25/05/2021
Prodotti e soluzioni
Configure even complex roofs with PV modules – SuperFlex Design makes this possible
The new GEN24 Plus
impresses with maximum flexibility in PV system design. In addition to two
Maximum Power Point trackers, the inverter also has a separate battery input. The
high current carrying capacity of the MPP trackers and the wide input voltage
range of the inverter enable both a parallel connection on one MPP tracker and
the configuration of smaller, complex module areas.
