MIG/MAG Welding Torches
For Manual Welding Applications
The right welding torch for every application
From difficult to access components to remote job sites, welding torches from Fronius are designed to cover an extremely broad range of applications. Hosepacks up to 15 meters long and torch bodies of different lengths and angles make life easier for every welder, not to mention the remote control in the handle on certain models. Welders can count on the flexibility they need with Fronius – guaranteed.
The benefits
Long wearing part lifetimes
Each wearing part is designed and manufactured to deliver the longest service life and for optimal heat dissipation. For example, a high-quality copper alloy (CuCrZr) is used for the contact tips in order to extend their service life.
Long service life
Top-quality components maximize the service life of the welding torch. Outer tubes for the torch body made from stainless steel, high-quality hosepack components, power cables with maximum flexibility and a larger-dimensioned copper cross-section all ensure longer-lasting welding tools.
Repairable
Despite the long service life of Fronius welding torches, faulty parts can be easily swapped out and repaired. A comprehensive range of roughly 40 replaceable spare parts on water-cooled manual welding torches allows sustainable management of your equipment pool.
Flexible
The MultiLock System leaves you with a wide choice of over 80 different torch bodies of different lengths and angles, affording the welder even greater flexibility. Torch bodies can also be produced to customer-specific requirements at lengths of up to 1.2 m and angles from 0-90°.
    Technology & ergonomics
    Video: Technology and ergonomics
    Optimized for professional use
    Fronius welding torches represent the perfect symbiotic relationship between technology and ergonomics. The ergonomic handle with anti-slip components lies comfortably and securely in the hand, allowing the torch to be guided with ease. The ball joint and optimal weight distribution prevent fatigue during welding.
    JobMaster: Everything is under control
    With JobMaster welding torches, the welder can use the remote control with color display integrated in the handle to get a quick overview of important welding parameters such as welding power, wire speed, and previously stored jobs, and can adjust them to the desired value.
    Highlights & options - Technology & ergonomics
    Exceptional accessibility
    Video: Accessibility
    The right solution for every application
    With a range of more than 80 different torch bodies available, the perfect combination of angle and length can be selected for components with challenging geometries. In addition, individual solutions are possible to meet customer-specific requirements.
    MultiLock - Patented interface
    The MultiLock system enables the torch body to be changed quickly without having to replace the entire hose package. This enables flexible adaptation to the respective welding challenge.
    • 360° | The torch body can be turned through 360° to permit the greatestpossible welding flexibility on components with challenging geometries.
    • 0°| The 0° position is fixed by an antitwist device.
    • Integrated water stop | Prevents water from escaping when the torch body is removed.
    Highlights & options - Exceptional accessibility
    Perfectly cooled
    Video: Cooling
    Cost efficient through robustness
    The gas-cooled MIG / MAG welding torches get the most out of any application. Perfect cooling can also maximize the service life of  components and thus improve cost efficiency.
    Water cooling system
    On water-cooled systems the cooling system has been brought forward and outward as far as possible. The shape of the contact tip means that less radiant heat is now absorbed. This alone brings a temperature reduction of up to 70 °C for the wearing parts.
    More about water-cooled welding torches
    Welding fume extraction
    Video: Welding fume extraction
    Optimal protection for health and work environment
    Welding fumes can be harmful to health, which is why Fronius believes in extracting the welding fumes directly at the point of origin – the welding torch. Thanks to fume extraction torches, the welder and their wider working environment are effectively protected against harmful emissions.
    Exento extraction kit
    • Compatible with every Fronius MIG/MAG welding torch – including the PushPull variants
    • Special geometry of the extraction nozzle for optimal fume capture without affecting the gas shield
    • Up/Down and JobMaster possible
    • Continuously adjustable extraction nozzle
    • LED light function may still be used, depending on the position of the extraction duct
    More about Exento extraction kit
    Exento fume extraction torch
    • Five different power categories: 3x air-cooled and 2x water-cooled
    • Extraction capacity controlled directly on the handle
    • Four different user interfaces available:Up/Down, JobMaster, potentiometer, top torch trigger
    • LED light for welding in dark environments as well as for quality control
    • 1.3 m leather protection tube directly on the handle for perfect protection against high temperatures and welding spatter
    • Quick tester of the extraction capacity directly at the suction nozzle
    More about Exento fume extraction torch
    High precision: PullMIG welding torch
    At a working height of 1 meter, the PullMig welding torch weighs just 1.6 kg and is therefore 30% lighter than comparable models. Its compact design means there is barely any size difference to conventional welding torches. The PullMig is a favorite for aluminum applications and where long hosepacks is required (up to 15 m) – situations in which a reliable and precise wirefeed is essential.
    For the CMT welding process Fronius specially developed the PullMig CMT welding torch with a highly dynamic drive motor.
    1 / 4
    MTG 320i PullMig welding torch
    PullMig drive unit
    LED-lighting
    High compatibility with third-party devices
    Video: Compatibility
    FSC - One connection for all media
    The Fronius System Connector (FSC) serves as a central connection for all media. This ensures the hose pack to be connected easily and safely to the wire feeder in less than 10 seconds - without tools. For welding equipment from other manufacturers, 4 different central connection variants (suitable for Euro, Lincoln, Miller, Hobart) are  offered to guarantee the highest possible compatibility. For this purpose standalone hose packs with corresponding connectors or adapters for existing hose packs are offered. You can get more detailed information from our sales consultants.
    Latest Fronius Torches
    MTG
    • The welding torches in the MTG product family are gas-cooled MIG/MAG manual welding torches with an output of up to 530 A. The ergonomically shaped grip, a ball joint and optimum weight distribution allow for effortless operation. Their robust design makes the welding torches reliable partners for all applications.
    MTW
    • The welding torches in the MTW product family are water-cooled MIG/MAG manual welding torches with an output of up to 700 A. The ergonomically shaped grip, a ball joint and optimum weight distribution allow for effortless operation. Their robust design makes the welding torches reliable partners for all applications.
    PullMig
    • The PullMig welding torch from Fronius weighs only around a third as much as comparable models. The design is so compact that there is hardly any noticeable difference in size from conventional, manual welding torches – yet the torch delivers unrivalled precision. The Multilock torch body, which can be rotated through 360°, serves as the base of the torch, with a stainless steel outer pipe and integrated water stop in the hosepack.
    1 / 3
    Let's get connected.
    Welding Wiki
    The encyclopedia about welding
    The aim of the wiki is to gather all relevant information and terms on welding in one place and share it with all those interested in welding technology.
