Fronius Wattpilot Flex
Charging station for electric cars
Woman with electric car and Fronius Wattpilot Flex
Wattpilot Flex: Maximum efficiency for charging with solar power
For those who like to be ahead of the game, Fronius offers the perfect combination of elegant design and state-of-the-art technology with the Wattpilot Flex.
The Fronius EV charger uses every ray of sunshine from your PV system* to charge your car as efficiently as possible for the next day. Intelligent charging modes in combination with a variable electricity tariff enable cost-effective and efficient use of the solar power generated by your own PV system. Where necessary, the Wattpilot Flex draws additional power from the grid when the price is lower for maximum range. The ideal electric car charging station for your home—sustainable, flexible, and cost-efficient.
*Additional components are required for charging with surplus PV energy. All the details can be found in the operating instructions.
Fronius Wattpilot Flex Home
Go to technical data
Fronius Wattpilot Flex in white
Fronius Wattpilot Flex Pro
Design Award for Fronius Wattpilot Flex
Charging electric cars with cheap solar power
With the Fronius Wattpilot Flex, you can charge your vehicle cost-effectively using your own solar energy. The PV-optimized Fronius EV charger automatically switches between 1 and 3 phases to make the best possible use of the sun’s power. Depending on the version, surplus PV energy of 1.38 to 11 or 22 kW is used to optimal effect. Not a single ray of sunshine is wasted.
The Fronius charging station impresses with its modern design and outstanding functionality. The Fronius Wattpilot Flex even received the prestigious German Design Award 2025 for its excellent product design.
Highlights
PV-optimized charging
Our PV-optimized charging solution puts the sun’s energy to intelligent use by dynamically adapting the charging process to the available solar power.
Efficiency meets elegance
The elegant look and high-quality finish make the electric car charging station a stylish feature in your home.
User-friendly interface
The Fronius Wattpilot Flex impresses with its intuitive touch controls and easy-to-navigate menu. Thanks to the integrated WiFi and LAN interfaces, it can be easily integrated into your home network.
Wattpilot Flex
Entdecken Sie die Highlights der Fronius Wallbox für zuhause.
Product picture of Fronius Wattpilot Flex Pro
Charging solution installation made easy
Quick installation, suitable for indoor and outdoor areas, and protected against external influences with IP66 safety class. Cable routing from above, below, and behind enables a flexible system design to suit the desired installation location.
Flat design
Optional mounting post
Wattpilot Flex for indoors & outdoors
The Fronius Wattpilot Flex is quick to install and ready to use in no time at all. Designed for both indoor and outdoor use, it can be installed in company parking lots, underground garages, or right in front of your home.
Transparent billing for electric company cars
The Fronius Wattpilot Flex Pro is the ideal choice for your electric company car. Thanks to the built-in MID*-compliant electricity meter, our charging station not only charges your company car efficiently, but also records the exact number of kilowatt hours charged for transparent billing with your employer. The Fronius Wattpilot Flex Pro can be seamlessly integrated into existing energy systems and impresses with its modern, elegant design in anthracite, which blends perfectly into any residential setting.
Fronius Wattpilot Flex Home awarded second place
The 2025 Wallbox Inspection shows for the first time how efficiently charging stations transfer surplus PV power to electric cars. The Fronius Wattpilot Flex Home 22 C6 impresses with a strong 94.4% Wallbox Performance Index (WPI) and secures second place.
Find out more about the 2025 Wallbox Inspection here
Award for Fronius Wattpilot Flex at the Wallbox Inspection 2025
Technical data
Data  Wattpilot Flex Home Wattpilot Flex Pro
Max. charging power  11/22 kW  11/22 kW
Dimensions (l x w x h)  325 x 195 x 105 mm  325 x 195 x 105 mm
Weight incl. type 2 charging cable  4.1/5.4 kg (11/22 kW)  4.1/5.4 kg (11/22 kW)
Charging cable  6 m cable with type 2 plug  6 m cable with type 2 plug
Cable entry  At the top (only permitted indoors), bottom, and rear  At the top (only permitted indoors), bottom, and rear
Network connection  LAN & WiFi  LAN & WiFi
MID meter  Not integrated  Integrated
Conformity with measurement and calibration law No  Yes
Color Telegray 4 Anthracite
Use* Indoors and outdoors Indoors and outdoors
*When installing outdoors, only the cable entry at the rear or the bottom may be used. The charging power can be limited by the Wattpilot in direct sunlight.
Find the right Fronius partner for you
Icon installer
Find an installer
Are you considering a photovoltaic system powered by Fronius? From planning to installation and commissioning: you’ll find the right partner for your project here.
To Fronius installers
Icon cooperation network
Find a sales partner
Are you an installer looking for a sales partner in your area? Then we would be happy to help.
To Fronius sales partners
More about the topic
Fronius Wattpilot Go charging box for on-the-go use with CEE plug.
Mobile charging solution for on the go
The Fronius Wattpilot Go is designed for mobile charging. With its CEE plug, you can charge wherever you find an available socket. More about the Wattpilot Go.
Product picture of Fronius Wattpilot Flex pedestal
Charging solution accessories for even more flexibility
From mounting columns to RFID tags and future-ready base plates, customize your Fronius charging station to fit your exact requirements.
More about the mounting post
