Symo Advanced SnapINverter
for Commercial Solar
The inverter generation for maximum safety, reliability & ROI
The Fronius Symo Advanced inverter line features six models ranging from 10 kW to 24 kW, ideal for commercial and industrial applications. The Symo Advanced is lightweight and combines high-power density with flexibility to ensure the fastest possible installation for your PV project.
The small number of total power conversion electronics adds to the high serviceability from any mounting spot. You get total system granularity with only a low number of system components.
Optimizing costs with Fronius inverters
For larger photovoltaic systems it is particularly important to keep the running costs (OPEX) as low as possible and to maximize the yield as much as possible. This results in shorter payback periods and high returns (a higher return on investment) – to the delight of every investor.
By using Fronius inverters, an economically viable solar system can be implemented even under complex system conditions. Thanks to the SuperFlex Design feature of the Fronius Symo Advanced, even complex systems with different roof orientations or shading are not a problem.
easy code compliance
Shade mitigation
The Fronius Symo line comes with a smart shade mitigation feature: The Fronius Dynamic Peak Manager (DPM) is an enhanced MPP tracking software that scans the entire I-V curve when searching for the optimal operating point. Usually, a MPP tracker starts looking for the maximum power point at a high voltage, because that’s where usually the peak of the curve lies. However, in a shaded array, the curve turns into an S-shape, where the peak at a high voltage is no longer the maximum power point across the entire curve.
By checking the entire characteristic curve on a regular basis, the DPM finds the global Maximum Power Point (GMPP) for partially shaded arrays. As with many other technologies, software is replacing clunky hardware with smarter and more integrated solutions. (see study here).
SunSpec rapid shutdown
With an integrated power line communication (PLC) transmitter, based on the SunSpec Rapid Shutdown communication standard, all Symo Advanced inverters have attained UL-PVRSE listing as a transmitter. The inverter is also listed as a UL-PVRSS with APsystem’s RSD device (Rapid Shutdown).
PC board replacement
Fronius Symo inverters are incredibly easy to service and ready for pro-active service solutions. Thanks to the inverter’s field-serviceability, reliability and low component count, Fronius Solutions Partners can solve most service issues with just one truck roll to the site. This means minimum time and cost for you and maximum yield for system owners.
Proven SnapINverter technology
Fronius SnapINverters are characterized by intelligent device design, maximum flexibility and smart functions.
  • Easy installation: Simply swing the inverter into the wall bracket.
  • Uniform design: Once you are familiar with one model, you can easily install others too.
  • Highest service quality: Easily accessible interfaces, remote updates and the PC board replacement process ensure quick and easy servicing.
  • Easy to use: Integrated data communication and online monitoring through Fronius Solar.web.
  • Future-proof: Open interfaces ensure the easy integration of third-party components – today and in the future.
Flexible AC service options
The 10 and 12kW models are available in 208 and 240 volt Delta, High-Leg, and WYE transformer output – eliminating the need for costly transformers. The 15-24 kW models work with 480 volt WYE services.
Fronius Symo Advanced is UL 3741 certified
UL 3741 is a solution to the NEC 690.12 requirement of module level rapid shutdown within a photovoltaic (PV) solar system. The Fronius Symo Advanced string inverter is UL 3741 certified for use with the PanelClaw® and IronRidge® racking systems when the inverter is installed within the 1ft array boundary.
More about UL 3741
Features at a glance
Active Cooling Technology
  • Prolongs the life of the inverter
  • Enables flexible system design & easy installation
  • Assists with yield optimization
  • MPP tracking algorithm with a tolerance for shading
  • Maximum yields even in the case of partial shading
  • In many cases, power optimizers are not needed
  • Best plug-and-play solution for the National Electrical Code’s module-level shutdown requirement
  • Based on an industry standard with Power Line Communication (PLC)
  • Easy connection of the inverter to the Internet via LAN/WLAN
  • Data logging, WLAN, Ethernet, energy management, web server and numerous interfaces fully integrated
  • Connection to third-party components by means of interfaces such as Modbus TCP SunSpec, Modbus RTU SunSpec or Fronius Solar API (JSON)
SnapINverter Technology
  • Innovative mounting system
  • Easy installation and maintenance
  • Components can be exchanged instead of replacing the device during servicing
SuperFlex Design
  • Enables maximum flexibility in system design
  • Different roof orientations and shading of strings do not pose any problems
Zero feed-in
  • Feed-in management from 0 - 100%
  • Compliance with all requirements of network operators
  • Simple adjustment via the inverter interface
1 / 7
Upcoming trainings & webinars
Fronius inverters in action
Best performance of the Fronius Symo Advanced
The PV system consists of 10 Fronius Symo SnapINverters, 10 Fronius Shade Covers, and 400 JA Solar 330- watt solar panels. Vulcan Solar Power a leading provider of turnkey solar energy systems across Alabama, Mississippi, and Georgia, designed and installed the PV system that is projected to produce more than 205,000 kilowatt-hours (kWh) of electricity in its first year.
The system is also the largest commercial system in central and southern Alabama.
See the reference
Birmingham array 1
Technical data
Technical data  Symo UL Symo Advanced
 Power category in kW  15  10 - 24
 Mains connection (Uac, r) 3~ NPE 208/220 V
3~ NPE 208-240 V
 Number of MPP trackers 1 2
DC input voltage range 325 - 1,000 V 200 - 600 V
 Oversizing 150%  150%
 Dimensions in mm 725 x 510 x 225
725 x 510 x 225
 Weight 35.52 kg
41.68 kg
    Get in touch with Fronius!
    We are here to help.
    Get in touch
