Installers & partners
Fronius Primo GEN24
Inverters for private photovoltaic systems with integrated basic backup power function
Our single-phase Fronius GEN24 inverter is the heart of private photovoltaic systems.
The Fronius GEN24 is equipped with PV Point, an integrated basic backup power function that supplies backup power to connected devices via a protected socket (as long as the sun is shining).
The Fronius Primo GEN24 boasts a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers:
/ Active cooling technology for a longer service life
/ Flexible and fast installation
Product details
Input Data
Number of MPP trackers2
Max. input current (Idc max)
22 / 22 A
41,25 / 36 A
65 - 600 V
80 V
Nominal input voltage (Udc,r)
400 V
260 - 480 V
Usable MPP voltage range65 - 480 V
Number of DC connections2+2
12 kWpeak
Output Data
AC nominal output (Pac,r)
8000 W
Max. output power (Pac max)
8000 VA
Max. AC output current45,45 A
Grid connection (Uac,r)
1~ NPE 220/230 V
155 - 270 V
Frequency (fr)
50 / 60 Hz
Frequency range (fmin - fmax)
45 - 65 Hz
Power factor (cos φac,r)
0,8 - 1 ind./cap.
Nom. output current (220VAC)13,6 A
Nom. output current (230VAC)13 A
Output Data PV Point
Nom. output current (Iac max)
13 A
Grid connection1~NPE 220 V / 230 V
Frequency50 Hz / 60 Hz
Max. switchover time PV-Point20 s
Battery Connection
Max. input current (Idc max.)
22 A
Max. input / output power (Depending on the connected battery)8260 W
Min. DC input voltage150 V
Max. DC input voltage455 V
General Data
Mains FrequencyHz
Dimension / length595 mm
Dimension / width529 mm
Dimension / depth180 mm
Weight21 kg
Weight incl. packaging26,05 kg
Degree of protectionIP66
Protection class1
2 / 3
Night-time consumption< 10 W
CoolingRegulated air cooling
Ambient temperature range-40°C - +60°C
Permitted humidity0 - 100 %
Max. altitude4000 m
DC PV connection technology4 × DC+ and 4 × DC- push-in tension clamp terminals 2.5 - 10 mm²
AC connection technology3 pole AC push-in spring terminals 2.5 - 10 mm² 3 pole backup power push-in spring terminals 1.5mm² - 10mm² 2x PE-screw terminals 2.5 - 16 mm² and  3x 2,5 - 10mm²
Certificates and compliance with standardsIEC 62109, IEC 62909, AS/NZS 4777.2, CEI 0-21, ABNT BNR 16149 and 16150, IEC 62116, IEC 61727 4)
Back-up power functionsPV Point
Sound emissions51 dB(A)
Interference emission classB
Efficiency
Max. efficiency (PV - grid)97,3 %
European efficiency (ηEU)96.5 / 96.9 / 96.4 (260Vdc / 400Vdc / 480Vdc)
η at 5% Pac,r 3)
90.3 / 91.2 / 88.7 (260Vdc / 400Vdc / 480Vdc)
η at 10% Pac,r 3)
94.4 / 94.9 / 93.5 (260Vdc / 400Vdc / 480Vdc)
η at 20% Pac,r 3)
96.3 / 96.6 / 96.0 (260Vdc / 400Vdc / 480Vdc)
η at 25% Pac,r 3)
96.6 / 96.9 / 96.4 (260Vdc / 400Vdc / 480Vdc)
η at 30% Pac,r 3)
96.8 / 97.1 / 96.7 (260Vdc / 400Vdc / 480Vdc)
η at 50% Pac,r 3)
97.0 / 97.3 / 97.0 (260Vdc / 400Vdc / 480Vdc)
η at 75% Pac,r 3)
97.0 / 97.3 / 97.1 (260Vdc / 400Vdc / 480Vdc)
η at 100% Pac,r 3)
96.8 / 97.2 / 96.9 (260Vdc / 400Vdc / 480Vdc)
MPP adaptation efficiency99,74
Protection Devices
DC insulation measurementYes
Overload behaviourOperating point shift. Power limitation
DC disconnectorYes
Interfaces
Emergency stop (WSD)Yes
2x RS485Modbus RTU SunSpec (third-party supplier) / Fronius Smart Meter, battery, Fronius Ohmpilot
The hybrid functions battery connection and full backup can be retrofitted to the GEN24 by Fronius UP.storage*!
