Fronius Primo UL
The communicative inverter for private households.
The Fronius Primo inverter series has been specially developed for the demands of the North American market. With power categories from 3.8 to 15 kW, the single-phase, transformerless device is the perfect inverter for private households. Its innovative SuperFlex Design provides maximum flexibility in system design, while the SnapINverter mounting system makes installation and maintenance as easy as possible. The communication package included as standard, with WLAN, energy management, several interfaces and much more besides, makes the Fronius Primo a communicative inverter for home owners. Standard equipment also includes a built-in arc detector (AFCI = Arc Fault Circuit Interrupter), in keeping with all other North American SnapINverters.
Technical Data
Input Data
Number of MPP trackers2
Max. usable input current33,0 / 18,0 A
Max. usable input current total (MPPT1 + MPPT2)
51 A
Max. array short circuit current (1.5 * Imax)49,5 / 27 A
Output Data
Max. output power 240 V11,4 kVA
Max. output power 208 V11,4 kVA
Output configuration
1~ NPE 208 / 240 V
Frequency range45 - 66 Hz
Frequency60 Hz
Total harmonic distortion< 2,5 %
Power factor range
0 - 1 ind./cap.
Max. continuous output current 240 V47,5 A
Max. continuous output current 208 V54,8 A
OCPD/AC breaker size 208 V70 A
Max. efficiency97,9 %
CEC efficiency 240 V96,5 %
General Data
UL safety standards & network regulationsUL 1741-2015, UL 1998, UL 1699B Issue 2-2013
Dimension / width512 mm
Dimension / height751 mm
Dimension / depth227,5 mm
Weight incl. packaging45 kg
Weight37,4 kg
Degree of protectionNEMA 4X
Night-time consumption< 1 W
Interference emission classB
SnapINverter technology
Integrated data communication
SuperFlex Design
Smart Grid Ready
Arc Fault Circuit Interruption Integrated
The Fronius Arc Fault Circuit Interruption (AFCI) makes each inverter NEC 2011 compliant and maintains some of the most civilized, integrated technology available today. Ensuring the utmost safety, AFCI shuts down the inverter in the event of an arc fault.
Active Cooling
Digital Operating Instruction
Smart Grid Ready
1 / 3
Fronius SnapINverter with innovative hinged system
Smart Grid Ready from Fronius
Fronius Robustness Tests
Fronius SnapINverters
SnapINverter
The deliberate design of the Fronius SnapINverter meets great enthusiasm of our installers and customers.
