Steel Welding
Always a secure connection
Challenge of steel welding
Steel remains the most widespread parent material in metal construction ahead of aluminum and stainless steel.
Its high strength and the low costs make it a popular construction material. Out of all materials, steel is the easiest to weld. The biggest challenge is keeping the material distortion as low as possible. Selecting the correct welding process plays an important part in this.
Interesting facts about steel
Steel is primarily composed of iron and a maximum of 2.06% carbon. Alloys with a higher proportion of carbon are known as cast iron. If the proportion of sulfur and phosphorus accompanying iron is less than 0.025%, it is called stainless steel.
Not every steel can also be welded: only pure steels, i.e. alloys with a carbon content of less than 0.22%, are suitable for this process. As a rule, the more impure the alloy, the harder it is to weld the steel.
Of particular importance are high-strength and super-high-strength steels. In addition to lightweight construction in the automotive industry, for example, they are also used for mobile cranes, concrete pumps, agricultural and forestry machinery. However, they are more difficult to weld than conventional steel alloys. The manufacturer's processing instructions should always be followed without fail.
Steel exists in a wide range of forms:
  • Flat steel
  • Round steel
  • Profile pipes
  • Square pipes
This is how to prepare steel for welding
  • Clean
    Before welding, remove coarse contamination from the steel in order to achieve good results.
  • Remove rust
    Remove rusty areas in the parent material before welding so that no bonding flaws occur in the weld metal.
  • Remove oil or grease
    Oily parent material makes the welding process more difficult and may, among other things, cause poor results. You should therefore remove the oil from the steel before welding.
  • Preheat
    In case of higher material thicknesses, you should preheat the part before welding to slow down the cooling time. This prevents a high degree of hardness in the microstructure, in turn preventing cracking.
Advantages
  • Very high strength
  • Low cost
  • Easy to weld
  • Can be recycled
Disadvantages
  • Susceptible to rust
  • High weight
Newsletter Registration
Welding process for steel
In principle, all welding processes are suitable for joining steel. However, the MIG/MAG process is primarily used because this allows for the highest welding speeds.
Professional welding systems for steel welding
TPS 320i
  • MIG/MAG welding system
  • Integrated data documentation
  • Intuitive touch display
Fortis 400
  • Easy-to-use digital user interface
  • Maximum connectivity
  • Reliable and stable welding performance for all manual applications
1 / 2
Read more about the subject
Simple, robust and cost-optimized
The welding of steel should be easy, robust and cost-optimized so that optimum weld seams can be achieved even under high cost pressure and in less-than-ideal circumstances.
Welding steel with the push system
Let's get connected.
