Fronius GEN24 & GEN24 Plus
The inverter for the PV system in your family home
Greater autonomy for your home with the GEN24
With the Fronius GEN24 you can generate your own solar energy cleanly, economically, and independently. The inverter takes care of all your needs, from electricity and heating to cooling and e-mobility— and with the GEN24, even at night with a connected battery storage device. Use your self-generated solar energy flexibly and directly, even in the event of a blackout thanks to the integrated PV Point basic backup power supply.
With integrated digital tools, high efficiency, durable design, and European manufacturing, the Fronius GEN24 is the ideal inverter for modern family homes. Optimize you transition to solar energy with the Fronius GEN24 and GEN24 Plus.
Fronius GEN24 SC – our new inverter generation
With the SC generation, Fronius takes the GEN24 inverters to a new level of performance. The Fronius GEN24 SC (“Superior Current”) handles higher PV input currents and is optimally tailored to modern PV modules as well as future technological developments. This enables flexible system planning and efficient energy conversion—even with rising module currents.
Additionally, the GEN24 SC comes standard with Fronius Arc Guard (AFCI). This integrated arc protection feature continuously monitors the PV system, significantly enhancing safety for your home.
Your advantages at a glance
Fronius GEN24 and Fronius GEN24 Plus
The Fronius GEN24 and Fronius GEN24 Plus boast a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers at the click of a button.GEN24 - Outstanding versatility
The Fronius GEN24 is a genuine all-rounder. From perfectly coordinated storage solutions and flexible upgrade options to intelligent cooling and practical accessories— these are just a taste of what the GEN24 can do.
Technical data & downloads
| Data | |||
| 1-phase / 3-phase | 1-phase 230 V | 3-phase 230 / 400 V | |
| Power categories | 3 / 3.6 / 4 / 4.6 / 5 / 6 kW ** | 3 / 4 / 5 kW* | 6 / 8 / 12 kW ** |
| MPP trackers | 2 | 2 | |
| Protection class | IP 66 | IP 66 | |
| Dimensions (WxHxD) in mm |
474 x 530 x 165 | 474 x 530 x 165 | 529 x 595 x 180 |
| DC input voltage (Udc min - Udc max) |
65 V – 600 V | 80 V – 1,000 V | |
* The Full Backup option is not available for the Fronius Symo GEN24 3.0–5.0 Plus. For Full Backup, a battery and a switching device for safe grid disconnection are required in addition to the inverter.
** Availability in Australia: Primo: 3 / 3.6 / 4 / 4.6 / 5 / 6 / 8 / 10 kW / Symo: 3 / 4 / 5 kW and 6 / 8 / 10 kW
Your photovoltaic system can do more
The fastest way to a Fronius device
