Information about our products and related services in accordance with the EU Data Act(Regulation (EU) 2023/2854)
valid from 9/12/2025
Data controller: Fronius International GmbH, Froniusstraße 1, 4643 Pettenbach, Austria
Contact: You can reach us at the following e-mail address: contact@fronius.com
    If the product data cannot be accessed directly via the respective product, Fronius will provide you, the user, with the readily available data, including metadata for the interpretation and use of the data, free of charge and in a comprehensive and common format.
    Please send your request to the following email address: dataprotection@fronius.com. Please fill out  this form.
    Please also specify which product or related service the data is to be provided from. Please note that Fronius may require user identification in order to verify your authorisation as a user to access the data.
    If you wish to pass on the generated data to third parties (or have it passed on) or wish to terminate this data transfer, please also contact dataprotection@fronius.com .
    Complaints procedure: If you have a complaint in this regard and wish to assert a violation of the Data Protection Regulation, you can address this to the competent authority.
    Data protection rights of data subjects: Data subjects affected by personal data processing in this context have the following rights at any time under the General Data Protection Regulation (GDPR): Right of access, right to rectification and supplementation, right to restriction of processing, right to erasure, right to data portability, right to object, right to withdraw consent and the right to lodge a complaint with the competent supervisory authority (Austrian Data Protection Authority, Barichgasse 40.42, 1030 Vienna, Austria).
    1. Networked products and related services of the Welding Technology division
    1.1. Welding products
    The following welding products are designed as so-called IoT devices and are therefore subject to the European Data Protection Regulation:
    • Fortis 270C, 320 C, 400 C and 400 /GW, 500 C, 500 GW and other products in the same series;
    • TPS 320i, 320i C, 320i PULSE, 400i, 400i LSC,  400i PULSE, 500i, 500i PULSE, 600i, 600i PULSE, 270i C PULSE and other products in the same series;
    • XuperArc 3200C, 4000DS, 5000DS and other products from the same series;
    • iWave 230i DC, 190 AC/DC, 230i AC/DC, 190 AC/DC, 300i DC, 300i AC/DC, 400i DC, 400i AC/DC, 500i DC, 500i AC/DC and other products in the same series;
    • WeldCube Connector U/I and other products from the same series.
    1.2. Product Data
    1.2.1. These welding products can generate the following product data:
    • Data on device settings (settings, job data, status data): such as default settings and operating point settings for welding, settings and condition data for the respective welding system.
    • Usage data: such as error states, setting parameter usage and usage data itself (this data may be personal).
    • Process data: process parameters (such as current, voltage, etc.), whereby these parameters are specified by the user.
    1.2.2. Storage: This product data can be generated in real time, but is not stored directly on the respective welding product. Product data that is made available in a related service or data processing service may be stored there for a specified period of time (see point1.3.1.2 ).
    1.2.3. Format: This product data can be obtained directly from the welding product in XML or PDF format. It is not possible to delete this product data.
    The usage data can only be accessed via the additional data processing service provided by Fronius, where the data is kept ready for retrieval and stored for a certain period of time (see1.3.1.2 ).
    1.2.4. Data access: The product data (except usage data) can be viewed directly on the respective welding product by retrieving the respective log file and can also be accessed via a web browser. More detailed information and instructions on how to retrieve the product data can be found in the operating instructions for your respective product or at www.fronius.com.
    1.2.5. Conditions of access: With regard to access to and use of the generated data, the respective contractual provisions (as set out in the Fronius terms of delivery and payment and in the respective terms of use) must be observed and complied with.
    1.3. Related services
    1.3.1. WeldCube Air
    WeldCube Air (hereinafter referred to as the "platform") offers the option of visualising welding data and digitally managing welding equipment, displaying the current welding processes in real time, as well as errors and warnings. In addition, operating instructions, spare parts catalogues and maintenance documentation can be accessed. Another feature is the display and use of optimisation potential and analyses provided.
    WeldCube Air is a cloud-based platform.
    1.3.1.1.  The product data of the networked welding products mentioned above, which is generated during the welding processes, namely
    • device settings,
    • usage data and
    • status data (in connection with the respective welding device)
    is transmitted directly to the cloud in real time when using the connected service and thus to Fronius due to its structure as a cloud-based platform. Service data: Connected service data is currently generated when using Weldcube Air, namely data on user activities (such as the creation, modification, deletion of welding instructions, qualifications, components, etc.).
    1.3.1.2. Storage: This product data is stored and retained on the platform. Fronius may limit storage and retention at its own discretion.
    1.3.1.3. Data access: The user can access this product data and associated service data directly on the platform; this requires a valid customer account or corresponding registration.
    1.3.1.4. Purposes: The data available on the platform is used by Fronius for the following purposes: product improvement, targeted advertising, in particular in connection with wear and spare parts. This use is agreed with the respective user.
    1.3.1.5. There are currently no plans to make this data available to third parties (except at your request).
    1.3.1.6. In connection with the platform, Fronius is not the owner of any trade secrets contained in the data.
    1.3.1.7. The term of the contract is based on the terms of use agreed for the platform and any other agreements made. The termination terms can be found in the terms of use or contract terms.
    1.3.2. WeldCube Premium
    WeldCube Premium offers intelligent management, analysis and statistics functions combined with graphical processing based exclusively on the recorded data of all connected welding products.
    The networked welding products are also functional without WeldCube Premium and all product functions can be executed.
    The generated product and related service data of the welding products, which are also required in WeldCube Premium for further functions, can be accessed free of charge in WeldCube Air as described above.
    WeldCube Premium with its functionalities is therefore essentially a service that does not affect the operation of the networked product and does not transmit any commands or data to the networked product. WeldCube Premium is therefore not a related service within the meaning of the Data Regulation.
    However, we would be happy to provide you with information about the data processing that takes place in WeldCube Premium. Please contact us at the above email address.
    1.3.3. WeldCube Navigator
    WeldCube Navigator is a Windows desktop application (hereinafter referred to as "service") designed to help standardise manufacturing processes and avoid errors by creating predefined welding instructions and guiding the respective welding specialist through the task. The work steps are visualised (on a separate display device) and the correct parameters are set directly on the welding machine.
    1.3.3.1. The product data of the networked welding products mentioned above, which is generated during the current welding processes, namely
    • device settings,
    • usage data and
    • status data (related to the respective welding machine, such as utilisation, temperature and speeds) are transmitted to the service in real time and stored locally.
    The following related service data is generated when using the service:
    • Registrations with a welding machine and the service;
    • Workflow data: number of welds with imported instructions, steps and status of production based on the instructions;
    • Imported and specified welding parameters;
    • User management data;
    • Product data documentation and documentation on welds performed;
    • Service settings data and monitoring of the service's programme functionalities.
    1.3.3.2. Storage: Product data is not stored in this service, but is only documented on the welded product. The service data is stored on the PC used (50 MB storage space by default) and is subsequently replaced by newer service data on a rolling basis as soon as the storage space is reached.
    1.3.3.3. Format: Service data is stored and archived in JSON format. Product data is provided in the formats mentioned above.
    1.3.3.4. Data access: The user can retrieve the product data in this service. The product data documentation and documentation on the welds performed can be exported directly from the welding machine.  The related service data can be accessed directly via the service. This data can be exported to a file system on a PC or directly via the service.
    1.3.3.5. Purposes: The data available in the service is not used by Fronius for its own purposes.
    1.3.3.6. Third parties: There are currently no plans to make this data available to third parties (except at your request).
    1.3.3.7. Fronius is not the owner of any trade secrets contained in the data in connection with the service.
    1.3.3.8. The term of the contract is based on the terms of use agreed for the service and any other agreements made. The termination conditions can be found in the terms of use or contract terms.
    2. Networked products and related services of the Solar Energy business division
    2.1. Solar Products
    The following SOLAR products are designed as so-called IoT devices and are therefore subject to the European Data Regulation. When using these products, the following product data is generated:
    Product supercategory Fronius product Product data
    Inverter
    Fronius Symo GEN24
    Fronius Primo GEN24
    Fronius Verto
    Fronius Verto Plus
    Fronius Tauro
    Fronius Argeno
    Data Manager
    Power
    Energy (production)
    Voltage
    Current
    Ohmpilot Ohmpilot
    Ohmpilot Eco
    Energy (consumption)
    Temperature of the inverter
    (via inverter)
    Wattpilot Wattpilot
    Wattpilot Flex
    Power
    Energy
    Voltage
    Current
    Charging process logs
    SmartMeter SmartMeter IP
    SmartMeter IP 2.1.
    SmartMeter
    Power
    Voltage
    Current
    Energy
    (via Inverter)
    Energy storage-battery Reserva State of charge
    Power
    Current
    Voltage
    (via Inverter)
    2.2. Product Data
    2.2.1. Inverter
    2.2.1.1.  Data access: The above types of product data are generated in real time when using the inverters.
    The product data can be accessed directly via the device: via the Solar API (interface) (except for the "Argeno" inverter) – to do this, you must access the interface via the same network, or via a MODBUS interface. For more detailed information and instructions on how to access the product data, please refer to the operating instructions for your respective inverter or visit www.fronius.com.
    2.2.1.2. Format: If the product data is retrieved via one of the interfaces, it can be downloaded and saved in json format (Solar API) or as a Sunspec register (Modbus interface).
    2.2.1.3. Storage: Real-time product data (known as live data) is not stored on the inverter. The exception to this is the "Argeno" inverter, where product data is also stored locally in a ring buffer for display and support purposes.   Settings made on the inverter can be downloaded in PDF format for Gen24, Verto and Tauro inverters. This data is permanently available as it is necessary for operation.
    If an additional digital service is used (such as Solar.web or another platform for visualising the product data of an inverter), product data can also be accessed there and, in particular, stored for a longer period of time (depending on the digital service used).
    2.2.1.4. Conditions of access: With regard to access to and use of the generated data, the respective contractual provisions (as specified in the Fronius terms of delivery and payment and in the respective terms of use) must be observed and complied with. The technical limitations of the data interfaces can be found in the respective documentation. Rapidly successive requests via the interfaces can affect the stability of the system.
    2.2.2. Ohmpilot
    2.2.2.1. Data access/format: The above-mentioned types of product data are generated in real time when using Ohmpilot. The product data can be queried via the above-mentioned interfaces of the connected inverter and is output in the above-mentioned format depending on the interface used.
    2.2.2.2. Storage: The product data generated in real time is not stored.
    2.2.3. Wattpilot
    2.2.3.1. Data access: The above types of product data are generated in real time when using Wattpilot. The product data can be queried via the SolarWattpilotAPP, the OCPP interface and via a connected service (e.g. Solar.web).
    2.2.3.2.  Storage: Product data generated in real time is not stored on the device.
    2.2.4. SmartMeter
    2.2.4.1. Data access/format: The above types of product data are generated in real time when using the SmartMeter. The product data can be queried via the above-mentioned interfaces of the inverter and is output in the above-mentioned format depending on the interface used.
    2.2.4.2. Storage: The product data generated in real time is not stored on the device.
    2.2.5. Battery Reserva
    2.2.5.1. Data access/format: The above types of product data are generated in real time when the battery is in use. The product data can be queried via the above-mentioned interfaces of the inverter and is output in the above-mentioned format depending on the interface used.
    2.2.5.2. Storage: Product data generated in real time is not stored.
    2.3. Related Services
    2.3.1.  Solar.web
    "Solar.web" is a cloud-based software-as-a-service platform (hereinafter referred to as "service") that visualises the production data of the stored PV system in particular and offers the possibility of monitoring energy yield, optimising energy consumption and further analysis options.
    2.3.1.1.  Due to its design as a cloud-based platform, the product data of the connected am. SOLAR products generated when using these products is transmitted directly to the cloud and thus to Fronius in real time when using the related service.
    • Log data (log files), if applicable;
    2.3.1.2. Storage: This product data is stored and retained on the platform. Fronius may limit the storage and retention of this data at its own discretion.
    2.3.1.3. Format: The product data can be queried directly via the inverter as described above and is output in the respective format.
    2.3.1.4. Data access: The user can access the product data in this service directly; this requires a valid customer account or corresponding registration.
    2.3.1.5. Purposes: The data available in the service is used by Fronius for the following purposes: product improvement, targeted advertising.
    2.3.1.6. Third parties: It is currently intended to make this data available to third parties. Product data can be made available to third parties designated by you and, if necessary, retrieved via an interface (this is particularly the case with so-called virtual power plants). Product data is made available to your network operator or virtual power plant provider after prior consent has been obtained. Certain aggregated (and non-personal) product data may be made available to network operators and public utility service providers, as this data is necessary for the maintenance and efficient expansion of the electricity grid.
    2.3.1.7. In connection with the service, Fronius is not the owner of any trade secrets contained in the data.
    2.3.1.8. The term of the contract is based on the terms of use agreed for the service and any other agreements made. The termination terms can be found in the terms of use or contract terms.
    2.3.2. Solar.wattpilot app
    The SolarWattpilot app is a cloud-based application (hereinafter referred to as the app) that can be used to monitor, analyse and control the Wattpilot and adjust its settings.
    2.3.2.1. The product data of the networked Wattpilots mentioned above, which is generated when using these products, is transmitted directly to Fronius in real time when using the related service, which is cloud-based.
    2.3.2.2. Storage: This product data is stored and retained in the app. Fronius may limit the storage and retention of this data at its own discretion.
    2.3.2.3. Data access: Users can directly access the product and service data in this app; this requires a valid customer account or corresponding registration.
    2.3.2.4. Purposes: The data available in the service is used by Fronius for the following purposes: product improvement, targeted advertising. This use is agreed with the respective user.
    3. Networked products and related services of the Battery Charging Technology division
    3.1. Battery Charging Technology products
    The following battery charging technology products are designed as so-called IoT devices and are therefore subject to the European Data Regulation. When using these products, the following product data is generated:
    Product Product data Data access: Accessible via
    Selectiva charger (4.0 or higher) with the additional product Gateway
    Charging data: per charging process, such as current data, voltage data, temperature data Operating meter data
    USB port directly on the device
    Gateway Log files in connection with network configurations  via webpage as part of network configuration
     TagID Battery data: voltage data, temperature, battery charge level data
    Associated cloud service
    3.2. Product Data
    3.2.1. Selectiva chargers + gateway: The above types of product data are generated in real time when the chargers are used in combination with the Gateway product.
    3.2.1.1. Data access and format: The product data can be accessed directly on the charger via a USB port. The product data is provided in CSV format.
    3.2.1.2. Storage: The product data is stored on the charger – depending on the storage capacity and use of the product, different periods of time may apply for the storage of product data. Once the storage capacity is reached, older data is overwritten with newer data. If an additional digital service is used (such as Charge & Connect or another platform for visualising product data from a charger), real-time product data can also be accessed there and, in particular, stored for a longer period of time (depending on the digital service).
    3.2.2.  Product TagID
    The product TagID is a battery sensor that can be attached to the battery. The above product data is generated in real time.
    The real-time product data is not stored unless an additional digital service (from Fronius) is used. The product data can then be displayed in this service, where it has already been enriched and subjected to further analysis and calculations. It is not possible  to provide raw data from the TagID product, as this is not stored and is therefore not (readily) available.
    3.3. Related Services
    3.3.1. Charge & Connect – data processing service
    The "Charge & Connect" data processing service offered by Fronius provides intelligent management, analysis and statistics functions combined with graphical processing based exclusively on real-time product data transmitted from all chargers stored in the service. The networked chargers are fully functional even without Charge & Connect and can perform all product functions without the need for this data processing service. The generated product data can be accessed directly via the respective charger.
    Charge & Connect with its functionalities is therefore essentially a data processing service that does not affect the operation of the networked product. Charge & Connect is therefore not a related service within the meaning of the Data Regulation.
    However, we would be happy to provide you with information about the data processing that takes place in Charge & Connect. Please contact us at the above email address.
    Form: Data access request (data user)
    Identification of the user
    Name:
    Address:
    Contract number, if applicable:
    (if applicable) Identification of the person making the request on behalf of the user
    Name:
    Relationship to the user: ______________
    Products and/or related services covered by the request
    Product/related service 1:_____________ (e.g. serial number)
    Product/related service 2:_____________ (e.g. serial number)
    Data affected by the request
    • All readily available data held by the data owner
      o   Including personal data If you are not the data subject or the user is not the data subject, please provide a valid legal basis in accordance with Art. 6 GDPR.
      o   After anonymisation
    • Personal data only
    • Other data: _________________________
    Period/date of the data affected by the request*
    *Historical/future data can only be provided if it is also processed and stored by the data controller.
    •  Historical data: _________________________________________________detailed description of the period
    • Future Data: _________________________________________________detailed description of the period
    Desired time period for the provision of the data
    • Without undue delay
    • Continuously
    • Real time
    • At an appropriate frequency
    • Other: please specify
    Modalities for data access
    • Data transmission to the user
    • If available, via direct access to the data storage location
    Information for data transfer
    Please specify the email address or other address/medium to which the data should be transferred
    Date of request
    Form: Data transfer request (transfer to third parties at the request of the data user)
    Name:
    Address:
    Name:
    Please note: does not apply in connection with the testing of new networked products, substances or processes that are not yet on the market.
    • Option 1: All readily available data held by the data owner
    • Option 2: Specific data, please describe in more detail
    If the data also includes personal data
    Please provide a valid legal basis for processing in accordance with Art. 6 GDPR
    Identification of the third party
    Please note: this must not be a gatekeeper in accordance with Art. 3 of Regulation (EU) 2022/1925
    Contactdata: _____________________
