Fronius Symo
Maximum flexibility for the applications of tomorrow.
With power categories ranging from 3.0 to 8.2 kW, the transformerless Fronius Symo is the three-phase inverter for every system size. Owing to the SuperFlex Design, the Fronius Symo is the perfect answer to irregularly shaped or different roof orientations. A WLAN or Ethernet internet connection as standard plus easy integration of third-party components make the Fronius Symo one of the most communicative inverters on the market. Furthermore, the meter interface permits dynamic feed-in management and a clear visualisation of consumption.
Technical Data
Input Data
Number of MPP trackers | 1 |
Max. input current (Idc max) | 16 A |
Max. short circuit current, module array* | 24 A |
DC input voltage range (Udc min - Udc max) | 150 - 1000 V |
Nominal input voltage (Udc,r) | 595 V |
MPP voltage range (Umpp min - Umpp max) | 250 - 800 V |
Usable MPP voltage range | 150 - 800 V |
Number of DC connections | 3 |
Max. PV generator power (Pdc max) | 7,4 kWpeak |
Output Data
AC nominal output (Pac,r) | 3700 W |
Max. output power (Pac max) | 3700 VA |
AC output current (Iac nom) | 5,3 A |
Grid connection (Uac,r) | 3~ NPE 400/230, 3~ NPE 380/220 V |
Frequency (fr) | 50 / 60 Hz |
Total harmonic distortion | <3% @Pnom (230/400VAC 50Hz) |
Power factor (cos φac,r) | 0,70 - 1 ind./cap. |
General Data
Dimension / width | 432,5 mm |
Dimension / height | 642,5 mm |
Dimension / depth | 205,5 mm |
Weight | 16,54 kg |
Weight incl. packaging | 18,65 kg |
Degree of protection | IP 65 |
Protection class | 1 |
Night-time consumption | < 1 W |
Inverter design | Transformerless |
Cooling | Regulated air cooling |
Installation | Indoors and outdoors |
Ambient temperature range | -25°C - +60°C |
Permitted humidity | 0 - 100 % |
Max. altitude 2) | 2 000 m / 3 400 m |
DC connection technology | 3x DC+ and 3x DC- screw terminals 2.5 - 16 mm² |
AC connection technology | 5-pin AC screw terminals 2.5 - 16 mm² |
Certificates and compliance with standards | ÖVE / ÖNORM E 8001-4-712, DIN V VDE 0126-1-1/A1, VDE AR N 4105, IEC 62109-1/-2, IEC 62116, IEC 61727, AS 3100, AS 4777-2, AS 4777-3, CER 06-190, G83/2, UNE 206007-1, NRS 097 |
Sound emissions | 49,9 dB(A) |
Interference emission class | B |
Efficiency
Max. efficiency (PV - grid) | 98 % |
European efficiency (ηEU) | 96,7 % |
η at 5% Pac,r 3) | 83,4 / 86,4 / 80,6 % |
η at 10% Pac,r 3) | 90,1 / 92,5 / 88,7 % |
η at 20% Pac,r 3) | 93,7 / 95,7 / 93,6 % |
η at 25% Pac,r 3) | 94,5 / 96,4 / 94,7 % |
η at 30% Pac,r 3) | 95,0 / 96,7 / 95,4 % |
η at 50% Pac,r 3) | 96,9 / 97,6 / 96,7 % |
η at 75% Pac,r 3) | 96,2 / 97,8 / 97,3 % |
η at 100% Pac,r 3) | 96,2 / 98,0 / 97,5 % |
MPP adaptation efficiency | > 99,9 % |
Protection Devices
DC insulation measurement | Yes |
Overload behaviour | Operating point shift, power limitation |
DC disconnector | Yes |
DC Reverse polarity protection | Yes |
Interfaces
Wi-Fi / Ethernet LAN | Fronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON) |
6 inputs and 4 digital I/Os | Interface to ripple control receiver |
Datalogger and web server | Integrated |
RS485 | Modbus RTU SunSpec or meter connection |
SnapINverter technology
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
Active Cooling
1) According to IEC 62109-1.
2) Unrestricted/restricted voltage range.
