Products
Fronius iWave and Fronius iWave Multiprocess PRO now in robot and automated applications
Excellent weld appearance, targeted heat input, reproducible ignition—these are just a few of the advantages that make our iWave stand out when used in robot applications or as the core element in automation systems. The all-rounder is now available in power categories 300i, 400i, and 500i, each as a DC or AC/DC variant, and with water or gas cooling as required.
Air gap bridging of up to 30% thanks to automatically controlled wire speed
With the machine complemented by the TIG DynamicWire dynamic wire feeding system, the wire feed speed is automatically adjusted to the current conditions during welding. The wire is always supplied in the exact quantity required, enabling compensation of air gaps up to 30% relative to the material thickness.
Furthermore, TIG DynamicWire supports the process of setting the optimum welding parameters. Defining one parameter—such as the welding current—is the only thing you need to do, and all other values are added based on material-specific characteristics.
Multiprocess PRO—Equipped for the challenges of tomorrow
Why choose between high-end TIG and high-end MIG/MAG when you can have both! Flexible and adaptable, our iWave Multiprocess PRO is the go-to 2-in-1 welding solution, with a selection of modular welding packages including Pulse, PMC, LSC, CMT, PMC AC, and CMT AC. It even has the perfect characteristic for additive manufacturing.
Switch between TIG and MIG/MAG in a single step
Equipped with suitable peripheral components, such as a welding torch and wirefeeder, a single high-tech welding machine becomes a universal all-rounder while taking up only minimal space.
Full connectivity, security, and transparency
As you would expect, the iWave is fully compatible with the most commonly used communication standards, e.g., WLAN, Bluetooth, and Ethernet, and meets the highest requirements when it comes to cybersecurity.
Contact address
