Fronius Symo GEN24
Inverters for private photovoltaic systems with backup power function
Our three-phase Fronius GEN24 inverter is the heart of private photovoltaic systems.
The Fronius GEN24 is equipped with PV Point, an integrated basic backup power function that supplies backup power to connected devices via a protected socket (as long as the sun is shining).*
The Fronius Symo GEN24 boasts a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers:
/ Active cooling for a longer service life
/ Flexible and fast installation
*The Full Backup option is not available for the Fronius Symo GEN24 3.0-5.0.
Technical Data
Input Data
Number of MPP trackers | 2 |
Maximum PV input power | 10,3 kW |
Feed-in start voltage (Udc start) | 80 V |
Nominal input voltage (Udc,r) | 610 V |
Min. MPP voltage ( U mpp min) | 246 V |
Max. MPP voltage ( U mpp max) | 800 V |
Output Data
AC nominal output (Pac,r) | 9999 W |
Max. output power (Pac max) | 9999 VA |
Max. grid power demand | 9999 VA |
AC output current (Iac nom) | 14,5A at 230Vac , 15,2A at 220Vac |
Max. AC output current | 18,5 A |
Grid connection (Uac,r) | 3~NPE 400/230, 3~NPE 380/220 V |
AC voltage range (Umin - Umax) | 154 - 280 V |
Frequency (fr) | 50 / 60 Hz |
Frequency range (fmin - fmax) | 45 - 66 Hz |
Power factor (cos φac,r) | 0,7-1 ind./cap. |
Back-up power | 1~NPE 220 V / 230 V |
Back-up power | 1~NPE 220V / 230V |
Nominal AC output current (380VAC) | 12,1 A |
Nominal AC output current (400VAC) | 11,6 A |
Output Data PV Point
Max continuous output power | 3000 VA |
Nom. output current (Iac max) | 13 A |
Grid connection | 1 ~ NPE 220 V / 230 V |
Max. switchover time PV-Point | 15 s |
Max. switchover time Full Backup | 10 s |
Frequency in backup power mode | 53 Hz |
Battery Connection
Max. input current (Idc max.) | 22 A |
Min. DC input voltage | 160 V |
Max. DC input voltage | 531 V |
General Data
Mains Frequency | Hz |
Width | 529 mm |
Height | 595 mm |
Depth | 180 mm |
Weight | 24,27 kg |
Weight | 22,75 kg |
Weight incl. packaging | 28 kg |
Protection class | IP66 |
Night-time consumption | <10 W |
Cooling | Regulated air cooling |
Ambient temperature range | -25°C - +60°C |
Permitted humidity | 0 - 100 % |
Max. altitude 2) | 3 000 m / 4 000 m (uneingeschränkter / eingeschränkter Spannungsbereich) |
DC PV connection technology | 3x DC+ and 3x DC- push-in spring terminals 2.5 - 10 mm² |
AC connection technology | PV Point |
Efficiency
Max. efficiency (PV - grid) | 98,3 % |
European efficiency (ηEU) | 97.0 / 98.1 / 97.9 (246Vdc / 610Vdc / 800Vdc) |
η at 5% Pac,r 3) | 93.0 / 95.8 / 95.0 (246Vdc / 610Vdc / 800Vdc) |
η at 10% Pac,r 3) | 95.6 / 97.4 / 96.9 (246Vdc / 610Vdc / 800Vdc) |
η at 20% Pac,r 3) | 96.8 / 98.1 / 97.8 (246Vdc / 610Vdc / 800Vdc) |
η at 25% Pac,r 3) | 97.1 / 98.2 / 98.0 (246Vdc / 610Vdc / 800Vdc) |
η at 30% Pac,r 3) | 97.3 / 98.3 / 98.1 (246Vdc / 610Vdc / 800Vdc) |
η at 50% Pac,r 3) | 97.4 / 98.3 / 98.1 (246Vdc / 610Vdc / 800Vdc) |
η at 75% Pac,r 3) | 97.3 / 98.2 / 98.0 (246Vdc / 610Vdc / 800Vdc) |
η at 100% Pac,r 3) | 97.0 / 98.0 / 97.9 (246Vdc / 610Vdc / 800Vdc) |
Protection Devices
DC insulation measurement | Yes |
Overload behaviour | Operating point shift, Power limitation |
DC disconnector | Yes |
DC Reverse polarity protection | Yes |
Interfaces
WLAN / 2x Ethernet LAN | Fronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON) |
6x digital in/out + 6x digital in | Interface to ripple control receiver, energy management |
Emergency stop (WSD) | Yes |
Datalogger and web server | Included |
2x RS485 | Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot |
