Product Catalogs
Wear parts for TIG welding torches
From gas nozzle and torch cap to tungsten electrode
TIG wear parts: top quality for reliable welding work
TIG wear parts from Fronius impress with maximum efficiency and an exceptionally long service life. These properties lengthen the replacement intervals for wear parts, reduce downtimes, and cut costs—for every application. Original Fronius wear parts not only extend the service life of your welding torches, they also reduce possible error sources and therefore guarantee high-quality welding results.
Advantages of our wear parts
Different types of wear parts
With our comprehensive range of products, we have the right solution for every welding application.
The longest possible service life
High-quality materials and precision manufacturing guarantee a significantly longer service life, even with intensive use.
Cost efficiency
You can shorten downtimes and reduce costs thanks to less frequent replacement and lower material consumption.
Outstanding seam quality
Precisely manufactured wear parts guarantee the optimum gas flow and stable arc quality for flawless welds.
Easy handling
Our wear parts are made to measure and user-friendly for unbeatable convenience during maintenance and replacement, leaving you more time for the work itself.
TIG wear parts explained: what you need for clean welds
Gas nozzles—diversity to cater for every welding task
The nozzles are specially designed to optimize the gas flow and meet even the highest requirements. Thanks to the high quality of the materials and careful manufacturing, they remain intact for longer and offer consistently high performance over their entire service life.
Even gas distribution and reduced turbulence for cleaner welds and less rework
Clear view of the welding point and enhanced precision for fine work
Perfect for tight, hard-to-reach areas thanks to precise shielding gas routing and improved access to the seam
For standard applications in draft-protected areas
Ideal for individual welding spots tailored to different workpiece geometries
Gas lenses: for optimum shielding gas coverage
The lenses ensure a laminar gas flow and provide consistently high-quality shielding gas coverage. They keep gas losses to a minimum, reduce turbulence, and as such contribute to uniform welds. Their long service life makes them a cost effective choice for pros.
Gas screen: protective function for uniform gas flow
When used in combination with the gas lens, the gas screen delivers a particularly uniform, laminar gas flow. It effectively protects the gas lens from wear (for example from welding fume) and therefore contributes to a longer component service life.
Torch caps: flexibility in every welding situation
With torch caps in a range of lengths, you can adapt your torch to every welding task. Be it in confined or spacious working environments, our robust and durable torch caps leave you in complete control.
Tungsten electrodes: powerful and reliable
Various types of electrodes are available, depending on the material and application—with different alloy additives for optimum ignition and weld properties. Because the right choice of electrode improves service life, arc stability, and ultimately your welding result.
Rapid electrode change with Tungsten Fast Clamp (TFC)
With this system, you can change the tungsten electrode quickly and effortlessly.
The touch of a button is all it takes to release and re-clamp the electrode—and all in just a few seconds, ensuring outstanding efficiency and uninterrupted work with no unnecessary downtime.
It is also possible to retrofit the TFC system to your existing TIG welding torches.
The tried, tested, and familiar A- and P-systems
A-system: with push-on gas nozzle for quick and easy replacement
P-system: with screw-type gas nozzle for maximum stability and a long service life
Both systems have proven their worth in practice and offer custom solutions for different requirements. Whether you need flexibility or stability—the choice is yours! Both solutions deliver unbeatable quality and facilitate professional welding with optimum results.
Interested in becoming a Fronius Robotic Integrator? Please fill in the information below to get started.
Let’s get connected.
