Our TPS/i TWIN Systems
Intelligent Tandem Welding
Tandem welding has never been so easy
Consistently high welding speed with reliable penetration and deposition rates of up to 25 kg/h—our TPS/i TWIN systems have got you covered.
Our newest development with intelligent welding processes that automatically adjust welding parameters and welding variables in the background provide maximum control and time savings—supported by robot assistance systems and automatic change and cleaning systems.
TPS/i TWIN systems are adapted to the respective application area on a modular basis. Whereas a push system is the ideal solution for steel applications, a PushPull solution is recommended for aluminum. If you want to achieve the absolute maximum when it comes to welding speed and process stability, look no further than the CMT TWIN process.
Self-regulating process
Only adjust the most necessary aspects
Achieve better results automatically: During the welding process, our system regulates the welding parameters and welding variables independently in the background to keep both arcs perfectly regulated at all times.
Smart assistance systems
Support that saves you time
TeachMode, TouchSense, SeamTracking, WireSense and short circuit detection within the gas nozzle: Our assistance systems simplify handling of the welding system and thereby increase welding efficiency.
High deposition rate
Up to 25 kg/h
Processing large, heavy components has never been easier. This is possible thanks to the power of 2 TPS/i power sources in one system, leading to particularly high deposition rates and excellent gap-bridging ability.
High-speed welding
Welding speeds of up to 4 m/min
Fast welding without loss of quality: This is par for the course owing to the high deposition rate—just like the reliable penetration and notch-free welds.
Totally stable welding
Continuous production with a long service life
High level of process reliability thanks to reliable wirefeeding. The highly dynamic TWIN Drive unit and wire buffers ensure, amongst other things, maximum stability.
TWIN systems at a glance
TWIN PUSH TWIN PUSH/PULL CMT TWIN
Welding process: PMC TWIN
Field of application: Steel
Typical welding tasks: Axles, rims, bogie frames and steel beams
Field of application: Aluminum
Typical welding tasks: Aluminum profiles, carriage construction, containers, pressure vessels, tanks
Welding process: CMT TWIN and PMC TWIN
Field of application: Light gage sheet, aluminum, nickel-based alloys, high-strength steel
Typical welding tasks: Axle production, exhaust systems, hydraulic cylinders, mobile crane booms, pressure vessels
System design
The TWIN welding processes
PMC TWIN
PMC (Pulse Multi Control) is a further development of the pulsed arc from Fronius. It provides the technological basis for the PMC TWIN process and is available with different characteristics as is typical from Fronius.
As a result, the right process properties can be accessed directly depending on the application scenario.
Reliable penetration
Achieve the desired weld quality with maximum reliability:
With the TWIN process, even greater penetration is achieved despite its tremendous speed.
Same a-dimension (a7) and over 30% more penetration at 75% higher welding speed with TWIN.
One weld is enough: Thanks to the high deposition rate of the TWIN system, welds that require multiple layers are a thing of the past.
CMT TWIN
CMT (Cold Metal Transfer) is a welding process developed by Fronius that provides the technological basis for the CMT TWIN process.
By combining different processes, benefits such as high speed, a gap-bridging ability and few spatters are brought together in one process. The process is also available with different characteristics to ensure users have the right process properties for their application at their fingertips.
Achieve the perfect result at top speed
Reliable penetration without notches: Thanks to the high deposition rate, the tandem process enables speeds of up to 330 cm/min. This allows you to weld 2.5 times faster than with just one arc.
Gap-bridging ability
Four times the welding speed and optimal gap-bridging ability with TWIN welding despite a 3 mm gap!
1 / 2
Current [A]: 155, voltage [V]: 12.3, vs [cm/min]: 30
Lead: Current [A]: 280, voltage [V]: 28.0, vs [cm/min]: 110 trail: Current [A]: 125, voltage [V]: 17.0, vs [cm/min]: –
Intelligent welding
Faster and more precise welding—this is made possible thanks to our TWIN series with various auxiliary systems. In combination with robot control, they all support the welder in their work, helping to make the production process as efficient as possible.
This not only saves time and minimizes errors, it also means that welds can be reproduced in the desired quality at any time—without the need for manual fine-tuning. What’s more, they can withstand the greatest loads and meet the highest demands thanks to their outstanding design.
Our assistance systems at a glance
For efficient programming of welding positions on the robot: The wire is pulled back before it collides with the component, thus preventing the wire from bending. The set stick-out always remains the same.
Compensates for clamping and component tolerances during the welding process, thus preventing welding errors and unnecessary rejects.
Reduces time-consuming reworking: The wire electrodes measure component deviations such as varying air gaps or clamping tolerances and transmit the values to the robot.
Safe and clean start to the welding process: Before welding, slag that has formed during previous welds is knocked off by reversing wire movements.
Developed for welding fillet welds and processed butt welds; the wire or gas nozzle precisely scans the component and transmits the start and end position to the robot, which calculates the exact seam path.
The welding system detects accumulations of welding spatter inside the gas nozzle. Cleaning routines can be optimized and process reliability can be increased.
Spatter-free ignition with SFI enables safe and clean ignition.
Let’s get connected.
