Fronius WattpilotFAQ
Basics
The Fronius Wattpilot is the intelligent charging solution for all electric car owners.
The Wattpilot is available in two variants – the permanently mounted Wattpilot Home for the household (in an 11 kW variant) and the mobile Wattpilot Go for on the move (in 11 and 22 kW variants).
The device can be operated using the associated Solar.wattpilot app, which also provides an overview of the charging process at the same time. The intelligent plug and play charging solution has two different charging modes called Eco Mode and Next Trip Mode.
What’s more, the Wattpilot is PV-optimised, meaning that the car can be charged particularly cost-effectively and sustainably via automatic 1-/3-phase switching from 1.38 to 22 kW in ampere increments of surplus solar energy.
Downloads & Links
Installation and start-up
The combination with a Fronius Ohmpilot and a Fronius compatible DC-coupled battery is also possible.
The Wattpilot can also be operated with other inverters / energy sources in combination with a Datamanager Box 2.0 and Fronius Smart Meter at the feed-in point. However, no other selfconsumption controls (battery, Power2Heat, etc.) may be implemented in parallel, because the controllers can interfere with each other. The loads in the household are not taken into account in the display in the Solar.wattpilot app.
Features
As it stands, there is still no standard for intelligent charging. For this reason, there may be limitations with cost-optimized charging for certain models of car. Fronius endeavours to configure the optimal charging behaviour for every vehicle.The following models of car are affected:
- Renault Zoe
- Twingo
- Kia e-Soul
- Mitsubishi i-MiEV
- Citroen C-Zero
- Peugeot iOn
- VW ID.3 / ID.4 (Due to the charging behaviour, charging must not be interrupted)
The selection of the car model can be found in the Solar.wattpilot app in Settings - Cost optimisation - Car.
All settings can also be set locally, directly by connecting to the Wattpilot’s hot spot. This is permanently open and secured with a password.The following functions are not possible without a network connection:
- Remote app access via the internet
- Coupling with the PV system (PV-optimised charging)
- Use of flexible electricity tariffs
- Software updates
This means charging increments of approx. 230 W (1-phase) or approx. 690 W (3-phase) are possible. The advantage is that the power range of the photovoltaic system can be used at optimum efficiency (charging power of 1.38 kW - 22 kW). Switching works on vehicles that have a 3-phase or 2-phase on-board charger.
App
Service
- Check your Solar.wattpilot app under Settings - Cost optimization - Car - Choose path switch.
- Make sure your charging cable and your car's on-board charger support three-phase charging.
- Check the car's app for relevant settings that might limit the charging to one phase.
Solar.web
If you have not yet created a PV system in Solar.web, register on www.solarweb.com and add your Wattpilot and paired inverter when creating the new PV system. When adding the Wattpilot to Solar.web we recommend that the Wattpilot currently has internet connection and is paired with the inverter. Nevertheless it is also possible to add an offline Wattpilot to Solar.web, but Wattpilot data will first be shown, when the Wattpilot is online and paired.
For Wattpilot data to be displayed in Solar.web, ensure the following:
- The Wattpilot (as well as your inverter) must be added to your PV system in Solar.web in the tab "Settings" - "Components". If this tab is not visible, please ask your installer to assign you "Owner" or "Supervisor" rights for your PV system.
- Both the Wattpilot and the paired inverter must be connected to the internet.The Wattpilot requires firmware version 36.0 or higher.
- You can update your Wattpilot in the Solar.wattpilot app in the tab "Internet".
- The Wattpilot needs to be paired with your inverter. Go to the tab "Settings" - "Cost Optimization" in the Solar.wattpilot app to pair your Wattpilot with an inverter.
- If the paired inverter is a GEN24 or Tauro, firmware version 1.12 or higher is required. You can update your inverter in Solar.web in the tab "Settings" - "Components".
If the Wattpilot has no internet connection (e.g. due to weak WLAN), live and history data is not available in Solar.web. History data will not be restored when the Wattpilot reconnects to the internet.
Furthermore, Wattpilot data is only shown if the Wattpilot is paired with an inverter of the same PV system in Solar.web. For example, no data is displayed in Solar.web for periods when the Wattpilot Go is used on the go.
