Fronius Primo GEN24
Inverters for private photovoltaic systems with integrated basic backup power function
Our single-phase Fronius GEN24 inverter is the heart of private photovoltaic systems.
The Fronius GEN24 is equipped with PV Point, an integrated basic backup power function that supplies backup power to connected devices via a protected socket (as long as the sun is shining).
The Fronius Primo GEN24 boasts a wide range of features that support a sustainable, independent energy supply. Discover the key features for installers and their customers:
/ Active cooling technology for a longer service life
/ Flexible and fast installation
Technical Data
Input Data
| Number of MPP trackers | 2 |
Max. input current (Idc max) | 22 / 12 A |
Max. short circuit current, module array* | 41,25 / 22 A |
DC input voltage range (Udc min - Udc max) | 65 - 600 V |
Feed-in start voltage (Udc start) | 80 V |
Nominal input voltage (Udc,r) | 400 V |
MPP voltage range (Umpp min - Umpp max) | 210 - 530 V |
| Usable MPP voltage range | 65 - 530 V |
| Number of DC connections | 2+2 |
| Min. MPP voltage (U mpp min) | 210 V |
| Max. MPP voltage (U mpp max) | 530 V |
Max. PV generator power (Pdc max) | 6 kWpeak |
Output Data
AC nominal output (Pac,r) | 4000 W |
Max. output power (Pac max) | 4000 VA |
| Max. grid power demand | 4000 VA |
| Max. AC output current | 25,8 A |
Grid connection (Uac,r) | 1~ NPE 220/230 V |
AC voltage range (Umin - Umax) | 155 - 270 V |
Frequency (fr) | 50 / 60 Hz |
| Frequency (fr) | IEC 62109, IEC 62909, AS/NZS 4777.2, CEI 0-21, ABNT BNR 16149 and 16150, IEC 62116, IEC 61727,G98/G994) |
Power factor (cos φac,r) | 0,8 - 1 ind./cap. |
| Back-up power | 1~NPE 220 V / 230 V |
| Nom. output current (220VAC) | 18.2 A |
| Nom. output current (230VAC) | 17.4 A |
Output Data PV Point
| Max continuous output power | 3000 VA |
Nom. output current (Iac max) | 13 A |
| Grid connection | 1~NPE 220 V / 230 V |
| Frequency | 50 Hz / 60 Hz |
| Max. switchover time PV-Point | 15 s |
| Frequency in backup power mode | 53 Hz |
General Data
| Mains Frequency | Hz |
| Dimension / width | 474 mm |
| Dimension / height | 530 mm |
| Dimension / depth | 165 mm |
| Weight | 15,38 kg |
| Weight incl. packaging | 19 kg |
| Degree of protection | IP66 |
| Protection class | 1 |
| Night-time consumption | < 10 W |
| Inverter design | Trafolos |
| Cooling | Active cooling |
| Installation | Indoor and outdoor installation |
| Ambient temperature range | -40°C - +60°C |
| Permitted humidity | 0 - 100 % |
| Max. altitude | 4000 m |
| DC PV connection technology | 4x DC+ and 4x DC- push-in spring-loaded terminals 2.5 - 10 mm² |
| AC connection technology | 3-pole AC push-in spring-loaded terminals 2.5 - 10 mm² 3-pole backup power push-in spring-loaded terminals 1.5 mm² - 10 mm² 2x PE screw terminals 2.5 - 16 mm² and 3x 2.5 - 10 mm² |
| Certificates and compliance with standards | IEC 62109, IEC 62909, AS/NZS 4777.2, CEI 0-21, ABNT BNR 16149 und 16150, IEC 62116, IEC 61727, G98/G994) |
| Back-up power functions | PV Point |
| Sound emissions | 42 dB(A) |
Efficiency
| Max. efficiency (PV - grid) | 97,6 % |
| European efficiency (ηEU) | 95.8 / 97.1 / 96.5 (210Vdc / 400Vdc / 530Vdc) |
η at 5% Pac,r 3) | 85.8 / 90.5 / 88.2 (210Vdc / 400Vdc / 530Vdc) |
η at 10% Pac,r 3) | 90.3 / 93.7 / 92.2 (210Vdc / 400Vdc / 530Vdc) |
η at 20% Pac,r 3) | 94.4 / 96.3 / 95.6 (210Vdc / 400Vdc / 530Vdc) |
η at 25% Pac,r 3) | 95.1 / 96.7 / 96.1 (210Vdc / 400Vdc / 530Vdc) |
η at 30% Pac,r 3) | 95.6 / 97.0 / 96.5 (210Vdc / 400Vdc / 530Vdc) |
η at 50% Pac,r 3) | 96.5 / 97.4 / 97.1 (210Vdc / 400Vdc / 530Vdc) |
η at 75% Pac,r 3) | 96.7 / 97.5 / 97.3 (210Vdc / 400Vdc / 530Vdc) |
η at 100% Pac,r 3) | 96.7 / 97.5 / 97.3 (210Vdc / 400Vdc / 530Vdc) |
| MPP adaptation efficiency | 99.9 |
Protection Devices
| Overload behaviour | Operating point shift, power limitation |
| DC disconnector | Yes |
Interfaces
| 6x digital in/out + 6x digital in | Connection to ripple control receivers, energy management |
| Emergency stop (WSD) | Yes |
| Datalogger and web server | Integrated |
| 2x RS485 | Modbus RTU SunSpec (third-party provider) / Fronius Smart Meter, battery, Fronius Ohmpilot |
Integrated data communication
SuperFlex Design
Dynamic Peak Manager
Multi Flow Technology
Full Backup
PV Point
Active Cooling
Fronius UP
Is a programme that allows the installer to upgrade a Fronius product via Solar.web – without any additional hardware. Fronius UP offers unique, new and innovative possibilities to expand Fronius products with new features according to the customers` needs at any time. This leads to maximum flexibility and future reliability.The hybrid functions battery connection and full backup can be retrofitted to the GEN24 by Fronius UP.storage*!
Footnotes for technical data
1) According to IEC 62109-1. Option to retrofit surge protection device DC SPD type 1+2 for 2 MPP trackers available under the following item number: 4,240,313,CK
2) Unrestricted voltage range.
3) At Umpp min. / Udc,r / Umpp max.
4) You can find the current certificates under www.fronius.com/primo-gen24-plus-cert
