INSTALLERS & PARTNERS
Repowering for PV-Systems make a fresh start
Returning to Maximum Performance with Repowering for Photovoltaic Systems
At some point, even the best photovoltaic systems start to show their age. However, through efficient repowering, you can quickly and easily restore your photovoltaic systems back to full power. Fronius inverters are the ideal replacement for older devices that are no longer operating at full capacity. They are easy to install and significantly increase the yield and service life of photovoltaic systems. With our new, user-friendly repowering tool, you can find out which devices are powering your customers’ existing photovoltaic system to full capacity. This allows you to quickly and easily replace the inverter.
Modernizing your Photovoltaic System
When you choose our Fronius inverters, you are at the cutting edge of technology: The devices feature open interfaces and are therefore equipped for new requirements, such as modern energy management, adding an accumulator or setting up an e-mobility infrastructure. Monitoring that is both user-friendly and free of charge greatly simplifies maintenance and ensures that the photovoltaic system can always be monitored accurately.
Products with a Particularly Long Service Life
We make sure that our products are extremely durable and subject them to countless quality tests to continuously check our high standards are being met and exceeded. The quality of our products and components is a top priority right from the outset in the product development phase: The Active Cooling feature, for example, ensures that the power electronics do not overheat even in extremely hot environments.
However, should a component fail to run smoothly, a power or PC board replacement can be carried out on site. By simply replacing the power electronics and not the entire inverter, you save not only resources, but also time and travel costs.
Many Years of Quality & Stability
As a technology leader with many years of experience and a high level of expertise, we can support you and your customers with bespoke solutions. It is not only our products that stand for reliability; as an Austrian family-owned company, we have been your trusted partner for 75 years and will continue to provide support wherever it is needed.
The Right Inverter for Your Photovoltaic System
Try our new, user-friendly repowering tool NOW. This will show you in just a few steps which Fronius inverters will upgrade your customers’ existing photovoltaic system.  The tool is free of charge and works on any device, be it smartphone, tablet, or PC. If you have any questions about the tool, please contact our support team.
Go to Tool
The country currently selected is South Africa. Would you like to stay on this page or do you want to switch to the local website?
