Primo SnapINverter
for Residential Solar
The inverter generation for maximum safety, reliability & ROI
The Fronius Primo inverters are ideal for homes.
With their easy installation, high reliability, and innovative feature set, the Primo inverters provide maximum safety, reliability, and highest energy yield even on complex roofs of shaded systems – giving customers the best return on their solar investment. Power categories from 3.8 kW to 15.0 kW cover a wide range of singlephase applications and make the Primo the best choice.
Easy installation & fast service
The SnapINverter technology makes for safe and easy installation of the inverters. This innovative mounting system allows for inverter installation in 15 minutes or less.
Fronius Primo inverters are incredibly easy to service and ready for pro-active service solutions. Thanks to the inverter’s field-serviceability, reliability and low component count, Fronius Solutions Partners can solve most service issues with just one truck roll to the site. This means minimum time and cost for you and maximum yield for system owners.
- SnapIN mounting system for fast installation
- Quick and secure installation & servicing
- High reliability and field-serviceability for less truck rolls
No roof left behind: design flexibility & shade mitigation
Fronius SuperFlex Design gives you the ability to choose the right inverter for any application, from small single phase residential systems to large three phase commercial systems, from multiple roof angles to specific module counts for carports and trackers – Fronius has you covered. Once you have learned how to design with one Fronius inverter, the rest of the product line will be intuitive thanks to a similar design philosophy.
With Fronius SuperFlex Design, you can design systems from incredibly low start-up voltages (as low as 80V or three modules) all the way up to the maximum DC voltage allowed by the code. The large Primo inverters, from 10 to 15 kW, allow for 1,000V applications, which is an attractive option for systems on non-dwellings.
Multiple power point trackers (MPPT) allow for different module orientations or tilts, no matter if it’s a simple east/west design with two symmetric arrays, an asymmetric design with a small sub-array, or a partly shaded system. Simply split the system among the independent trackers as needed, from a 50/50 split all the way to a 33/66 split.
The Fronius Primo line comes with a smart shade mitigation feature: The Fronius Dynamic Peak Manager (DPM) is an enhanced MPP tracking software that scans the entire I-V curve when searching for the optimal operating point. Usually, a MPP tracker starts looking for the maximum power point at a high voltage, because that’s where usually the peak of the curve lies. However, in a shaded array, the curve turns into an S-shape, where the peak at a high voltage is no longer the maximum power point across the entire curve.
By checking the entire characteristic curve on a regular basis, the DPM finds the global Maximum Power Point (GMPP) for partially shaded arrays. As with many other technologies, software is replacing clunky hardware with smarter and more integrated solutions.
Flexible expansion thanks to open interfaces
The inverters have numerous integrated open interfaces for easy connection of third-party components.
There are many possibilities, ranging from a meter connection for dynamic feed-in control to integration into home automation systems. So you are prepared for tomorrow’s requirements today.
- Easy connection of third-party components
- Future-proof as standard - equipped for every requirement
- Storage ready - monitor energy profiles today, AC-couple tailor-fit storage later
Features at a glance
The Fronius Primo in action
„We‘re so pleased with the ease of installation and quality Fronius brings to the table for our projects so the Fronius Primo was a straightforward choice for this residential system.“
Chris Spencer, SunKing
Technical data
| Technical data | Primo |
| Power category | 3.8 - 15.0 kW |
| Phases | 1-phase |
| MPP tracker | 2 |
Get in touch with Fronius!
- Business & technical sales advice: pv-sales-usa@fronius.com
- Place an order: pv-order-usa@fronius.com
- Get technical support: pv-support-usa@fronius.com
- Call: (877) 376-6487
