E-mobility
Driving on solar power
Fronius E-Mobility Solar Energy
The mobility of the future is electric. And we have the energy to make it happen.
Charging your electric vehicle with green electricity not only makes it emissions-free, but also highly economical—especially if you use self-generated solar power from your PV system. This also means that your mobility helps shape a more livable, sustainable future.
From roof to battery: by installing an electric charging station at your home, you can use your solar power even more efficiently while also increasing your self-consumption. This means that your PV system and your electric vehicle will both pay for themselves even faster, saving money, conserving resources and resulting in a smaller carbon footprint.
Fronius E-Mobility electric charging
E-mobility meets solar power—your advantages
Reduced costs and lower grid consumption
From day one, your solar power delivers the most economical way to charge.
Increased self-consumption
The more of your own solar power you use in your household, the more you can save—and the less of your power is fed into the grid.
Reduced carbon emissions
Smaller ecological footprint, cleaner air: electric cars produce no exhaust fumes.
E-mobility that pays off
The right charging solutions for electric cars pay off in several ways.
With the PV surplus, you can charge your electric vehicle at no cost—making use of the excess energy your photovoltaic system isn’t currently supplying to your household. Thanks to different charging modes, your car is always supplied with self-generated solar power or automatically charged at the lowest available grid rate. This makes it quick and easy for you to specify the precise amount of solar power needed to charge your electric car for your next journey, as well as the time it needs to be charged by.
Fronius E-Mobility charging solution
Our solutions
Wattpilot Flex
Elegant design, state-of-the-art technology: with the Fronius Wattpilot Flex, you can optimally charge your electric car at home or at work using self-generated solar power. The electric charging station is available in a “Home” and a “Pro” version, with the “Pro” version being ideal for company or fleet vehicles.
Fronius E-Mobility Wattpilot Flex
Wattpilot
No matter whether you’re at home or out and about, the Fronius Wattpilot allows you to charge more flexibly and intelligently than ever before. Available in two versions: “Go” as a portable solution and “Home” as a permanently installed charging box for the home. Simply plug in and charge.
More about the Wattpilot
Solar.wattpilot app
As flexible as the charging solution itself: our matching app allows you to conveniently control the Fronius Wattpilot via your smartphone or tablet.
More about the Solar.wattpilot app
Fronius Solar.wattpilot App
Full charging flexibility
“Another advantage of the Wattpilot is that it automatically adjusts the charging power depending on how much surplus PV is available. Once the car is plugged in, you don’t have to worry about anything else. It makes life so much easier for us.” – Ralf Anzi
Go to reference
Fronius E-Mobility car charging
