Store solar power
Batteries for PV systems
Your energy when you need it
A battery storage system can significantly increase the self-consumption rate of the solar power you generate. At the same time, your energy costs are reduced because you are less reliant on electricity from the public grid. Your surplus solar power is stored in the battery for use during peak demand or nighttime hours.
The ideal choice for your perfectly tailored complete PV solution.To provide you with the best possible support in maximizing your self-consumption, we have developed our own storage solutions: the Fronius Reserva and Reserva Pro. They have been designed as the perfect partners to our hybrid inverters Fronius GEN24 Plus and Verto Plus and are available in various capacities. The lithium iron phosphate technology guarantees maximum safety and a long service life.
The ideal choice for your perfectly coordinated system PV solution.
Fronius storage solutions
Available capacities: 12.0 kWh – 32.0 kWh
Up to 128 kWh via parallel connection
Available capacities: 6.3 kWh – 15.8 kWh
Up to 63 kWh via parallel connection
All you need to know about Fronius battery storage systems
FAQs about Fronius batteries
The Fronius Reserva and the Fronius Reserva Pro are high-performance battery storage systems for storing and utilising self-generated solar power and can be seamlessly integrated into the Fronius energy system. Both storage systems enable a high degree of energy independence, are flexibly expandable and can also be used for backup power applications.
The Fronius Reserva was developed specifically for residential properties and stands out thanks to its sleek design and flexible storage capacities. The Fronius Reserva Pro is suitable for applications with higher energy requirements and greater power demands, making it the ideal solution for larger residential properties, agricultural businesses and small and medium-sized enterprises. Thanks to the practical click system, the Reserva Pro is particularly easy and efficient to install. Furthermore, its cells and modules are manufactured in Europe, which ensures high quality standards, short supply chains and a reliable value chain.
It is possible to retrofit individual battery modules into an existing battery tower or to add additional battery towers. This allows the storage capacity to be flexibly adapted to rising energy requirements, for example following the purchase of an electric vehicle, a heat pump or other electrical appliances.
To make optimum use of the storage capacity, Fronius recommends carrying out the expansion within the first two years of commissioning. An expansion is still possible even after two years. In this case, however, the newly added battery module will be adjusted to the State of Health (SoH) of the existing battery system.
Yes. The model designations for Fronius batteries refer to the storage system’s actual usable capacity. For example, with the Fronius Reserva 12.6, the specified 12.63 kWh is available for operation.
Deep discharge is prevented. The battery storage systems have an integrated safety buffer, which is not included in the usable capacity and protects the battery from deep discharge and premature cell ageing. This means that, from the user’s perspective, the state of charge (SoC) can drop to 0 % without compromising the battery’s service life or safety.
The optimal battery size depends on your electricity consumption and usage profile. As a general guideline:
- Average daytime electricity consumption: Battery capacity (kWh) = Annual electricity consumption (kWh) ÷ 1,000 × 1.2
- Low daytime electricity consumption: Battery capacity (kWh) = Annual electricity consumption (kWh) ÷ 1,000 × 1.5
For the optimal sizing of your battery system, please contact your installer.
Safety is the core of every Fronius battery. They utilise the particularly safe and thermally stable lithium iron phosphate (LFP) technology, which is market-leading for its high level of safety, reliability and longevity.
An intelligent battery management system (BMS) continuously monitors key operating parameters such as voltage, current and temperature, and detects potential deviations at an early stage. This is complemented by a multi-level safety concept at cell, module and system level, featuring integrated protection mechanisms and automatic safety functions. This prevents critical operating conditions and ensures reliable operation over many years.
The Fronius Reserva and Fronius Reserva Pro are covered by a 10-year manufacturer’s warranty. The guaranteed State of Health (SoH) at the end of the warranty period may vary depending on the country and region and ranges from 70 % to 80 % of the original storage capacity.
You can find the detailed warranty terms and conditions, as well as the SoH values applicable to your country, in the relevant warranty documents.
Yes. With Fronius Solar.web, you can keep track of your energy flows at all times via the app or web browser. For example, you can see how much solar energy is being generated, stored, consumed or fed into the public grid. In addition, the battery’s current charge and operating status are also displayed in Solar.web.
In conjunction with the Energy Cost Assistant, you can further optimize battery usage by preferentially storing surplus solar energy and using it during periods of higher electricity prices. This helps increase self-consumption and reduce electricity drawn from the grid.
Detailed charging and discharging power ratings for Fronius batteries in combination with different Fronius inverters can be found in the respective solution sheet.
Fronius batteries are not simply disposed of at the end of their service life. Our aim is to keep batteries and valuable raw materials in circulation for as long as possible.
When a battery is taken out of service, specialist partners first check whether it can still be used. If this is not feasible, the battery modules are recycled professionally and valuable materials are returned to the raw materials cycle.
To this end, Fronius works with qualified take-back and recycling partners and supports the sustainable recovery of the materials used.
FAQs about the Digital Battery Passport
The fastest way to a Fronius device
