Fronius Primo UL
The communicative inverter for private households.
The Fronius Primo inverter series has been specially developed for the demands of the North American market. With power categories from 3.8 to 15 kW, the single-phase, transformerless device is the perfect inverter for private households. Its innovative SuperFlex Design provides maximum flexibility in system design, while the SnapINverter mounting system makes installation and maintenance as easy as possible. The communication package included as standard, with WLAN, energy management, several interfaces and much more besides, makes the Fronius Primo a communicative inverter for home owners. Standard equipment also includes a built-in arc detector (AFCI = Arc Fault Circuit Interrupter), in keeping with all other North American SnapINverters.
Technical Data
Input Data
Number of MPP trackers2
Max. usable input current18,0 / 18,0 A
Max. usable input current total (MPPT1 + MPPT2)
36 A
Max. array short circuit current (1.5 * Imax)27 / 27 A
80 - 1000 V
240 - 800 V
Max. input voltage1000 V
Output Data
Max. output power 240 V6000 VA
Max. output power 208 V6000 VA
Output configuration
1~ NPE 208 / 240 V
Frequency range45 - 66 Hz
Frequency60 Hz
Total harmonic distortion< 5 %
Power factor range
0,85 - 1 ind./cap.
Max. continuous output current 240 V25 A
Max. continuous output current 208 V28,8 A
OCPD/AC breaker size 208 V40 A
Max. efficiency96,9 %
CEC efficiency 240 V96 %
CEC efficiency 208 V96 %
General Data
UL safety standards & network regulationsUL 1741-2010, UL 1998, UL 1699B Issue 2-2013
Dimension / width432,7 mm
Dimension / height642,5 mm
Dimension / depth204,5 mm
Weight30 kg
Weight incl. packaging25,8 kg
Weight21,5 kg
Degree of protectionNEMA 4X
Night-time consumption< 1 W
CoolingVariable speed fan
Max. altitude4000 m (13120 ft) with a max. input voltage of 1000 V
Certificates and compliance with standardsUL 1741-2010 Second Edition (incl. UL1741 Supplement SA 2016-09 for California Rule 21), UL1998 (for functions: AFCI, RCMU and isolation monitoring), IEEE 1547-2003, IEEE 1547.1-2003, ANSI/IEEE C62.41, FCC Part 15 A & B, NEC 2017 Article 690, C22. 2 No. 107.1-16, UL1699B Issue 2 -2013, CSA TIL M-07 Issue 1 – 2013
DC connection technology4x DC+ and 4x DC- screw terminals for copper (solid/stranded/fine stranded) or aluminium (solid/stranded)
AC connection technologyScrew terminals 12 - 6 AWG
Revenue Grade MeteringOptional (ANSI C12.1 accuracy)
Interference emission classB
Protection Devices
DC reverse polarity protectionYes
Anti islandinginternal in accordance with UL 1741-2016-09, IEEE 1547-2003 and NEC 2017
Over temperature protectionOutput power derating / Active cooling
AFCIYes
Rapid shutdown compliantYes (according to NEC 2014)
Ground fault protection with isolation monitor interrupterYes
DC disconnectorYes
Interfaces
Wi-Fi / Ethernet LANWireless standard 802.1 1 b/g/n / Fronius Solar.web, SunSpec Modbus TCP, JSON
USB (type A socket)Datalogging and inverter update possible via USB
2x RS422 (RJ45 socket)Fronius Solar Net
RS485SunSpec Modbus RTU
6 inputs and 4 digital I/OsLoad management signaling, multipurpose I/O
SnapINverter technology
Integrated data communication
SuperFlex Design
Smart Grid Ready
Arc Fault Circuit Interruption Integrated
The Fronius Arc Fault Circuit Interruption (AFCI) makes each inverter NEC 2011 compliant and maintains some of the most civilized, integrated technology available today. Ensuring the utmost safety, AFCI shuts down the inverter in the event of an arc fault.
Active Cooling
Digital Operating Instruction
Smart Grid Ready
1 / 3
Fronius SnapINverter with innovative hinged system
Smart Grid Ready from Fronius
Fronius Robustness Tests
Fronius SnapINverters
SnapINverter
The deliberate design of the Fronius SnapINverter meets great enthusiasm of our installers and customers.
