Welding in the food and beverage industry
Pulling out all the stops against germs and bacteria
Welding in this sector is all about hygiene
Germs and bacteria have no business being present in the food industry. For this reason, surfaces and welded joints must be as smooth and as flat as possible. Weld seams that come into contact with liquids must always be ground flush. In addition, container walls and pipes must not exhibit any spatter or temper coloration after welding. Industry and regional or international standards are authoritative.
Mechanized welding in container construction
Typical seam connections
Longitudinal seam welding systems
For welding container shells
FCP 2100-2 Seam welder
FCP 2100-2 seam welder with intuitive HMI system controls, TIG, ArcTig, Plasma
FCP 6100-2S Seam welder
FCP 6100-2S seam welder with intuitive HMI system controls, TIG, ArcTig, Plasma
Circumferential welding systems
Circumferential welding system for joining container shells in flat position (PA)
Intuitive HMI system controls, remote control, and ArcView camera system for monitoring the weld seam.
Welding processes: TIG, ArcTig, Plasma
Circumferential welding system for joining container shells in horizontal-vertical position (PC)
Circumferential welding systems for joining container shells and container bases
Fcw compact welding system
Robust welding system with intuitive HMI system controls and remote control. Ideal for small and medium-sized businesses.
FCW 650 Circumferential welding system
Mobile welding system incl. FCU-20 system controls. Ideal for small and medium-sized businesses.
Circumferential welding systems for welding different components, e.g., agitator mixer
FMW Multi welding system
Welding system for circumferential and longitudinal seam welding of different components. Intuitive HMI system controls, remote control, and ArcView camera system for monitoring the weld seam.
Welding processes: TIG, plasma
Agitator for cheesemaking
Let's get connected!
Manual welding in container construction
Typical applications
Welding systems
For manual welding in container construction
Mechanized welding in pipeline construction
Orbital welding systems
Mechanized orbital welding systems for joining pipes and flanges
FCH closed orbital welding heads
FOH open orbital welding heads
