Fronius Symo GEN24
Inverters for private photovoltaic systems with backup power function
Our three-phase Fronius GEN24 inverter is the heart of private photovoltaic systems.
The Fronius GEN24 is equipped with PV Point, an integrated basic backup power function that supplies backup power to connected devices via a protected socket (as long as the sun is shining).*
The Fronius Symo GEN24 boasts a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers:
/ Active cooling for a longer service life
/ Flexible and fast installation
*The Full Backup option is not available for the Fronius Symo GEN24 3.0-5.0.
Technical Data
Input Data
| Number of MPP trackers | 2 |
| Maximum PV input power | 12,36 kW |
Max. input current (Idc max) | 28 / 14 A |
| Max. array short circuit current (1.5 * Imax) | 40 / 20 A |
DC input voltage range (Udc min - Udc max) | 80 - 1000 V |
Feed-in start voltage (Udc start) | 80 V |
Nominal input voltage (Udc,r) | 610 V |
| Usable MPP voltage range | 80 - 800 V |
| Number of DC connections | 2/1 |
| Min. MPP voltage (U mpp min) | 295 V |
| Max. MPP voltage (U mpp max) | 800 V |
Max. PV generator power (Pdc max) | 18 kWpeak |
Output Data
AC nominal output (Pac,r) | 12 kW |
Max. output power (Pac max) | 12 kVA |
| Max. grid power demand | 12 kVA |
AC output current (Iac nom) | 17,4A at 230Vac / 18,2A at 220Vac |
| Max. AC output current | 18,5 A |
Grid connection (Uac,r) | 3~NPE 400/230, 3~NPE 380/220 V |
AC voltage range (Umin - Umax) | 154 - 280 V |
Frequency (fr) | 50 / 60 Hz |
Frequency range (fmin - fmax) | 45 - 66 Hz |
Power factor (cos φac,r) | 0,7-1 ind./cap. |
| Back-up power | 3~NPE 400 V / 230 V |
| Nominal AC output current (380VAC) | 18,2 A |
| Nominal AC output current (400VAC) | 17,4 A |
Output Data PV Point
| Max continuous output power | 3000 VA |
Nom. output current (Iac max) | 13 A |
| Max. switchover time PV-Point | 15 s |
| Frequency in backup power mode | 53 Hz |
Battery Connection
| Min. DC input voltage Battery input | 160 V |
| Max. DC input voltage Battery input | 700 V |
General Data
| Dimension / width | 529 mm |
| Dimension / height | 595 mm |
| Dimension / depth | 180 mm |
| Weight | 22,75 kg |
| Weight incl. packaging | 28 kg |
| Degree of protection | IP66 |
| Protection class | 1 |
| Night-time consumption | <10 W |
| Inverter design | Transformerless |
| Installation | Indoor and outdoor installation |
| Ambient temperature range | -25°C - +60°C |
| Permitted humidity | 0 - 100 % |
| Max. altitude | 3000m / 4000m (unrestricted / restricted voltage range) |
| Max. altitude | 4000 m |
| DC PV connection technology | 3x DC+ and 3x DC- push-in spring terminals 2.5 - 10 mm² |
| DC battery connection technology | 1x BATT+ and 1x BATT- push-in spring terminals 2.5 - 10 mm² |
| AC connection technology | 5 pole AC push-in spring terminals 1.5 - 10 mm² 3 pole backup power push-in spring terminals 1.5mm² - 10mm² 5x PE-screw terminals 2.5 - 16 mm² |
| Back-up power functions | PV Point |
| Sound emissions | 47 dB(A) |
Efficiency
| Max. efficiency (PV - grid) | 98,2 % |
| European efficiency (ηEU) | 97.0 / 97.9 / 97.5 (295Vdc / 610Vdc / 800Vdc) |
η at 5% Pac,r 3) | 93.0 / 95.4 / 93.2 (295Vdc / 610Vdc / 800Vdc) |
η at 10% Pac,r 3) | 95.9 / 97.1 / 96.0 (295Vdc / 610Vdc / 800Vdc) |
η at 20% Pac,r 3) | 96.8 / 98.0 / 97.4 (295Vdc / 610Vdc / 800Vdc) |
η at 25% Pac,r 3) | 97.1 / 98.1 / 97.5 (295Vdc / 610Vdc / 800Vdc) |
η at 30% Pac,r 3) | 97.2 / 98.1 / 97.6 (295Vdc / 610Vdc / 800Vdc) |
η at 50% Pac,r 3) | 97.4 / 98.2 / 97.8 (295Vdc / 610Vdc / 800Vdc) |
η at 75% Pac,r 3) | 97.3 / 98.0 / 97.8 (295Vdc / 610Vdc / 800Vdc) |
η at 100% Pac,r 3) | 97.0 / 97.9 / 97.6 (295Vdc / 610Vdc / 800Vdc) |
Protection Devices
| Overload behaviour | Operating point shift, Power limitation |
| DC disconnector | Yes |
Interfaces
| 6x digital in/out + 6x digital in | Interface to ripple control receiver, energy management |
| Emergency stop (WSD) | Yes |
| Datalogger and web server | Included |
| 2x RS485 | Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter |
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Multi Flow Technology
Full Backup
PV Point
Active Cooling
Fronius UP
Is a programme that allows the installer to upgrade a Fronius product via Solar.web – without any additional hardware. Fronius UP offers unique, new and innovative possibilities to expand Fronius products with new features according to the customers` needs at any time. This leads to maximum flexibility and future reliability.Clear HTML version of the operating instructions. Mobile and optimised for every device.
