Fronius Additive Cell – Fronius combines additive manufacturing, software, and automation in a single package
The expectations being placed on modern manufacturing processes are constantly increasing. Shorter development cycles, maximum material efficiency, and cost-effective production of complex geometries are in greater demand than ever before. From aerospace and automotive to pressure vessels, rolling stock, and oil and gas, many industries require customized, tailored solutions and spare parts that are available quickly: in other words, the exact areas where additive manufacturing can truly shine. With metal 3D printing, components are created virtually out of thin air. Compared to conventional manufacturing processes such as casting, cutting, or milling, additive components keep material consumption and costs low. “WAAM enables decentralized, location-independent manufacturing without the need for complex production lines. Even irregular geometries can be built to the highest quality standards without wasting valuable material,” summarizes Manuel Stinglmayr, Business Development at Fronius International GmbH.
A stable welding process that enables uniform layer build-up is crucial for achieving the desired quality with the Directed Energy Deposition-Arc (DED-Arc) method. The CMT Additive PRO, which is based on the Cold Metal Transfer (CMT) process developed by Fronius, is particularly well-suited to additive manufacturing as a relatively cool dip transfer arc process that combines a higher deposition rate than other additive manufacturing methods with low heat input. The “CMT Additive PRO” welding characteristics are specifically tailored to the requirements of additive manufacturing, providing features such as a deposition rate stabilizer, Pulsed HotStart, CTWD measurement, and power correction to ensure the necessary process stability. “The CMT Additive PRO guarantees uniform and, above all, predictable layer build-up across the entire component. This drastically reduces scrap rates as well as the workload required for any rework,” emphasizes Manuel Stinglmayr.
Fronius Additive Cell—flexibility for custom welding solutions
For many companies, additive manufacturing presents numerous challenges. Compared to traditional manufacturing techniques, however, material waste is significantly lower, and neither complex molds and tools nor long lead times are required. Thanks in particular to the new Fronius Additive Cell, production of the first components can begin quickly. The Fronius Additive Cell is a perfectly coordinated complete system developed by Fronius to meet the needs of industry. Inside the welding cell, the CMT Additive PRO and Fronius iWave ensure a precise welding process while the Polaris system remains in overall control. “The Additive Cell combines proven welding technology, intelligent control, and Fronius’s many years of welding expertise. Every component has been designed to complement the other, resulting in a stable manufacturing process,” says Anna Dieplinger, Key Product Manager Additive Manufacturing, Automation & Digital Solutions at Fronius International GmbH. The Fronius Additive Cell includes not only the hardware but also our proprietary software bundle Vectris, which brings together the machine tool service kit (MTSK) and the post-processor on a single central platform. Developed by a highly experienced team of Fronius specialists, the software is designed specifically for additive manufacturing with the Fronius Additive Cell. In addition to an integrated kinematic model, an adapted user interface, and validated welding operations for additive processes, it also supports geometry-based detection of different component regions. This allows for flexible process parameters, such as different settings for outer walls, panels, infills, or component joints. Thanks to the “FroArc” welding command integrated into the post-processor, these so-called “build styles” are translated directly into code for the welding robot, and the system switches to the correct welding parameters at the exact desired location without delay. Fronius’s integrated system, consisting of a welding machine and software, ensures a simple, stable, and reliable welding process.
360° service for additive manufacturing
The applications for the Fronius Additive Cell and WAAM in general are diverse, ranging from reverse engineering and optimization of existing components to completely new designs. While reverse engineering is particularly useful for repairs when original parts are no longer available or the CAD data has been lost, designing new components permits optimized geometries. Both contribute to greater manufacturing efficiency and cost-effectiveness over the long term. To help customers with these requirements and more, Fronius offers a comprehensive package of consultation, feasibility studies, process development, and production services at our Prototyping and Manufacturing Center. We can also develop, test, and certify the optimal welding and pressure parameters for the respective welding materials. These ready-made and validated “recipes” can be licensed directly to you, allowing you to start production without delay. As part of our comprehensive 360° service offering, Fronius also handles the full process engineering for additive manufacturing projects upon request. Customers benefit from our expert knowledge, state-of-the-art development capabilities, and thoroughly tested solutions, all without having to take on any risk themselves.
Technological expertise as a key to success
With decades of experience in welding technology, Fronius enjoys a unique foundation for additive manufacturing in the industrial sector. The ongoing development of CMT, combined with comprehensive application and process expertise, makes Fronius a strong partner for a wide range of additive manufacturing applications.
Would you like to learn more about the new Fronius Additive Cell and our metal 3D printing services? Our experts will be at Formnext in Frankfurt am Main from November 17 to 20, 2026 (Booth B59, Hall 12) to present the Fronius Additive product and service portfolio and would be happy to meet with you in person.
You can find out more about Fronius Additive here: www.fronius.com/fronius-additive
