Manual MIG/MAG welding—stable, precise, powerful
Fronius Fortis and TPS/i
The right welding solution
for every challenge
Every welding job is unique. Materials, requirements, and processes can vary from one project to another: so you need solutions that are flexible and deliver reliable results.
Whether on steel or aluminium, the manual Fronius MIG/MAG welding systems redefine industry standards. With Fortis and TPS/i, you are opting for technologies that increase your productivity, reduce errors, and ensure consistent quality.
Both series impress with their modern process control, intuitive operation, and maximum arc stability.
Fortis: As flexible as your work
With up to 240 optimised characteristics that have been specially developed for the requirements of steel construction, the Fortis series impresses with its reliable welding performance. In addition to steel, the MIG/MAG welding machine also masters materials such as aluminium and stainless steel effortlessly, especially in combination with the pulsed arc.
More about Fortis
TPS/i: Equipped for the challenges of tomorrow
The TPS/i is one of the most modern welding machines on the market and offers a high output of up to 600 A for steel, stainless steel, and aluminium applications. System components are automatically recognised and seamlessly integrated for manual as well as robotic applications.
The clear touch display makes operation easier and shows all settings clearly.
With regular software updates, upgradable welding packages, and high safety standards, the TPS/i is designed to be a reliable long-term companion.
More about TPS/i
Operating concepts at a glance
The Fortis menu navigation with welding parameter wizard and the TPS/i user interface both ensure clearly structured and intuitive operation. While the Fortis wizard guides welders through the most important settings, the TPS/i allows particularly fast access to in-depth process details through its modern touch interface. Both systems efficiently help welders to configure, control, and optimise the welding process, depending on the respective welding machine.
Manuelles MIG/MAG-Schweißen
Lightweight, versatile, ergonomic
Particularly lightweight and user-friendly generation of more than 60 welding torch variants available in different versions:
– Gas-cooled or water-cooled
– Standard or Up/Down operation with LED
– Different lengths (3.5 m, 4.5 m, and 6 m)
To the MIG/MAG welding torches
Products
Fortis
– MIG/MAG welding up to 500 A
– Compact, split, or duo versions available
– Standard, Pulse, and Standard/Pulse Mix
– Simple operation using welding parameter wizard
– Multi-process welding (MIG/MAG, TIG, MMA/Stick)
– Full connectivity
TPS/i
– MIG/MAG welding up to 600 A
– Compact, split, or with Dual Wire Feeder
– Intuitive operation via touchscreen
– Penetration and arc length stabilisers for high weld seam quality
– Maximum flexibility through expandable software packages
– Full connectivity
Let’s get connected.
