TPSi Robotcs
FRONIUS SYSTEM SOLUTIONS FOR THE MOST DEMANDING REQUIREMENTS
THE PERFECT SOLUTION FOR YOUR REQUIREMENTS
In welding technology, demands on quality, speed, precision and efficiency continue to increase across all industries. Whether it’s for manual or robot-assisted welding processes, a customised welding system that is perfectly tailored to the respective requirements is the key to a high level of productivity and to optimum, 100% reproducible welding results. This not only requires innovative technologies, but also high-quality, long-lasting components that work in perfect harmony with each other.
As the global welding technology leader, Fronius has a wealth of expertise in implementing customised welding solutions. Working together with our customers, we also solve difficult, complex tasks and provide perfectly tailored systems and first-rate service from a single source – from planning and development, through commissioning and training to maintenance and servicing. Our customers include renowned manufacturers in the automotive and component supply industries; shipbuilding and offshore; power generation; commercial vehicle, agricultural and construction machinery; pipeline construction and pipe manufacturing; robot manufacturing and system integration; rolling stock manufacturing, and many more besides. Whether for MIG/MAG or TIG welding, LaserHybrid welding or resistance spot welding: we find the ideal solution for every requirement.
FIND THE RIGHT CONTACT
Fronius International GmbH
vasb.vaqvn@sebavhf.pbz Other ways to contact us
POWERFUL WELDING TECHNOLOGY FOR COMPLEX TASKS
TPS/i – THE INTELLIGENT REVOLUTION
TPS/i, the new MIG/MAG power source platform from Fronius, has taken welding technology into a new era. The individually customisable and upgradeable appliances stand out due to their high intelligence and extensive communication capabilities. In conjunction with perfectly synchronised peripheral components, the TPS/i is the welding system of the future for both manual and robotic welding.
Find out more
CMT TWIN: COMBINES THE BEST OF TWO WELDING TECHNOLOGIES
With CMT Twin, Fronius combines two independently functioning arc-welding processes into one single process. This makes it possible to use two Cold Metal Transfer (CMT) processes, or combine a CMT process with a GMA pulse welding process, all within one single system. The setup consists of two power sources, one welding torch and two separate contact tips. The result is an extremely stable arc that can be used to weld thin sheets at high speed with minimal spatter, deep penetration and optimised weld-seam formation.
Find out more
LASERHYBRID: THE ADVANTAGES OF MIG AND LASER-BEAM WELDING COMBINED
The combination of laser and GMA welding makes it possible to exploit the advantages of each process to the full to create synergies. The high welding speed and concentrated energy of the laser can be effectively combined with the gas-metal arc in two ways: either through maximum welding speed when joining light-gauge sheets, or maximum penetration on thicker materials.
Find out more
DELTASPOT: INNOVATIVE RESISTANCE SPOT WELDING OF ALUMINIUM AND STEEL
With DeltaSpot, Fronius offers an innovative resistance spot welding process for aluminium and steel. Thanks to the spooling process tape, every welding spot is welded with an unused electrode and is therefore 100% reproducible. This enables the precise, high-quality spot welding of aluminium, as well as challenging sheet-steel joints, such as those involving visually exposed spots or coated high-strength sheets.
Find out more
