Fronius Symo
Maximum flexibility for the applications of tomorrow.
With power categories ranging from 3.0 to 8.2 kW, the transformerless Fronius Symo is the three-phase inverter for every system size. Owing to the SuperFlex Design, the Fronius Symo is the perfect answer to irregularly shaped or different roof orientations. A WLAN or Ethernet internet connection as standard plus easy integration of third-party components make the Fronius Symo one of the most communicative inverters on the market. Furthermore, the meter interface permits dynamic feed-in management and a clear visualisation of consumption.
Technical Data
Input Data
| Number of MPP trackers | 1 |
Max. input current (Idc max) | 16 A |
Max. short circuit current, module array* | 24 A |
DC input voltage range (Udc min - Udc max) | 150 - 1000 V |
Nominal input voltage (Udc,r) | 595 V |
MPP voltage range (Umpp min - Umpp max) | 200 - 800 V |
| Usable MPP voltage range | 150 - 800 V |
| Number of DC connections | 3 |
Max. PV generator power (Pdc max) | 6 kWpeak |
Output Data
AC nominal output (Pac,r) | 3000 W |
Max. output power (Pac max) | 3000 VA |
AC output current (Iac nom) | 4,3 A |
Grid connection (Uac,r) | 3~ NPE 400/230, 3~ NPE 380/220 V |
Frequency (fr) | 50 / 60 Hz |
Power factor (cos φac,r) | 0,70 - 1 ind./cap. |
General Data
| Mains Frequency | Hz |
| Dimension / width | 432,5 mm |
| Dimension / height | 642,5 mm |
| Dimension / depth | 205,5 mm |
| Weight | 16,54 kg |
| Weight incl. packaging | 18,65 kg |
| Degree of protection | IP 65 |
| Protection class | 1 |
| Night-time consumption | < 1 W |
| Inverter design | Transformerless |
| Installation | Indoors and outdoors |
| Ambient temperature range | -25°C - +60°C |
| Permitted humidity | 0 - 100 % |
| Max. altitude | 3400 m |
| DC connection technology | 3x DC+ and 3x DC- screw terminals 2.5 - 16 mm² |
| AC connection technology | 5-pin AC screw terminals 2.5 - 16 mm² |
| Certificates and compliance with standards | ÖVE / ÖNORM E 8001-4-712, DIN V VDE 0126-1-1/A1, VDE AR N 4105, IEC 62109-1/-2, IEC 62116, IEC 61727, AS 3100, AS 4777-2, AS 4777-3, CER 06-190, G83/2, UNE 206007-1, NRS 097 |
| Sound emissions | 49,9 dB(A) |
Efficiency
| Max. efficiency (PV - grid) | 98 % |
| European efficiency (ηEU) | 96,2 % |
η at 5% Pac,r 3) | 80,3 / 83,6 / 79,1 % |
η at 10% Pac,r 3) | 87,8 / 91,0 / 86,2 % |
η at 20% Pac,r 3) | 92,6 / 95,0 / 92,6 % |
η at 25% Pac,r 3) | 93,4 / 95,6 / 93,8 % |
η at 30% Pac,r 3) | 94,0 / 96,3 / 94,5 % |
η at 50% Pac,r 3) | 95,2 / 97,3 / 96,3 % |
η at 75% Pac,r 3) | 95,6 / 97,7 / 97,0 % |
η at 100% Pac,r 3) | 95,6 / 97,9 / 97,3 % |
| MPP adaptation efficiency | > 99,9 % |
Protection Devices
| Overload behaviour | Operating point shift, power limitation |
| DC disconnector | Yes |
Interfaces
| Wi-Fi / Ethernet LAN | Fronius Solar.web, Modbus TCP SunSpec, Fronius Solar API (JSON) |
| 6 inputs and 4 digital I/Os | Interface to ripple control receiver |
| Datalogger and web server | Integrated |
| RS485 | Modbus RTU SunSpec or meter connection |
SnapINverter technology
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Smart Grid Ready
Zero feed-in
Active Cooling
1) According to IEC 62109-1.
2) Unrestricted/restricted voltage range.
