Switch between different filler wires directly on the welding torch
The dual wirefeeder is the perfect partner for the Fronius TPS/i or the Fronius iWave and can supply each process line with gas separately. The WF 25i Dual wire feeder standard packages support wire spools from 8" (S200) up to 14" (S350) and with an adapter can accommodate wire coils up to 17.7" (B450) also referred to as 60lb coils. Speaking of which, TPS/i users will have reason to celebrate as of July 2023 when a free software upgrade will revolutionize operating convenience and enable the required device settings to be made in just a few clicks. But first, more about the many advantages of the new WF 25i Dual:
A solution for numerous manual welding requirements
The dual wirefeeder can be used for many practical applications. For example, if you need to switch from a thin wire for tacking to a thicker wire for fill passes, or if a component calls for two filler wire materials such as steel and flux core wire. It has never been so easy to raise flexibility and productivity during manual welding. Notable areas of application are construction machinery and pipeline construction, as well as the automotive industry and its suppliers.
Switch process line with the torch trigger
The carefully thought-out operating concept behind the WF 25i Dual enables welders to switch the process line, filler wire, and associated parameters in a number of ways. For exceptional convenience, just reach for the second welding torch and start the process line directly with the torch trigger. There’s no need to walk to the wirefeeder anymore. Of course, selection can still be made at the wirefeeder or directly on the welding system display with the touch of a button. Or the RC Panel can be used—this is positioned near the welder so the required process line can be activated there. This is an ideal choice for particularly long hosepacks for systems mounted on a crane or Trabant.
