Fronius Primo GEN24 UL
Residential inverter with integrated backup power
Our single-phase inverter is the ideal heart of residential PV systems. The Fronius GEN24 combines smart solutions, intelligent software, and thoughtful engineering to achieve maximum yields.
With PV Point, the Fronius GEN24 offers an integrated basic backup power supply: Connected devices are supplied with backup power through a designated socket as long as the sun is shining.
With its diverse features, the Fronius GEN24 enables economic sustainability for long-term energy self-sufficiency. Discover the key advantages for installers and their customers:
- Integrated shade management
- Basic backup power without battery
- Highly flexible system design potential
- Built-in longevity thanks to the Active Cooling Technology
- Made in Europe
- Sustainably future-proof
Further technical data can be found in the data sheet which you find in the download section of this page.
Technical Data
Input Data
Number of MPP trackers2
Maximum PV input power3940 W
80 V
Min. MPP voltage (U mpp min)200 V
Max. MPP voltage (U mpp max)480 V
Output Data PV Point
Max. switchover time PV-Point17 s
Max. switchover time Full Backup17 s
General Data
Nominal voltage208V, 220V, 240V
Mains Frequency60 1/s, 50 1/sHz
Dimension / width474 mm
Dimension / height516 mm
Dimension / depth165 mm
Weight15,08 kg
Weight incl. packaging18,7 kg
Protection class1
2 / 4
CoolingActive Cooling Technology
Min. permissible ambient temperature-40 °C
Max. permissible ambient temperature60 °C
DC PV connection technology2x DC+1, 2x DC+2 and 4x DC- spring-type terminals for solid: copper
AWG14-8
DC battery connection technology1x DC+ and 1x DC- spring-type terminals for solid: copper
AWG 12-8
AC connection technologySpring-type terminals for solid: copper stranded / fine stranded: copper: AWG 14-8
Backup power spring-type terminals: AWG 16-8
Back-up power functionsPV Point
Sound emissions42 dB(A)
Interference emission classB
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift, Power limitation
DC disconnectorYes
Arc fault circuit interrupter (Fronius Arc Guard)Yes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter
Technical Data
Grid connectionNPE
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Multi Flow Technology
Full Backup
PV Point
Active Cooling
Fronius UP
Is a programme that allows the installer to upgrade a Fronius product via Solar.web – without any additional hardware. Fronius UP offers unique, new and innovative possibilities to expand Fronius products with new features according to the customers` needs at any time. This leads to maximum flexibility and future reliability.
