Profiling, you can integrate external electrical consumers or generators into the Fronius Solar.web analysis software. These may be both a heat pump or an entire additional PV system, depending on which generators or consumers you are operating. Fronius Energy Profiling transforms intelligent energy flow management into a reality.
Fronius Energy Profiling – the convenient form of data analysis
Fronius Energy Profiling makes it possible to use several Smart Meters in a system and to visualise and evaluate their data individually using the Fronius Solar.web analysis tool. Various different curves and diagrams can be called upon to show how much energy each consumer requires or how much energy each generator produces.
How does this data help me?
The aim of Fronius Energy Profiling is to optimise energy usage by presenting the most important generation and consumption data. This visualization then allows you to take targeted measures towards ensuring the efficient usage of energy.
Which systems are compatible with Fronius Energy Profiling?
Fronius Energy Profiling is compatible with any PV system with a Fronius inverter. You will require an appropriate number of Fronius Smart Meters to match the number of consumers/generators you would like to be covered by the software. In addition, you will also need a Fronius Datamanager 2.0 for each system and access to Fronius Solar.web. The Fronius Datamanager 2.0 is integrated into every Fronius SnapINverter as standard.
Benefits of Fronius Energy Profiling:
  • Visualise different generators – even external ones. There is no need to switch between tools.
  • Display several different energy consumers and generators in Fronius Solar.web
  • Opportunity for analysis and identification of high-consumption appliances
Fronius Smart Meter
The smarter way to record your energy consumption!
